B
THRU UM10B
UM05B
0.8 AMP SURFACE MOUNT BRIDGE RECTIFIERS
VOLTAGE RANGE
FEATURES:
50 to 1000 Volts
Glass Passivated Chip Junction
CURRENT
Reverse Voltage - 100 to 1000 V
0.8 Ampere
Average Rectified Output Current - 0.8 A
UMB
High Surge Current Capability
∠ALL ROUND
E
e
C
Designed for Surface Mount Application
HE
D
g
A
MECHANICAL DATA
• Case: UMB
• Terminals: Solderable per MIL-STD-750,
Method 2026
• A pprox. Weight: 45mg 0.0016oz
d
A
UNIT
C
D
E
HE
g
d
e
max
1.2
0.20
3.8
4.0
5.1
0.82
2.7
0.70
min
1.0
0.12
3.4
3.6
4.6
0.51
2.3
0.51
max
47
7.9
150
157
201
32
106
28
min
39
4.7
134
142
181
mm
7°
mil
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
UM05B UM1B UM2B
50
35
50
100
70
100
200
140
200
UM4B
UM6B
400
280
400
600
420
600
UM8B UM10B UNIT
800
560
800
1000
700
1000
V
V
V
at Ta=40 C(Note 1)
Peak Forward Surge Current, 8.3 ms single half sine-wave
0.8
A
superimposed on rated load (JEDEC method)
Maximum Forward Voltage Drop per Bridge Element at 0.4A D.C.
Maximum DC Reverse Current
Ta=25 C
25
1.0
3.0
A
V
at Rated DC Blocking Voltage
Ta=125 C
Typical Thermal Resistance RqJA (Note 2)
Operating Temperature Range, TJ
Storage Temperature Range, TSTG
100
110
-55 +150
-55 +150
μA
μA
m
C/W
C
C
NOTES: 1. Mounted on P.C. Board.
2. Thermal Resistance Junction to Ambient.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (UM05B THRU UM10B)
FIG.2-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
1.2
1.0
0.8
0.6
Single Phase
Half Wave 60Hz
0.4
Resistive Or Inductive Load
0.2
50
75
100 125
150
175
AMBIENT TEMPERATURE ( C)
PEAK FORWAARD SURGE CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT
DERATING CURVE
50
40
30
8.3ms Single Half
Tj=25 C
Sine Wave
JEDEC method
10
5
50
10
100
FIG.3-TYPICAL FORWARD
FIG.4-TYPICAL REVERSE
CHARACTERISTICS
CHARACTERISTICS
50
50
10
10
T J =125°C
REVERSE LEAKAGE CURRENT, (mA)
INSTANTANEOUS FORWARD CURRENT,(A)
NUMBER OF CYCLES AT 60Hz
3.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
3.0
1.0
0.1
Tj=25 C
.01
.01
.4
.6
.8
1.0
FORWARD VOLTAGE,(V)
1.2
1.4
60
80
100 120 140
PERCENTAGE OF PEAK REVERSE VOLTAGE, (%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“UM10B-B7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16967
- 200+0.13889
- 600+0.12172
- 5000+0.10520
- 10000+0.09634
- 20000+0.09148
