SS1045
SS10200
THRU
10.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
45 to 200 Volts
CURRENT
10.0Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
DO-214AB(SMC)
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
MECHANICAL DATA
.280(7.11)
.260(6.60)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
.012(0.31)
.006(0.15)
.103(2.62)
.079(2.00)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS104 5
SS106 0 SS10100
100
60
70
42
100
60
45
32
45
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 10.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JA (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SS1015 0 SS10200 UNITS
200
150
V
105
140
V
150
200
V
A
10.0
175
0.55
0.7
0.92
0.85
50
0.70
0.85
0.70
0.85
50
440
250
60
to10+150
-55
-55 to +150
A
V
A
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS1045 THRU SS10200)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
FIG.2-TYPICAL FORWARD
50
4
2
60
80
100
120
140
160
180
200
CASE TEMPERATURE,( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
10
5.0
SS
101
50SS
102
00
6
SS
106
SS
101
00
8
SS
10
45
10
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
12
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
.01
200
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
8.3ms Single Half
Tj=25 C
Sine Wave
100
JEDEC method
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
FIG.4-TYPICAL JUNCTION CAPACITANCE
REVERSE LEAKAGE CURRENT, (mA)
2800
JUNCTION CAPACITANCE,(pF)
PEAK FORWARD SURGE CURRENT,(A)
250
2400
2000
1600
1200
800
400
Tj=100 C
1.0
Tj=75 C
.1
Tj=25 C
.01
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENT OF RATED PEAK REVERSE VOLTAGE,(%)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS10100-SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.82591
- 50+0.67661
- 150+0.60196
- 500+0.54598
- 3000+0.41923
- 6000+0.39687
- 国内价格
- 1+0.38170
- 3000+0.35640
- 国内价格
- 5+1.10546
- 50+0.87568
- 150+0.77718
- 500+0.65435
- 3000+0.52777
- 6000+0.49490
