SS310FL
3.0 AMP SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
100 Volts
CURRENT
FEATURES
3.0 Amperes
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
SMAF
.146(3.7)
.130(3.3)
.063(1.6)
.051(1.3)
MECHANICAL DATA
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
.193(4.9)
.173(4.4)
.009(0.23)
.007(0.18)
.051(1.30)
.043(1.10)
.106(2.7)
.094(2.4)
.051(1.3)
.039(1.0)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
See Fig. 1
Peak Forward Surge Current, 8.3 ms single half sine-wave
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Ta=125 C
Typical Junction Capacitance (Note1)
Typical Thermal Resistance R JL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
SS310 FL
UNITS
100
70
100
V
V
V
3.0
A
80
A
V
A
0.67
100
0.70
0.85
100
250
28
10
to +150
-55
-55 to +150
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. P.C.B. mounted with 0.2" x 0.2" (5.0 mm x 5.0 mm) copper pad areas
REV 1.0 2015 JAN
PAGE:1/2
RATING AND VHARACTERISTIC CURVES(SS310FL)
FIG.1-FORWARD CURRENT DERATING CURVE
FIG.2-MAXIMUM NON-REPETITIVE PEAK
FORWARD SURGE CURRENT
120
RESISTIVE OR INDUCTIVE LOAD
4.0
PEAK FORWARD SURGE
CURRENT(AMPERES)
AVERAGE FORWARD CURRENT
AMPERES
5.0
3.0
2.0
1.0
60
80
120 130
100
TJ=TJMAX
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
100
80
60
40
LEAD TEMPERATURE ( ℃)
1
10
100
NUMBER OF CYCLES AT 60Hz
FIG.3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
FIG.4-TYPICAL REVERSE CHARACTERISTICS
200
INSTANTANEOUS REVERSE CURRENT (mA)
INSTANTANEOUS FORWARD CURRENT( AMPERES)
50
TJ=100℃
10
1
TJ=125℃
PULSE WIDTH=300μS
1% DUTY CYCLE
TJ=25℃
0.1
100
10
TJ=125℃
TJ=100℃
1
0.1
0.01
TJ=25℃
0.2
0.3
0.4
0.5
0.6
0.7
0.8
0.01
INSTANTANEOUS FORWARD VOLTAGE (V)
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE%
FIG.5-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE(pF)
4000
1000
100
0.1
1
10
100
REVERSE VOLTAGE. VOLTS
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS310FL”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.41214
- 100+0.32700
- 300+0.28441
- 3000+0.22994
- 6000+0.20438
- 9000+0.19166
