10A10-F
10A10-F
    GOODWORK(固得沃克)
    R-6
    整流二极管 VRRM=1KV If=10A VF=1V CJ=150pF R6_D9.1X9.1MM
10A10-F 数据手册
1 10A05 THRU 10A10 10.0 AMP SILICON RECTIFIERS VOLTAGE RANGE 50 TO 1000 Volts CURRENT 6.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability R-6 .360(9.1) .340(8.6) DIA. 1.0(25.4) MIN. MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 1.65 grams .360(9.1) .340(8.6) 1.0(25.4) MIN. .052(1.3) .048(1.2) DIA. Dimensions in inches and (millimeters) 0 Ratings at 25 C ambient temperature unless otherwise specified. Single phase, half wave, 60Hz, resistive or inductive load.. For capacitive load, derate current by 20%. Symbols 10A05 10A1 10A2 10A4 10A6 10A8 10A10 Units Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 Volts Maximum RMS voltage VRMS 35 70 140 280 420 560 700 Volts VDC 50 100 200 400 600 800 1000 Volts Maximum DC blocking voltage O Maximum average forward rectified current @TA=50 C IF(AV) 10 Amps Peak forward surge current 8.3ms single half sine-wave superimposed on rated load (JEDEC method) IFSM 300 Amps VF 1 Volts IR 10 100 µA CJ 150 pF RθJA 10 Operating temperature range TJ -55 to+125 O C Storage temperature range TS -55 to+150 O C Maximum forward voltage at 10A DC Maximum DC reverse current O @TJ = 25 C O at rated DC blocking voltage @TJ = 100 C Typical junction capacitance (Note 1) Typical thermal resistance (Note 2) O C/W REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (10A05 THRU 10A10) PEAK FORWARD SURGE CURRENT,(A) FIG.4-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 375 300 225 8.3ms Single Half Tj=25 C Sine Wave 150 JEDEC method 75 0 1 5 50 10 100 NUMBER OF CYCLES AT 60Hz REV 1.0 2015 JAN PAGE:2/2
10A10-F 价格&库存
很抱歉,暂时无法提供与“10A10-F”相匹配的价格&库存,您可以联系我们找货
10A10-F
  • 5+0.64793
  • 50+0.52542
  • 150+0.46427
  • 500+0.37439
  • 2500+0.33767
  • 5000+0.31930
库存:1948
10A10-F
    • 1+0.48760
    库存:40
