SB10100L
SB10100L
    GOODWORK(固得沃克)
    TO-277
    10.0安培肖特基势垒整流器
SB10100L 数据手册
SB10100L 10.0 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE CURRENT 10.0 Ampere 0.264 (6.70) 0.248 (6.30) 1 0.073 (1.85) 0.069 (1.75) 2 3 0.028 (0.71) 0.016 (0.41) 0.216 (5.48) 0.208 (5.28) ■ Mechanical data • Epoxy : UL94-V0 rated flame retardant. • Case : Molded plastic, TO-277 . • Lead : Solder plated, solderable per MIL-STD-750, Method 2026. • Polarity: Indicated by cathode band . • Mounting Position : Any. • Weight : Approximated 0.093 grams . PIN 1 PIN 3 PIN 2 0.163 (4.13) 0.151 (3.83) TO-277 ■ Features • Low forward voltage drop. • Excellent high temperature stability. • Fast switching capability. • Suffix "G" indicates Halogen-free part, ex.CP10S45SG. • Lead-free parts meet environmental standards of MIL-STD-19500 /228 100 Volts 0.077 (1.96) 0.069 (1.76) 0.028 (0.71) 0.016 (0.41) 0.037 (0.95) 0.033 (0.85) 0.124 (3.15) 0.112 (2.85) 0.037 (0.95) 0.033 (0.85) 0.145 (3.69) 0.133 (3.39) 0.014 (0.35) 0.010 (0.25) 0.069 (1.74) 0.057 (1.44) 0.049 (1.25) 0.037 (0.95) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER SR10100L UNITS Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current 100 70 100 V V V See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave 10.0 A 150 A V A superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=125 C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 0.67 100 0.70 0.85 20 370 250 60 to10+150 -55 -55 to +150 mA pF C/W C C Note : 1.FR-4 PCB, 2oz.Copper. 2.Polymide PCB, 2oz.Copper.Cathode pad dimensions 18.8mm x 14.4mm.Anode pad dimensions 5.6mm x 14.4mm. REV 1.0 2017 JAN PAGE:1/2 RATING AND VHARACTERISTIC CURVES(SB10100L) REV 1.0 2017 JAN PAGE:2/2
SB10100L 价格&库存
很抱歉,暂时无法提供与“SB10100L”相匹配的价格&库存,您可以联系我们找货
SB10100L
  • 1+1.20670
库存:2
SB10100L
  • 5+0.98486
  • 50+0.79129
  • 150+0.70834
库存:171
SB10100L
  • 5+1.08536
  • 50+0.87204
  • 150+0.78063
  • 500+0.66658
  • 2500+0.59245
  • 5000+0.56204
库存:2159
