MBRF10150CT
MBRF10150CT
    GOODWORK(固得沃克)
    ITO220AB
    肖特基二极管 VR=150V IF=10A IR=200μA CT=420pF ITO220AB
MBRF10150CT 数据手册
MBRF1020CT THRU MBRF10200CT 10.0 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 20 to 200 Volts CURRENT 10.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * Good for switching mode application ITO-220AB (FULLY INSULATED) .108 (2.75) .248 (6.3) MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Lead solderable per MIL-STD-202, method 208 guranteed * Polarity: As Marked * Mounting position: Any .189 MAX. (4.8) .122 MAX. (3.1) 3.4 f MAX. HOLE THRU .412 (10.5) MAX. .610 (15.5) MAX. .550 (14.0) .158 (4.0) MIN. MAX. .060 MAX. (1.5) .035 MAX. (0.9) .100 (2.54) .114(2.9) .098(2.5) PIN 1 + PIN 1 PIN 3 CASE PIN 2 PIN 3 CASE PIN 2 Negative CT Suffix "A" Positive CT Suffix "C" Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current MBRF1020CT MBRF1045CT MBRF1060CT MBRF1080CT MBRF10100CT MBRF10150CT MBRF10200CT UNITS 20 14 20 45 32 45 60 42 60 80 56 80 at Rated DC Blocking Voltage Ta=100 C Typical Junction Capacitance (Note1) Typical Thermal Resistance R JC (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 150 105 150 200 140 200 0.55 150 0.85 0.2 0.7 50 420 2.5 -65 +150 -65 +150 V V V A 10 at Tc=125 C Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 10A Maximum DC Reverse Current Ta=25 C 100 70 100 0.92 A V mA mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Case. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (MBRF1020 THRU MBRF10200) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 5C T 0 0 20 40 60 80 100 120 140 160 180 200 CASE TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT BR F1 02 00 CT BR F1 01 00 CT RF 10 15 0C TM CT CT 60 20 10 10 RF RF MB -M MB 2 5.0 RF 10 80 CT 4 10 MB 6 MB 8 -M BR F1 04 50 10 INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 12 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 250 .01 200 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 150 8.3ms Single Half Tj=25 C Sine Wave 100 JEDEC method 50 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 1400 1200 1000 800 600 400 10 Tj=100 C 1.0 Tj=75 C .1 Tj=25 C 200 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENT OF RATED PEAK REVERSE VOLTAGE,(%) REV 1.0 2015 JAN PAGE:2/2
MBRF10150CT 价格&库存
很抱歉,暂时无法提供与“MBRF10150CT”相匹配的价格&库存,您可以联系我们找货
MBRF10150CT
  • 5+1.57151
  • 50+1.24492
  • 150+1.10484
  • 500+0.93021
  • 2000+0.85245
  • 5000+0.80568
库存:32
MBRF10150CT
  • 5+1.42600
库存:15
