SR5200-B
SR5200-B
    GOODWORK(固得沃克)
    DO-27(DO-201AA)
    5.0安培肖特基势垒整流器
SR5200-B 数据手册
SR5150 SR5200 THRU 5.0 AMP SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 150 to 200 Volts CURRENT 5.0 Amperes FEATURES * Low forward voltage drop * High current capability * High reliability * High surge current capability * Epitaxial construction DO-27 .220(5.6) .197(5.0) DIA. 1.0(25.4) MIN. MECHANICAL DATA * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Lead: Axial leads, solderable per MIL-STD-202, method 208 guranteed * Polarity: Color band denotes cathode end * Mounting position: Any .375(9.5) .285(7.2) 1.0(25.4) MIN. .052(1.3) .048(1.2) DIA. Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SR5150 SR5200 UNITS 150 105 150 200 140 200 V V V at TL=100 C Peak Forward Surge Current, 8.3 ms single half sine-wave 5.0 A superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 5.0A Maximum DC Reverse Current Ta=25 C 150 A V mA at Rated DC Blocking Voltage Typical Junction Capacitance (Note1) Typical Thermal Resistance R JL(Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 10 380 0.92 0.5 Ta=100 C -65 -65 12 +150 +150 mA PF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead Vertical PC Board Mounting 0.375"(9.5mm) Lead Length. REV 1.0 2015 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SR5150 THRU SR5200) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 50 5.0 4.0 3.0 2.0 1.0 0 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE,( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT INSTANTANEOUS FORWARD CURRENT,(A) AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 6.0 10 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 PEAK FORWARD SURGE CURRENT,(A) 150 .01 120 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 90 8.3ms Single Half Tj=25 C Sine Wave 60 JEDEC method 30 FIG.5 - TYPICAL REVERSE CHARACTERISTICS 0 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 1400 1200 1000 800 600 400 10 Tj=100 C 1.0 .1 Tj=25 C 200 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENTAGE RATED PEAK REVERSE VOLTAGE REV 1.0 2015 JAN PAGE:2/2
SR5200-B
物料型号:SR5150 至 SR5200
器件简介: - 低正向电压降 - 高电流能力 - 高可靠性 - 高浪涌电流能力 - 外延结构
引脚分配: - 封装类型:DO-27 - 引脚:轴向引脚,可焊性符合MIL-STD-202标准 - 极性:色带表示阴极端
参数特性: - 电压范围:150至200伏特 - 最大重复峰值反向电压:SR5150为150V,SR5200为200V - 最大RMS电压:SR5150为105V,SR5200为140V - 最大直流阻断电压:SR5150为150V,SR5200为200V - 最大平均正向整流电流:在100°C时为5.0A - 正向浪涌电流:在8.3毫秒单半正弦波形下,叠加在额定负载上(JEDEC方法)为150A - 最大瞬时正向电压在5.0A时:SR5150为0.92V - 最大直流反向电流:在25°C时为0.5mA,在100°C时为10mA - 典型结电容:380pF(在1MHz和4.0V反向电压下测量) - 典型热阻RJL:12°C/W(垂直PC板安装,0.375英寸(9.5mm)引脚长度)
功能详解: - 正向电流降额曲线 - 最大非重复正向浪涌电流特性 - 典型反向漏电流特性 - 典型结电容特性
应用信息: - 适用于单相半波,60Hz,电阻性或感性负载 - 对于电容性负载,电流需降低20%
封装信息: - 封装类型:模塑塑料 - 环氧树脂:UL 94V-0级阻燃 - 安装位置:任意
SR5200-B 价格&库存
很抱歉,暂时无法提供与“SR5200-B”相匹配的价格&库存,您可以联系我们找货
SR5200-B
  • 5+0.64556
库存:30
SR5200-B
  • 5+0.71143
  • 50+0.57200
  • 150+0.50233
  • 1200+0.40425
  • 2400+0.36239
  • 4800+0.34146
库存:10
