SS24BF
SS24BF
    GOODWORK(固得沃克)
    SMBF
    表面安装肖特基势垒整流器,电压范围20至100伏电流2.0安培
SS24BF 数据手册
SS22BF SS210BF THRU 2.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 20 to 100 Volts CURRENT 2.0 Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop SMBF .173(4.4) .165(4.2) .086(2.2) .075(1.9) MECHANICAL DATA .216(5.5) .200(5.1) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any .010(0.26) .007(0.18) .051(1.30) .043(1.10) .146(3.7) .138(3.5) .051(1.3) .039(1.0) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SS22BF SS23BF 20 14 20 30 21 30 SS24BF 40 28 40 SS25BF SS26BF SS28BF SS29BF SS210BF UNITS 50 35 50 See Fig. 1 Peak Forward Surge Current, 8.3 ms single half sine-wave 80 56 80 90 63 90 50 0.70 0.2 0.55 0.85 20 170 Ta=100 C 75 -65 +125 -65 -65 +150 100 70 100 V V V A 2.0 superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 2.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Typical Junction Capacitance (Note1) Typical Thermal Resistance RqJA (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG 60 42 60 +150 A V mA mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Ambient. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SS22BF THRU SS210BF) FIG.2-TYPICAL FORWARD FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE BF F 20 40 60 80 100 120 140 160 180 200 AMBIENT TEMPERATURE ( C) PEAK FORWAARD SURGE CURRENT,(A) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT BF 26 22 BF ~S S BF ~S S 10 4B 0 3.0 F 25 2 SS F~ 2 SS F~ 0.4 SS 5B 2B 0.8 10 SS 2 SS 1.2 INSTANTANEOUS FORWARD CURRENT,(A) 1.6 24 BF 50 2.0 2 SS AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 2.4 S ~S BF SS 1.0 21 0B 28 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 50 .01 40 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 30 8.3ms Single Half Tj=25 C Sine Wave 20 JEDEC method 10 FIG.5 - TYPICAL REVERSE 0 CHARACTERISTICS 1 5 50 10 100 100 NUMBER OF CYCLES AT 60Hz REVERSE LEAKAGE CURRENT, (mA) FIG.4-TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE,(pF) 350 300 250 200 150 100 10 1.0 Tj=75 C .1 Tj=25 C 50 0 .01 .05 .1 .5 1 REVERSE VOLTAGE,(V) 5 10 50 100 .01 0 20 40 60 80 100 120 140 PERCENTAGE RATED PEAK REVERSE VOLTAGE REV 1.0 2017 JAN PAGE:2/2
SS24BF 价格&库存
很抱歉,暂时无法提供与“SS24BF”相匹配的价格&库存,您可以联系我们找货
SS24BF
库存:30
SS24BF
  • 20+0.10493
  • 200+0.08160
  • 600+0.06864
  • 5000+0.05622
  • 10000+0.04947
  • 20000+0.04580
库存:1385
