MB24F
MB24F
    GOODWORK(固得沃克)
    DBS-4.7X3.8MM_SM
    桥式整流器/整流桥 VR=40V IR=0.3mA VF=0.55V MBF
MB24F 数据手册
B THRU MB220F MB22F SINGLE PHASE 1.0 AMP SURFACE MOUNT BRIDGE RECTIFIERS VOLTAGE RANGE 20 to 200 Volts CURRENT 1.0 Ampere MBF FEATURES * Ideal for printed circuit board * Reliable low cost construction utilizing molded plastic technique * High surge current capability + ~ * Polarity: Symbol molded on body * Mounting position: Any .027(0.7) .157(4.0) .019(0.5) .141(3.6) 2.75(7.0) MAX. .014(.35) .006(.15) ~ .043(1.1) .008(0.2) .027(0.7) MAX. .031(0.8) .023(0.6) * Weight: 0.12 grams .193(4.9) .177(4.5) .055(1.4) .051(1.3) .066(1.7) MAX. .106(2.7) .090(2.3) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current MB22F MB24F MB26F MB28F MB210F MB215FMB220F UNIT 20 14 20 40 28 40 60 42 60 80 56 80 at Ta=40 C(Note 1) Peak Forward Surge Current, 8.3 ms single half sine-wave superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 2.0A D.C. Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Ta=125 C Typical Thermal Resistance RqJA (Note 2) Operating Temperature Range, TJ Storage Temperature Range, TSTG 100 70 100 150 105 150 200 140 200 2.0 A 50 0.55 0.7 0.3 10 0.85 0.9 0.2 0 .1 5 2 100 -55 +150 -55 V V V +150 A V mA m mA m C/W C C NOTES: 1. Mounted on P.C. Board. 2. Thermal Resistance Junction to Ambient. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (MB22F THRU MB220F) Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 10 3 T J =100°C 10 2 T J =75°C 10 1 T J =25°C 10 0 0 Case Temperature (°C) 100 80 Fig.4 Typical Junction Capacitance 500 T J =25°C 20 Junction Capacitance ( pF) Instaneous Forward Current (A) 60 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 10 1.0 MB22F-MB24F MB26F MB28F/MB220F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 200 100 50 MB22F -MB24F 20 MB26F-MB220F 10 50 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance( °C /W) 60 1 100 10 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 10 1 0.1 1.8 Instaneous Forward Voltage (V) Peak Forward Surage Current (A) 40 20 Fig.6- Typical Transient Thermal Impedance 1000 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) REV 1.0 2017 JAN PAGE:2/2
MB24F 价格&库存
很抱歉,暂时无法提供与“MB24F”相匹配的价格&库存,您可以联系我们找货
MB24F
  • 5+0.77720
库存:30
