MB10S-A
MB10S-A
    GOODWORK(固得沃克)
    DBS-4.7X3.8MM_SM
    单相1.0安培表面安装桥式整流器 VR=1KV IR=5μA MBS
MB10S-A 数据手册
B THRU MB10S MB05S SINGLE PHASE 1.0 AMP SURFACE MOUNT BRIDGE RECTIFIERS VOLTAGE RANGE 50 to 1000 Volts CURRENT 1.0 Ampere MBS FEATURES * Ideal for printed circuit board * Reliable low cost construction utilizing molded plastic technique * High surge current capability + ~ * Polarity: Symbol molded on body * Mounting position: Any .051(1.3) .157(4.0) .035(0.9) .141(3.6) 2.75(7.0) MAX. .014(.35) .006(.15) ~ .043(1.1) .008(0.2) .027(0.7) MAX. .031(0.8) .023(0.6) * Weight: 0.12 grams .193(4.9) .177(4.5) .106(2.7) .090(2.3) .118(3.0) MAX. .106(2.7) .090(2.3) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current MB05S MB1S MB2S MB4S MB6S 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 MB8S MB10S UNIT 800 560 800 1000 700 1000 V V V at Ta=40 C(Note 1) Peak Forward Surge Current, 8.3 ms single half sine-wave 1.0 A superimposed on rated load (JEDEC method) Maximum Forward Voltage Drop per Bridge Element at 0.5A D.C. Maximum DC Reverse Current Ta=25 C 30 1.0 5.0 A V at Rated DC Blocking Voltage Ta=125 C Typical Thermal Resistance RqJA (Note 2) Operating Temperature Range, TJ Storage Temperature Range, TSTG 500 75 -55 +150 -55 +150 μA μA m C/W C C NOTES: 1. Mounted on P.C. Board. 2. Thermal Resistance Junction to Ambient. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (MB05S THRU MB10S) FIG.2-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 1.2 1.0 0.8 0.6 Single Phase Half Wave 60Hz 0.4 Resistive Or Inductive Load 0.2 0 25 50 75 100 125 150 175 AMBIENT TEMPERATURE ( C) PEAK FORWAARD SURGE CURRENT,(A) AVERAGE FORWARD CURRENT,(A) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE 50 40 30 8.3ms Single Half Tj=25 C Sine Wave 20 JEDEC method 10 0 1 5 50 10 100 NUMBER OF CYCLES AT 60Hz FIG.3-TYPICAL FORWARD FIG.4-TYPICAL REVERSE CHARACTERISTICS CHARACTERISTICS 50 T J =125°C 10 REVERSE LEAKAGE CURRENT, (mA) INSTANTANEOUS FORWARD CURRENT,(A) 50 3.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 10 3.0 1.0 0.1 Tj=25 C .01 0 .2 .4 .6 .8 1.0 FORWARD VOLTAGE,(V) 1.2 1.4 .01 20 40 60 80 100 120 140 PERCENTAGE OF PEAK REVERSE VOLTAGE, (%) REV 1.0 2017 JAN PAGE:2/2
MB10S-A 价格&库存
很抱歉,暂时无法提供与“MB10S-A”相匹配的价格&库存,您可以联系我们找货
MB10S-A
库存:30
