SS56-SMB
SS56-SMB
    GOODWORK(固得沃克)
    SMB(DO-214AA)
    5.0安培表面安装肖特基势垒整流器
SS56-SMB 数据手册
SS510 SS52 THRU 5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS VOLTAGE RANGE 20 to 100 Volts CURRENT 5.0 Ampere FEATURES * Ideal for surface mount applications * Easy pick and place * Built-in strain relief * Low forward voltage drop DO-214AA(SMB) .155(3.94) .130(3.30) .083(2.11) .075(1.91) MECHANICAL DATA .185(4.70) .160(4.06) * Case: Molded plastic * Epoxy: UL 94V-0 rate flame retardant * Metallurgically bonded construction * Polarity: Color band denotes cathode end * Mounting position: Any * Weight: 0.093 grams .012(0.31) .006(0.15) .096(2.44) .083(2.13) .008 MAX. (.203) .220(5.59) .200(5.08) .050(1.27) .030(0.76) Dimensions in inches and (millimeters) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Rating 25 C ambient temperature uniess otherwies specified. Single phase half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%. TYPE NUMBER Maximum Recurrent Peak Reverse Voltage Maximum RMS Voltage Maximum DC Blocking Voltage Maximum Average Forward Rectified Current SS52 SS53 SS54 SS55 SS56 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 at TL=90 C Peak Forward Surge Current, 8.3 ms single half sine-wave SS59 SS510 80 56 80 90 63 90 100 70 100 120 0.55 0.85 0.70 0.2 20 380 Ta=100 C 16 -65 +125 -65 -65 +150 UNITS V V V A 5.0 superimposed on rated load (JEDEC method) Maximum Instantaneous Forward Voltage at 5.0A Maximum DC Reverse Current Ta=25 C at Rated DC Blocking Voltage Typical Junction Capacitance (Note1) Typical Thermal Resistance RqJL (Note 2) Operating Temperature Range TJ Storage Temperature Range TSTG SS58 +150 A V mA mA pF C/W C C NOTES: 1. Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2. Thermal Resistance Junction to Lead. REV 1.0 2017 JAN PAGE:1/2 RATING AND CHARACTERISTIC CURVES (SS52 THRU SS510) FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE FIG.2-TYPICAL FORWARD 0 20 40 60 80 100 120 140 160 180 200 LEAD TEMPERATURE ( C) FIG.3-MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT S5 SS 5 8 ~ SS 5 10 6 ~S ~S S5 2 3.0 5 10 S5 -S 4 1.0 SS 5 55 S5 -S 2.0 10 SS 5 SS 52 3.0 INSTANTANEOUS FORWARD CURRENT,(A) 4.0 4 50 5.0 SS AVERAGE FORWARD CURRENT,(A) CHARACTERISTICS 6.0 1.0 Tj=25 C Pulse Width 300us 1% Duty Cycle 0.1 .01 120 .1 .3 .5 .7 .9 1.1 1.3 1.5 FORWARD VOLTAGE,(V) 90 Tj=25 C 8.3ms Single Half Sine Wave 60 JEDEC method 30 FIG.5 - TYPICAL REVERSE 0 CHARACTERISTICS 1 5 10 50 100 100 NUMBER OF CYCLES AT 60Hz FIG.4-TYPICAL JUNCTION CAPACITANCE REVERSE LEAKAGE CURRENT, (mA) PEAK FORWARD SURGE CURRENT,(A) 150 10 1.0 Tj=75 C .1 Tj=25 C .01 0 20 40 60 80 100 120 140 PERCENTAGE RATED PEAK REVERSE VOLTAGE REV 1.0 2017 JAN PAGE:2/2
SS56-SMB 价格&库存
很抱歉,暂时无法提供与“SS56-SMB”相匹配的价格&库存,您可以联系我们找货
SS56-SMB
  • 10+0.35192
  • 100+0.28790
  • 300+0.25589
  • 3000+0.21412
  • 6000+0.19494
  • 12000+0.18530
库存:4871
SS56-SMB
  • 10+0.29694
