SS52
SS510
THRU
5.0 AMP SURFACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
5.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
DO-214AB(SMC)
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
MECHANICAL DATA
.280(7.11)
.260(6.60)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
.012(0.31)
.006(0.15)
.103(2.62)
.079(2.00)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SS52
SS53
21
30
SS54
40
28
40
SS55
SS56
SS58
SS59
SS510
UNITS
50
35
50
60
42
60
80
56
80
90
63
90
100
70
100
V
V
V
at TL=90 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
150
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 5.0A
Maximum DC Reverse Current
Ta=25 C
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
A
5.0
0.55
0.85
0.70
0.2
Ta=100 C
10
-65
+125
-65
-65
+150
+150
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SS52 THRU SS510)
FIG.2-TYPICAL FORWARD
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
60
80
100
120
140
160
180
200
LEAD TEMPERATURE ( C)
FIG.3-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
~S
S
51
~S
S
~S
S
52
3.0
55
58
SS
10
S5
-S
4
1.0
SS
55
S5
-S
2.0
10
SS
SS
52
3.0
INSTANTANEOUS FORWARD CURRENT,(A)
4.0
54
50
5.0
SS
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
6.0
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
PEAK FORWARD SURGE CURRENT,(A)
250
.01
200
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
150
8.3ms Single Half
Tj=25 C
Sine Wave
100
JEDEC method
50
FIG.5 - TYPICAL REVERSE
CHARACTERISTICS
1
5
50
10
100
100
NUMBER OF CYCLES AT 60Hz
REVERSE LEAKAGE CURRENT, (mA)
FIG.4-TYPICAL JUNCTION CAPACITANCE
JUNCTION CAPACITANCE,(pF)
700
600
500
400
300
200
10
1.0
Tj=75 C
.1
Tj=25 C
100
.05
.1
.5
1
REVERSE VOLTAGE,(V)
5
10
50
100
.01
60
80
100 120 140
PERCENTAGE RATED PEAK REVERSE VOLTAGE
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SS54-SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.32222
- 100+0.26163
- 600+0.23133
- 1200+0.22786
- 国内价格
- 10+0.35151
- 100+0.28542
- 300+0.25237
- 3000+0.20821
- 6000+0.18838
- 12000+0.17837
- 国内价格
- 1+0.34320
- 200+0.22110
- 1500+0.19250
- 3000+0.17050
