SK82
SK810
THRU
8.0 AMP SURF ACE MOUNT SCHOTTKY BARRIER RECTIFIERS
VOLTAGE RANGE
20 to 100 Volts
CURRENT
8.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Low forward voltage drop
DO-214AB(SMC)
.245(6.22)
.220(5.59)
.124(3.15)
.108(2.75)
MECHANICAL DATA
.280(7.11)
.260(6.60)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.21 grams
.012(0.31)
.006(0.15)
.103(2.62)
.079(2.00)
.008
MAX.
(.203)
.320(8.13)
.305(7.75)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SK82
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
SK83
SK84
SK85
SK86
SK88
SK89
40
28
40
50
35
50
60
42
60
80
56
80
90
63
90
30
21
30
at TL=90 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
175
at Rated DC Blocking Voltage
Typical Junction Capacitance (Note1)
Typical Thermal Resistance RqJL (Note 2)
Operating Temperature Range TJ
Storage Temperature Range TSTG
0.55
0.85
0.70
0.2
Ta=100 C
10
-65
+125
-65
-65
+150
UNITS
100
70
100
V
V
V
A
8.0
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 8.0A
Maximum DC Reverse Current
Ta=25 C
SK810
+150
A
V
mA
mA
pF
C/W
C
C
NOTES:
1. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2. Thermal Resistance Junction to Lead.
REV 1.0 2017 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (SK82 THRU SK810)
Fig.2 - MAXIMUMNON-REPETITIVEPEAK
FORWARD SURGECURRENT
5.0
4.0
SK
85
82
3.0
K8
-S
4
10
K8
-S
2.0
1.0
60
80
100
120
140
160
180
200
PEAK FORWARDSURGE CURRENT,
AMPERES
6.0
SK
200
175
140
105
70
35
10
LEAD TEMPERATURE ( C)
100
NO. OF CYCLE AT 60Hz
FIG.3-TYPICAL FORWARD
CHARACTERISTICS
FIG.4-TYPICAL JUNCTION CAPACITANCE
50
4
JUNCTION CAPACITANCE,(pF)
2800
K8
10
-S
SK
88
-S
3.0
85
SK
82
K8
6
-S
K8
10
SK
INSTANTANEOUS FORWARD CURRENT,(A)
AVERAGE FORWARD CURRENT,(A)
FIG.1-TYPICAL FORWARD CURRENT DERATING CURVE
1.0
Tj=25 C
Pulse Width 300us
1% Duty Cycle
0.1
2400
2000
1600
SK
82
~S
K8
1200
800
SK 8
4
5 ~S
K8
10
400
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
.01
.1
.3
.5
.7
.9
1.1
1.3
1.5
FORWARD VOLTAGE,(V)
REV 1.0 2017 JAN
PAGE:2/2
很抱歉,暂时无法提供与“SK86-SMC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.83568
- 50+0.67809
- 150+0.59930
- 500+0.54020
- 3000+0.46693
- 6000+0.44324
