RS3A
RS3M
THRU
3.0 AMP SURFACE MOUNT FAST RECOVERY RECTIFIERS
VOLTAGE RANGE
50 to 1000 Volts
CURRENT
3.0 Ampere
FEATURES
* Ideal for surface mount applications
* Easy pick and place
* Built-in strain relief
* Fast switching speed
DO-214AA(SMB)
.155(3.94)
.130(3.30)
.083(2.11)
.075(1.91)
MECHANICAL DATA
.185(4.70)
.160(4.06)
* Case: Molded plastic
* Epoxy: UL 94V-0 rate flame retardant
* Metallurgically bonded construction
* Polarity: Color band denotes cathode end
* Mounting position: Any
* Weight: 0.093 grams
.012(0.31)
.006(0.15)
.096(2.44)
.083(2.13)
.008
MAX.
(.203)
.220(5.59)
.200(5.08)
.050(1.27)
.030(0.76)
Dimensions in inches and (millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Rating 25 C ambient temperature uniess otherwies specified.
Single phase half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
RS3A RS3B RS3D RS3G RS3J RS3K RS3M
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
at Ta=55 C
Peak Forward Surge Current, 8.3 ms single half sine-wave
3.0
A
superimposed on rated load (JEDEC method)
Maximum Instantaneous Forward Voltage at 3.0A
Maximum DC Reverse Current
Ta=25 C
125
1.3
5.0
A
V
mA
at Rated DC Blocking Voltage
Ta=125 C
Maximum Reverse Recovery Time (Note 1)
Typical Junction Capacitance (Note 2)
Operating and Storage Temperature Range TJ, TSTG
200
250
150
-65
60
+150
500
mA
nS
pF
C
NOTES:
1. Reverse Recovery Time test condition: IF=0.5A, IR=1.0A, IRR=0.25A
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
REV 1.0 2015 JAN
PAGE:1/2
RATING AND CHARACTERISTIC CURVES (RS3A THRU RS3M)
FIG.1-TYPICAL FORWARD
FIG.2-TYPICAL FORWARD CURRENT DERATING CURVE
AVERAGE FORWARD CURRENT,(A)
CHARACTERISTICS
10
3.0
1.0
3.0
2.5
2.0
Single Phase
1.5
Half Wave 60Hz
Resistive Or Inductive Load
1.0
0.5
Tj=25 C
60
80
100
120
140
160
180
200
AMBIENT TEMPERATURE ( C)
Pulse Width 300us
1% Duty Cycle
0.1
FIG.4-MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
.6
.8
1.0
1.2
1.4
1.6
1.8
2.0
FORWARD VOLTAGE,(V)
FIG.3- TEST CIRCUIT DIAGRAM AND REVERSE
RECOVERY TIME CHARACTERISTICS
50W
NONINDUCTIVE
10W
NONINDUCTIVE
D.U.T.
25Vdc
(approx.)
PULSE
GENERATOR
(NOTE 2)
PEAK FORWARD SURGE CURRENT,(A)
125
.01
100
75
Sine Wave
50
JEDEC method
25
5
2. Rise Time= 10ns max., Source Impedance= 50 ohms.
-0.25A
100
FIG.5-TYPICAL JUNCTION CAPACITANCE
NOTES: 1. Rise Time= 7ns max., Input Impedance= 1 megohm.22pF.
+0.5A
50
10
NUMBER OF CYCLES AT 60Hz
OSCILLISCOPE
(NOTE 1)
trr
8.3ms Single Half
Tj=25 C
1W
NONINDUCTIVE
140
JUNCTION CAPACITANCE,(pF)
INSTANTANEOUS FORWARD CURRENT,(A)
50
120
100
80
60
40
-1.0A
1cm
SET TIME BASE FOR
.01
.05
.1
.5
1
5
10
50
100
REVERSE VOLTAGE,(V)
50 / 10ns / cm
REV 1.0 2015 JAN
PAGE:2/2
很抱歉,暂时无法提供与“RS3M-SMB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15263
- 300+0.12376
- 1200+0.10772
- 3000+0.08607
- 国内价格
- 20+0.16651
- 200+0.13501
- 600+0.11752
- 3000+0.09390
- 12000+0.08476
- 18000+0.07981
- 国内价格
- 1+0.42350
- 200+0.14190
- 1500+0.08833
- 3000+0.07018
