www.msksemi.com
SOD4001-MS THRU SOD4007-MS
Semiconductor
FEATURES
Compiance
MECHANICAL DATA
Glass passivated device
Ideal for surface mouted applications
Low reverse leakage
Metallurgically bonded construction
High temperature soldering guaranteed:
250 C/10 seconds,0.375”(9.5mm) lead length,
5 lbs. (2.3kg) tension
Case: JEDEC SOD-123FL molded plastic body over passivated chip
Terminals: Solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.0007 ounce, 0.02 grams
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
P/N
SOD4001 SOD4002 SOD4003 SOD4004 SOD4005 SOD4006 SOD4007 UNITS
-MS
-MS
-MS
-MS
-MS
-MS
-MS
A3
A5
A6
A7
VRRM
A1
1
A2
Maximum repetitive peak reverse voltage
50
100
200
400
600
800
1000
VOLTS
Maximum RMS voltage
VRMS
35
70
140
280
420
560
700
VOLTS
Maximum DC blocking voltage
VDC
50
100
200
400
600
800
1000
VOLTS
MARK
Maximum average forward rectified current
I(AV)
at TA=65 C (NOTE 1)
Peak forward surge current
IFSM
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method) TL=25 C
VF
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
IR
at rated DC blocking voltage
TA=125 C
Typical junction capacitance (NOTE 2)
CJ
Typical thermal resistance (NOTE 3)
RJA
Operating junction and storage temperature range TJ,TSTG
A4
1.0
Amp
25.0
Amps
1.0
Volts
10.0
50.0
A
4
180
-55 to
+150
pF
K/W
C
Note: 1.Averaged over any 20ms period.
2. Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3. Thermal resistance from junction to ambient at 0.375” (9.5mm)lead length,P.C.B. mounted
www.msksemi.com
Semiconductor
FIG.2-- TYPICALJUNCTIONCAPACITANCE
1000
10
TJ = 150°C
CAPACITANCE, pF
9
TJ = 25°C
m AMPERES
INSTANTANEOUS FORWARDCURRENT
FIG.1 --TYPICALFORWARDCHARACTERISTIC
TJ = 100°C
8
7
6
5
4
3
2
1
100
600
700
800
900
1000
INSTANTANEOUSFORWARDVOLTAGE,mV
TJ = 150C
10
TJ = 125C
TJ =100C
1
TJ = 75C
TJ =50C
0.1
TJ =25C
0.01
400 500 600 700 800 900
INSTANTANEOUSREVERSEVOLTAGE,V
5
10
15
30
35
40
FIG.4 -- FORWARDDERATINGCURVE
AVERAGE FORWARD CURRENT,
AMPERES
100
REVERSEVOLTAGE,VOLTS
FIG.3 --TYPICAL INSTANTANEOUS
REVERSE CHARACTERISTICS
AMPERES
INSTANTANEOUS REVERSECURRENT
Compiance
1.2
Resistive or Inductive Load
1.0
0.8
0.6
0.4
0.2
3.0 x 3.0mm 40 µm
Thick Copper Pad Areas
60
80
100 120 140 160
AMBIENT TEMPERATEU,R
www.msksemi.com
Semiconductor
Compiance
1.8± 0.3
0.95 ±0.25
PACKAGE MECHANICAL DATA
1.15±0.25
0.05-0.30
2.75 ±0.25
0.6±0.3
3.7 ±0.30
Dimensions in millimeters
1.4
2.85
1.2
REEL SPECIFICATION
P/N
PKG
SOD-123FL
QTY
3000
www.msksemi.com
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as
life-support
systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations,
products must not be exported without obtaining the export license from
theauthorities
such
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“SOD4007-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.04550
- 1000+0.03620
- 3000+0.02730
- 9000+0.02410
- 51000+0.02150
- 99000+0.02020
- 国内价格
- 100+0.02600
- 1000+0.02127
- 3000+0.01773
- 9000+0.01513
- 30000+0.01465
- 国内价格
- 1+0.09724
- 200+0.03245
- 1500+0.02024
- 3000+0.01606
- 国内价格
- 100+0.04871
- 1000+0.03932
- 3000+0.02970
- 9000+0.02657
- 51000+0.02387
- 99000+0.02236
