SP0503BAHTG
SP0503BAHTG
    MSKSEMI(美森科)
    SOT-143
    SOT143 VC:15V 30pF
SP0503BAHTG 数据手册
www.msksemi.com SP0503BAHTG Semiconductor Compiance Features ● ● ● ● ● Ultra low leakage: nA level Operating voltage: 5V Low clamping voltage Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±15kV Contact discharge: ±8kV – IEC61000-4-4 (EFT) 40A (5/50ns) – IEC61000-4-5 (Lightning) 10A RoHS Compliant (8/20μs) Applications ● ● ● ● ● SOT-143 ● USB 2.0 power and data line Set-top box and digital TV Digital video interface (DVI) Notebook Computers SIM Ports 10/100 Ethernet Mechanical Characteristics ● Package: SOT-143 ● Lead Finish: Lead Free ● UL Flammability Classification Rating 94V-0 ● Quantity Per Reel:3,000pcs ● Reel Size:7inch Absolute Maximum Ratings(Tamb=25°C unless otherwise specified) Parameter Peak Pulse Power (8/20µs) ESD per IEC 61000−4−2 (Air) Symbol Ppp Value Unit 150 W ±15 VESD Kv ±8 ESD per IEC 61000−4−2 (Contact) Operating Temperature Range TJ -55 to +125 ℃ Storage Temperature Range TSTJ -55 to +150 ℃ www.msksemi.com SP0503BAHTG Semiconductor Compiance Electrical Characteristics(TA=25°C unless otherwise specified) Vc P/N Marking VRWM (V) VBR (V) IT (mA) VC @1A 503B 5 6 1 10 SP0503BAHTG (Max) (@A) IR μA (Max) C (Pf) (Typ.) 1 30 10 15 Characteristic Curves Fig2. ESD Pulse Waveform (according to IEC 61000-4-2) Fig1. 8/20µ s Pulse Waveform 120 IPP - Peak Pulse Current - % of IPP 100 100% TEST WAVEFORM PARAMETERS tr=8 s td=20 s Peak Value IPP 80 Percent of Peak Pulse Current % tr 60 40 td=t IPP/5 20 0 0 5 10 15 20 25 30 10% tr = 0.7~1ns Time (ns) 30ns 60ns t - Time ( s) Fig3. 90% Power Derating Curve % of Rated Power 110 100 90 80 70 60 50 40 30 20 10 0 0 25 50 75 100 125 150 Ambient Temperature –TA (ºC) www.msksemi.com SP0503BAHTG Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol θ Inches Min. Millimeters Nom. Max. Min. Nom. Max. A 0.031 - 0.048 0.80 - 1.22 A1 0.000 - 0.008 0.013 - 0.15 A2 0.020 0.035 0.042 0.75 0.90 1.07 b 0.011 - 0.020 0.30 - 0.51 b1 0.029 - 0.037 0.76 - 0.94 c 0.003 - 0.008 0.08 - 0.20 D 0.110 0.114 0.120 2.80 2.90 3.04 E 0.082 0.093 0.104 2.10 2.37 2.64 E1 0.047 0.051 0.055 1.20 1.30 1.40 e 0.075 e1 L 0.008 0.015 L1 0.020 0.20 BSC 0.024 0.40 (0.021) N θ 1.92 BSC - 0.60 (0.54) 4 0° 0.50 4 8° 0° - aaa 0.006 0.15 bbb 0.008 0.20 ccc 0.004 0.10 8° REEL SPECIFICATION P/N SP0503BAHTG PKG SOT-143 QTY 3000 www.msksemi.com SP0503BAHTG Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
SP0503BAHTG 价格&库存
很抱歉,暂时无法提供与“SP0503BAHTG”相匹配的价格&库存,您可以联系我们找货
