ESD9L5.0ST5G-MS
ESD9L5.0ST5G-MS
    MSKSEMI(美森科)
    SOD-882
    SOD882 VC:12.9V 0.9pF
ESD9L5.0ST5G-MS 数据手册
www.msksemi.com ESD9L5.0ST5G-MS Semiconductor Compiance Features  Small Body Outline Dimensions: 0.039″x 0.024″(1.0 mm x 0.60 mm)  Protects one I/O or power line  Low Clamping Voltage  Ultra Low Capacitance:0.9pF  Working Voltage: 5 V  Low Leakage Current  Response Time is Typically < 1 ns SOD-882 IEC COMPATIBILITY (EN61000-4)  IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact)  IEC 61000-4-4 (EFT) 40A (5/50ns) Mechanical Characteristics Applications   DFN1006  Laptop Computers Molding compound flammability rating:  Cellular Phones UL 94V-0  Digital Cameras  Marking: Marking Code  Personal Digital Assistants (PDAs)  Packaging: Tape and Reel per EIA 481  RoHS/WEEE Compliant ELECTRICAL CHARACTERISTICS (TA = 25C unless otherwise noted) P/N ESD9L5.0ST5G-MS C (pF) VC (V) @ IPP = 1 A (Note 3) VC mA Max Max Per IEC61000−4−2 (Note 4) 1.0 0.9 12.9 VRWM (V) IR (µA) @ VRWM VBR (V) @ IT (Note 2) IT Max Max Min 5.0 1.0 5.4 Figures 1 and 2 See Below 2. VBR is measured with a pulse test current IT at an ambient temperature of 25C. 3. Surge current waveform per Figure 4. 4. For test procedure see Figures 3. www.msksemi.com ESD9L5.0ST5G-MS Semiconductor Compiance ELECTRICAL CHARACTERISTICS (TA = 25C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR I Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM Breakdown Voltage @ IT IT Test Current IF Forward Current VF Forward Voltage @ IF Ppk Peak Power Dissipation C IPP IT VC VBR VRWM IR IR VRWM VBR VC IT V IPP Bi−Directional TVS Capacitance @ VR = 0 and f = 1.0 MHz Figure 1. ESD Clamping Voltage Screenshot Positive 8 kV Contact per IEC61000−4−2 Figure 2. ESD Clamping Voltage Screenshot Negative 8 kV Contact per IEC61000−4−2 www.msksemi.com ESD9L5.0ST5G-MS Semiconductor IEC 61000−4−2 Spec. Ipeak Level Test Voltage (kV) First Peak Current (A) Current at 30 ns (A) Current at 60 ns (A) 1 2 7.5 4 2 2 4 15 8 4 3 6 22.5 12 6 4 8 30 16 8 Compiance IEC61000−4−2 Waveform 100% 90% I @ 30 ns I @ 60 ns 10% tP = 0.7 ns to 1 ns % OF PEAK PULSE CURRENT 100 tr 90 PEAK VALUE IRSM @ 8 µs PULSEWIDTH(tP) ISDEFINED ASTHATPOINT WHERETHE PEAK CURRENT DECAY= 8 µs 80 70 60 HALF VALUE IRSM /2 @ 20 µs 50 40 30 tP 20 10 0 0 20 40 t, TIME (µs) 60 80 Figure 4. 8 X 20 µs Pulse Waveform www.msksemi.com ESD9L5.0ST5G-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 D E D1 E1 b e e1 L1 L2 Dimensions In Millimeters Min. Max. 0.450 0.550 0.010 0.090 0.950 1.050 0.550 0.650 0.390REF. 0.400 0.500 0.420REF. 0.580 0.680 0.360REF. 0.050REF. 0.270 0.370 Dimensions In Inches Min. Max. 0.018 0.022 0.000 0.004 0.037 0.041 0.022 0.026 0.015REF. 0.016 0.020 0.017REF. 0.023 0.027 0.014REF. 0.002REF. 0.011 0.015 REEL SPECIFICATION P/N ESD9L5.0ST5G-MS PKG QTY SOD-882 10000 www.msksemi.com ESD9L5.0ST5G-MS Semiconductor Compiance PACKAGE MECHANICAL DATA A Dim B C R D E MIN Millimeters MAX MIN MAX A 0.0125 0.02 0.32 0.52 B 0.000 0.002 0.00 0.05 C 0.037 0.043 0.95 1.080 D 0.022 0.027 0.55 0.680 E 0.016 0.024 0.40 0.60 F 0.008 0.012 0.20 0.30 H R F Inches 0.015Typ. 0.001 0.40Typ. 0.005 0.05 0.15 H 1.20 0.50 0.60 0.70 NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. REEL SPECIFICATION P/N ESD9L5.0ST5G-MS PKG SOD-882 QTY 10000 www.msksemi.com ESD9L5.0ST5G-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
ESD9L5.0ST5G-MS 价格&库存
很抱歉,暂时无法提供与“ESD9L5.0ST5G-MS”相匹配的价格&库存,您可以联系我们找货
