RCLAMP0521P.TCT
RCLAMP0521P.TCT
    MSKSEMI(美森科)
    0402 VC:25V 0.25pF
RCLAMP0521P.TCT 数据手册
www.msksemi.com RCLAMP0521P.TCT Semiconductor Compiance Features PIN CONFIGURATION ■ 100Watts peak pulse power (tp = 8/20μs) ■ Tiny DFN1006 package ■ Bidirectional configurations ■ Solid-state silicon-avalanche technology ■ Low clamping voltage ■ Low leakage current ■ Low capacitance (Cj=0.25pF typ. IO to IO) ■ Protection one data/power line to: ■ IEC 61000-4-2 ±20kV contact ±20kV air ■ IEC 61000-4-4 (EFT) 40A (5/50ns) ■ IEC 61000-4-5 (Lightning) 4A (8/20μs) Applications 0402 ■ Cell Phone Handsets and Accessories ■ Microprocessor based equipment ■ Personal Digital Assistants (PDA’s) ■ Notebooks, Desktops, and Servers ■ Portable Instrumentation Mechanical Data ■ 0402 ■ Molding compound flammability rating: UL 94V-0 ■ Packaging: Tape and Reel ■ RoHS/WEEE Compliant Electrical Parameters (TA = 25°C unless otherwise noted) Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR VBR IT I IPP Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM VC VBR VRWM IT IR I IT R VRWM VBR VC V Breakdown Voltage @ IT Test Current IPP Note:. 8/20μs pulse waveform. www.msksemi.com RCLAMP0521P.TCT Semiconductor Compiance Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power ( tp =8/20μs ) PPP 100 Watts Peak Pulse Current ( tp =8/20μs ) (note1) Ipp 4.0 A VESD 20 20 kV Lead Soldering Temperature TL 260(10seconds) ℃ Junction Temperature TJ -55 to + 125 ℃ Storage Temperature Tstg -55 to + 125 ℃ ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Electrical Characteristics Parameter Reverse Stand-Off Voltage Reverse Breakdown Voltage Symbol Conditions Min Typical VRWM VBR IT=1mA Reverse Leakage Current IR VRWM=5V,T=25℃ Peak Pulse Current IPP tp =8/20μs Clamping Voltage VC IPP=4A,tp=8/20μs Junction Capacitance Cj IO to IO VR = 0V, f = 1MHz Max Units 5.0 V 6.0 V 0.25 100 nA 4.0 A 25 V 0.4 pF www.msksemi.com RCLAMP0521P.TCT Semiconductor Typical Characteristics Figure 2: Power Derating Curve 110 10 Percent of Rated Power for Ipp Ppp – Peak Pulse Power - Ppp(KW) Figure 1: Peak Pulse Power vs. Pulse Time 1 100w 8/20µswaveform 0.1 0.01 0.1 1 10 90 80 70 60 50 40 30 20 10 0 1,000 100 100 0 25 td – Pulse Duration - µs 80 Ipp 125 150 26 Clamping Voltage–VC (V) 90 Percent 100 20 Waveform Paramters tr=8µs td=20µs 100 70 e 75 Figure 4: Clamping Voltage vs.Ipp 110 60 50 Ambient Temperature - TA (℃) Figure3: Pulse Waveform -1 50 40 30 td=Ipp/2 20 23 20 17 Test Waveform Paramters tr=8µs td=20µs 14 11 8 5 10 0 2 0 5 10 15 20 25 30 0 Time (µs) IPP (A) Compiance 1 2 3 4 5 6 Peak Pulse Current–IPP (A) Figure5: Positive Clamping voltage (TLP) Figure5: Negative Clamping voltage (TLP) 35 0 30 5 25 10 20 IPP (A) 15 Rdyn = 0.55 Ω 20 15 Rdyn = 0.55 Ω 10 25 5 30 0 -0.5 35 4.5 9.5 14.5 19.5 24.5 VCL (V) -24.5 -19.5 -14.5 -9.5 -4.5 0.5 VCL (V) www.msksemi.com RCLAMP0521P.TCT Semiconductor Compiance PACKAGE MECHANICAL DATA A Dim B C R E D Millimeters MIN MAX MIN MAX A 0.0125 0.02 0.32 0.52 B 0.000 0.002 0.00 0.05 C 0.037 0.043 0.95 1.080 D 0.022 0.027 0.55 0.680 E 0.016 0.024 0.40 0.60 F 0.008 0.012 0.20 0.30 H R F Inches 0.015Typ. 0.001 0.40Typ. 0.005 0.05 0.15 H 1.20 0.50 0.60 0.70 NOTES: 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 2. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. REEL SPECIFICATION P/N RCLAMP0521P.TCT PKG QTY 0402 10000 www.msksemi.com RCLAMP0521P.TCT Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
RCLAMP0521P.TCT 价格&库存
很抱歉,暂时无法提供与“RCLAMP0521P.TCT”相匹配的价格&库存,您可以联系我们找货
