www.msksemi.com
RCLAMP0524P-MS
Semiconductor
Compiance
Features
60Watts peak pulse power (tp = 8/20μs)
Bidirectional configurations
Solid-state silicon-avalanche technology
Low clamping voltage
Low leakage current
Low capacitance (Cj=0.2pF typ. I/O to I/O)
IEC 61000-4-2 ±20kV contact ±25kV air
IEC 61000-4-4 (EFT) 40A (5/50ns)
IEC 61000-4-5 (Lightning) 4A (8/20μs)
Mechanical Data
DFN2510-10
Molding compound flammability rating: UL
94V-0
Packaging: Tape and Reel
RoHS/WEEE Compliant
Applications
USB3.0, USB2.0,Ethernet
HDMI 2.0, Displayport 1.3,eSATA
Unified Display interface
Digital Visual Interface
High speed serial interface
Schematic & PIN Configuration
www.msksemi.com
RCLAMP0524P-MS
Semiconductor
Compiance
Electrical Characteristics
Parameter
Symbol
Reverse Stand-Off Voltage
Reverse Breakdown Voltage
Conditions
Min
Typical
VRWM
Max
Units
5.0
V
6.0
VBR
IT=1mA
Reverse Leakage Current
IR
VRWM=5V,T=25℃
1
µA
Peak Pulse Current
IPP
tp =8/20µs
4
A
Clamping Voltage
VC
IPP=4A,tp=8/20µs
15
V
Junction Capacitance
Cj
V
VR = 0V, f = 1MHz
I/O to I/O
0.2
0.3
VR = 0V, f = 1MHz
I/O to GND
0.4
0.55
pF
Electrical Parameters (TA = 25°C unless otherwise noted)
Parameter
IPP
MaximumReversePeak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
VBR
IT
I
IPP
WorkingPeak Reverse Voltage
Maximum Reverse Leakage Current @ VRWM
VC VBR
VRWM
IT
IR
I
IT R
VRWM
VBR VC
V
Breakdown Voltage @ IT
Test Current
IPP
Note:.8/20µs pulse waveform.
www.msksemi.com
RCLAMP0524P-MS
Semiconductor
Compiance
Typical Characteristic Curves
Fig.1 Peak Pulse Power Rating Curve
Fig.2 Pulse Derating Curve
% of Rated Power (PPP) or IPP
Peak Pulse Power –PPP(KW)
10
1
60W
0.1
0.01
0.1
1
10
100
Pulse Duration tp (μs)
1000
Fig.3 Pulse Waveform-8/20μs
120
60
40
50
75
100
125
Ambient Temperature—TA(℃)
100%IPP , 8μS
150
100%
90%
30ns
80
50%IPP, 20μS
-t
e
60
Percent of IPP
Percent of IPP
80
Fig.4 Pulse Waveform-ESD(IEC61000-4-2)
100
40
100
60ns
10%
10
15
Time (μs)
30
tr 0.7 to 1ns
30
60
Time (ns)
www.msksemi.com
RCLAMP0524P-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
Dimensions in millimeters
Min
Nom
Max
A
0.45
0.50
0.55
A1
0.02
0.05
A3
0.10
0.15
0.20
D
2.45
2.50
2.55
E
0.95
1.00
1.05
D1
0.35
0.40
0.45
b
0.15
0.20
0.25
e
L
0.50BSC
0.35
0.40
0.45
REEL SPECIFICATION
P/N
RCLAMP0524P-MS
PKG
DFN2510-10
QTY
3000
www.msksemi.com
RCLAMP0524P-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“RCLAMP0524P-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27227
- 100+0.21525
- 300+0.18674
- 3000+0.16535
- 6000+0.14829
- 9000+0.13965
