www.msksemi.com
2SK3019-MS
Semiconductor
1. Gate
2. Source
3. Drain
Compiance
Low On-resistance
Fast Switching Speed
Low Voltage Drive Makes This Device
SOT-523
Electrical Symbol:
Easily Designed Drive Circuits
9
Ideal for Portable Equipment
Easy to Parallel
RoHS Compliant & Green EMC
Matte Tin(Sn) Lead Finish
Weight: approx. 0.002g
Marking
D
KN
G
Absolute Maximum Ratings
Symbol
S
TA = 25°C unless otherwise noted
Parameter
VDS
Drain-Source Voltage
VGS
Continuous Gate-Source Voltage
Value
Units
30
V
±20V
V
ID
Continuous Drain Current
100
mA
PD
Power Dissipation
150
mW
RθJA
Thermal Resistance from Junction to Ambient
833
°C /W
TSTG
Storage Temperature Range
-55 to +150
°C
+150
°C
TJ
Operating Junction Temperature
www.msksemi.com
2SK3019-MS
Semiconductor
Electrical Characteristics
(T A = 25°C unless otherwise noted)
Off Characteristics
Symbol
BVDSS
Parameter
Test Condition
Drain-Source Breakdown Voltage
VGS=0V, ID=10uA
IGSS
Gate-Body Leakage
VDS=0V, VGS=±20V
IDSS
Zero Gate Voltage Drain Current
VDS =30V, VGS=0V
Limits
Min
Parameter
Test Condition
Vth(GS)
Gate-Threshold Voltage
VDS= 3V, ID=100uA
RDS(on)
Drain-Source On-Resistance
Reverse Transfer Capacitance
Typ
0.8
Max
Unit
13
Ω
Test Condition
ms
1.2
Dynamic Characteristics
Crss
µA
VGS=2.5V, ID=1mA
IS=115mA, VGS=0V
Output Capacitance
1
Ω
Drain-Source Diode Forward Voltage
Coss
uA
8
VSD
Input Capacitance
±1
VGS=4V, ID=10mA
VDS =3V, ID =10mA
Ciss
Volts
Limits
Min
Unit
Volts
Forward Trans Conductance
Parameter
Max
1.5
gfs
Symbol
Typ
30
On Characteristics
Symbol
Compiance
Limits
Min
Typ
Max
V
Unit
13
pF
VGS = 0V
9
pF
f = 1.0MHz
4
pF
VDS = 5V
Switching Characteristics
Symbol
tD(on)
tD(off)
Parameter
Turn-on Time
Turn-off Time
Test Condition
VDD =5V, RL=500Ω,
ID =10mA, VGs=5V,
RG = 10Ω
Limits
Min
Typ
Max
Unit
15
nS
80
nS
www.msksemi.com
2SK3019-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b1
b2
c
D
E
E1
e
e1
L
L1
Dimensions In Millimeters
Min.
Max.
0.700
0.000
0.700
0.150
0.250
0.100
1.500
0.700
1.450
0.900
0.260
0°
0.500 TYP.
0.400 REF.
Dimensions In Inches
Min.
Max.
0.900
0.100
0.800
0.250
0.350
0.200
1.700
0.900
1.750
0.028
0.000
0.028
0.006
0.010
0.004
0.059
0.028
0.057
1.100
0.035
0.460
8°
0.010
0°
0.020 TYP.
0.016 REF.
0.035
0.004
0.031
0.010
0.014
0.008
0.067
0.035
0.069
0.043
0.018
8°
REEL SPECIFICATION
P/N
2SK3019-MS
PKG
SOT-523
QTY
3000
www.msksemi.com
2SK3019-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“2SK3019-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15303
- 200+0.11833
- 600+0.09906
- 3000+0.08364
- 9000+0.07354
- 21000+0.06812
