B5817W-MS
B5817W-MS
    MSKSEMI(美森科)
    SOD-123
    20V 1A 0.75V@3A SJ
B5817W-MS 数据手册
www.msksemi.com B5817W-MS-B5819W-MS Semiconductor Compiance FEATURES SOD-123 For use in low voltage, high frequency inverters Free wheeling, and polarity protection applications. MARKING: B5817W-MS: SJ B5818W-MS:SK B5819W-MS: SL Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃ Parameter Symbol B5817W-MS B5818W-MS B5819W-MS Unit Non-Repetitive Peak Reverse Voltage VRM 20 30 40 V Peak Repetitive Peak Reverse Voltage Working Peak Reverse Voltage DC Blocking Voltage VRRM VRWM VR 20 30 40 V VR(RMS) 14 21 28 V RMS Reverse Voltage Average Rectified Output Current IO 1 A Peak Forward Surge Current @t=8.3ms IFSM 9 A Repetitive Peak Forward Current IFRM 1.5 A Power Dissipation PD 500 mW Thermal Resistance Junction to Ambient RθJA 200 ℃/W Junction temperature TJ 125 ℃ Storage Temperature TSTG -55~+150 ℃ ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified) Parameter Reverse breakdown voltage Reverse voltage leakage current Forward voltage Symbol V(BR) IR VF Test conditions IR= 1mA B5817W-MS B5818W-MS B5819W-MS VR=20V B5817W-MS VR=30V B5818W-MS VR=40V B5819W-MS B5817W-MS IF=1A B5818W-MS B5819W-MS Diode capacitance CD VR=4V, f=1MHz Min Max 20 30 40 Unit V 1 0.45 IF=3A 0.75 I F=1A 0.55 IF=3A 0.875 I F=1A 0.6 IF=3A 0.9 120 mA V V V pF www.msksemi.com B5817W-MS-B5819W-MS Semiconductor Characteristics Reverse 1 (mA) 10 0.1 REVERSE CURRENT I Forward Characteristics T =100 oC a 1 0.01 0.0 0.2 0.4 FORWARD VOLTAGE VF T =25 oC a 0.01 1E-3 0.8 Capacitance Characteristics D P POWER DISSIPATION 100 REVERSE VOLTAGE 10 VR 100 (V) 10 15 20 VR 25 (V) Power Derating Curve 600 Ta=25℃ 1 5 REVERSE VOLTAGE f=1MHz 10 0.1 0 (V) T CAPACITANCE BETWEEN TERMINALS C (pF) 1000 0.6 0.1 (mW) FORWARD CURRENT R I F (A) 5 Compiance 500 400 300 200 100 0 0 25 50 75 100 AMBIENT TEMPERATURE 125 Ta 150 (℃) www.msksemi.com B5817W-MS-B5819W-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E E1 L L1 θ Dimensions In Millimeters Min Max 1.050 1.250 0.000 0.100 1.050 1.150 0.450 0.650 0.080 0.150 1.500 1.700 2.600 2.800 3.550 3.850 0.500 REF 0.250 0.450 0° 8° Dimensions In Inches Min Max 0.041 0.049 0.000 0.004 0.041 0.045 0.018 0.026 0.003 0.006 0.059 0.067 0.102 0.110 0.140 0.152 0.020 REF 0.010 0.018 0° 8° REEL SPECIFICATION P/N PKG QTY B5817W-MS SOD-123 3000 B5818W-MS SOD-123 3000 B5819W-MS SOD-123 3000 www.msksemi.com B5817W-MS-B5819W-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
B5817W-MS 价格&库存
很抱歉,暂时无法提供与“B5817W-MS”相匹配的价格&库存,您可以联系我们找货
B5817W-MS
    • 10+0.28237
    • 100+0.22638
    • 300+0.19839
    • 3000+0.16233
    • 6000+0.14551
    • 9000+0.13706
    库存:19
