www.msksemi.com
B5817WS-MS-B5819WS-MS
Semiconductor
For use in low voltage, high frequency inverters
Free wheeling, and polarity protection applications
Compiance
SOD-323
MARKING: B5817WS-MS: SJ
B5818WS-MS:SK
B5819WS-MS: SL
Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃
Symbol
B5817WS-MS
B5818WS-MS
B5819WS-MS
Unit
Non-repetitive peak reverse voltage
VRM
40
V
Peak repetitive peak reverse voltage
Working peak reverse voltage
DC blocking voltage
VRRM
VRWM
VR
40
V
RMS reverse voltage
VR(RMS)
14
21
28
V
Average rectified output current
IO
1
A
Peak forward surge current @t=8.3ms
IFSM
9
A
Repetitive peak forward current
IFRM
1.5
A
Parameter
Power dissipation
Pd
250
mW
Thermal resistance junction to
ambient
RθJA
400
℃/W
Junction temperature
TJ
125
Storage temperature
TSTG
-55~+150
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Symbol
Test
IR= 1mA
Reverse breakdown voltage
Reverse voltage leakage current
Forward voltage
Diode capacitance
V(BR)
IR
VF
CD
VR =20V
VR=30V
VR=40V
conditions
B5817WS-MS
B5818WS-MS
B5819WS-MS
B5817WS-MS
B5818WS-MS
B5819WS-MS
Min
Max
40
V
1
B5817WS-MS IF=1A
0.45
IF=3A
0.75
B5818WS-MS IF=1A
0.55
IF=3A
0.875
B5819WS-MS IF=1A
0.6
IF=3A
0.9
VR=4V, f=1MHz
Unit
120
mA
V
V
V
pF
www.msksemi.com
Semiconductor
Characteristics
Reverse
1
(mA)
10
0.1
REVERSE CURRENT I
Forward
Characteristics
T =100 oC
a
1
0.01
0.0
0.2
0.4
FORWARD VOLTAGE
VF
T =25 oC
a
0.01
1E-3
0.8
Capacitance Characteristics
D
P
POWER DISSIPATION
100
REVERSE VOLTAGE
10
VR
100
(V)
10
15
VR
25
(V)
Power Derating Curve
600
Ta=25℃
1
5
REVERSE VOLTAGE
f=1MHz
10
0.1
(V)
T
CAPACITANCE BETWEEN TERMINALS
C
(pF)
1000
0.6
0.1
(mW)
FORWARD CURRENT
R
I
F
(A)
5
Compiance
500
400
300
200
100
50
75
100
AMBIENT TEMPERATURE
125
Ta
150
www.msksemi.com
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
REEL SPECIFICATION
P/N
PKG
QTY
B5817WS-MS
SOD-323
3000
B5818WS-MS
SOD-323
3000
B5819WS-MS
SOD-323
3000
www.msksemi.com
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“B5819WS-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24310
- 200+0.15840
- 1500+0.13640
- 3000+0.12100
- 国内价格
- 10+0.23600
- 300+0.20890
- 3000+0.18680
- 6000+0.16910
- 9000+0.16010
- 国内价格
- 10+0.31320
- 100+0.25100
- 300+0.21989
- 3000+0.19656
- 6000+0.17788
- 9000+0.16848
