ESDA6V1W5-MS
ESDA6V1W5-MS
    MSKSEMI(美森科)
    SOT323-5
    SOT323 VBR:6.1V 90pF
ESDA6V1W5-MS 数据手册
www.msksemi.com ESDA6V1W5-MS Semiconductor Compiance Features  4 Unidirectional Transil functions  Breakdown voltage:  VBR = 6.1 V min. and 25 V min.  Low leakage current: < 1 mA  Very small PCB area < 4.2 mm2 typically  High ESD protection level: up to 25 kV    High integration Pb-Free Package is Available S- Prefix for Automotive and Other Applications Requiring Unique Site and Control Change Requirements; AEC-Q101 Qualified and PPAP Capable. Complies with the following standards IEC61000-4-2 Level 4 16 kV (air discharge) 9 kV(contact discharge) MIL STD 883E - Method 3015-7 Class 3 25 kV HBM (Human Body Model) SOT-323-5 Applications  Computers  Printers  Communication systems  Cellular phones handsets and accessories  Wireline and wireless telephone sets  Set top boxes Absolute Ratings (Tamb=25°C ) Symbol PPP Parameter Peak Pulse Power (tp = 8/20μs) Value Units 150 W TL Maximum lead temperature for soldering during 10s 260 °C Tstg Storage Temperature Range -40 to +125 °C Top Operating Temperature Range -40 to +125 °C www.msksemi.com ESDA6V1W5-MS Semiconductor Compiance Electrical Parameter Symbol Parameter VRM Stand-off voltage VBR Breakdown voltage VCL Clamping voltage IRM Leakage current IPP Peak pulse current IR Reverse current IF Forward current αT Voltage temperature coefficient VF Forward voltage drop C Capacitance Rd Dynamic Electrical Characteristics VBR P/N ESDA6V1W5-MS VF αT C Typ.(1) Max.(2) Typ. 0v bias IR VRM IRM v mA v µA v mA Ω 10-4/°C pF 7.2 1 5 1 1.25 200 0.61 6 90 Min. Max. v 6.1 Max. IF Rd 1.Square pulse IPP=15A,tp=2.5µs 2.VBR=aT*(Tamb-25°C)*VBR(25°C) www.msksemi.com ESDA6V1W5-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E E1 e e1 L L1 θ Dimensions In Millimeters Min Max 0.900 1.100 0.000 0.100 0.900 1.000 0.150 0.350 0.100 0.150 2.000 2.200 1.150 1.350 2.150 2.400 0.650 TYP 1.200 1.400 0.525 REF 0.260 0.460 0° 8° Dimensions In Inches Min Max 0.035 0.043 0.000 0.004 0.035 0.039 0.006 0.014 0.004 0.006 0.079 0.087 0.045 0.053 0.085 0.094 0.026 TYP 0.047 0.055 0.021 REF 0.010 0.018 0° 8° REEL SPECIFICATION P/N ESDA6V1W5-MS PKG QTY SOT-323-5 3000 www.msksemi.com ESDA6V1W5-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
ESDA6V1W5-MS 价格&库存
很抱歉,暂时无法提供与“ESDA6V1W5-MS”相匹配的价格&库存,您可以联系我们找货
ESDA6V1W5-MS
    • 5+0.57329
    • 50+0.45665
    • 150+0.39833
    • 500+0.35459
    • 3000+0.31960
    • 6000+0.30210
    库存:1250
