www.msksemi.com
AO4884-MS
Semiconductor
Compiance
D1
D1
D2
D2
General Features
S1
G1
S2
G2
VDS = 40V ID =10A
RDS(ON) < 19mΩ @ VGS=10V
SOP-8
Application
Battery protection
D1
D1
7
6
D2
D2
1
2
3
4
8
5
Load switch
Uninterruptible power supply
S1
G1
S2
G2
N-Channel MOSFET
Absolute Maximum Ratings (TA=25℃unless otherwise noted)
Parameter
Symbol
Limit
Unit
Drain-Source Voltage
V DS
40
V
Gate-Source Voltage
VGS
±20
V
ID
10
A
ID (100℃)
6.4
A
Pulsed Drain Current
IDM
40
A
Maximum Power Dissipation
PD
2
W
TJ,TSTG
-55 To 150
RθJA
62.5
℃/W
Drain Current-Continuous
Drain Current-Continuous(T C=100℃)
Operating Junction and Storage Temperature Range
Thermal Resistance,Junction-to-Ambient (Note 2)
www.msksemi.com
AO4884-MS
Semiconductor
Compiance
N-CH Electrical Characteristics (TA=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
40
V
Zero Gate Voltage Drain Current
IDSS
VDS=40V,V GS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,V DS=0V
±100
nA
VGS(th)
VDS=VGS,ID=250μA
1
1.5
2.0
V
VGS=10V, ID=8A
15
mΩ
VGS=4.5V, ID=4A
mΩ
VDS=5V,ID=8A
33
S
964
PF
109
PF
96
PF
5.5
nS
14
nS
24
nS
Gate Threshold Voltage
Drain-Source On-State Resistance
RDS(ON)
Forward Transconductance
gFS
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
Turn-Off Delay Time
td(off)
VDS=20V,VGS=0V,
F=1.0MHz
VDD=20V, RL=2.5Ω
VGS=10V,RGEN=3Ω
Turn-Off Fall Time
tf
12
nS
Total Gate Charge
Qg
22.9
nC
Gate-Source Charge
Qgs
3.5
nC
5.3
nC
0.8
1.2
V
Qgd
Gate-Drain Charge
Diode Forward Voltage
(Note 3)
VSD
VDS=20V,ID=8A,
VGS=10V
VGS=0V,IS=9A
www.msksemi.com
AO4884-MS
Semiconductor
Compiance
www.msksemi.com
AO4884-MS
Semiconductor
Vgs Gate-Source Voltage (V)
Figure7 Rdson vs Vgs
Qg Gate Charge (nC)
Figure 9 Gate Charge
Vds Drain-Source Voltage (V)
Figure 11 Capacitance vs Vds
Compiance
TJ-Junction Temperature(℃)
Figure 8 Power Dissipation
Figure 10 Source- Drain Diode Forward
Figure 12 Safe Operation Area
www.msksemi.com
AO4884-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b
c
D
e
E
E1
L
θ
Dimensions In Millimeters
Min
1.350
Max
1.750
Dimensions In Inches
Min
0.053
Max
0.069
0.100
0.250
1.350
1.550
0.330
0.510
0.170
0.250
4.800
5.000
1.270(BSC)
0.004
0.010
0.053
0.061
0.013
0.020
0.007
0.010
0.189
0.197
0.050(BSC)
5.800
3.800
0.400
6.200
4.000
1.270
0.228
0.150
0.016
0.244
0.157
0.050
0°
8°
0°
8°
REEL SPECIFICATION
P/N
AO4884-MS
PKG
QTY
SOP-8
4000
www.msksemi.com
AO4884-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“AO4884-MS”相匹配的价格&库存,您可以联系我们找货
