www.msksemi.com
SS12-MS/SS110-MS
Semiconductor
Compiance
FEATURES
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
250 C/10 seconds at terminals
MECHANICAL DATA
Case: JEDEC DO-214AC molded plastic body
Terminals: leads solderable per MIL-STD-750,
Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight:0.003 ounce, 0.093 grams
0.004 ounce, 0.111 grams SMA(H)
SMA
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL(see fig.1)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Maximum instantaneous forward voltage at 1.0A
Maximum DC reverse current
TA=25 C
at rated DC blocking voltage
TA=100 C
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
SYMBOLS
SS12
SS13
SS14
SS15
SS16
VRRM
VRMS
VDC
21
30
40
28
40
50
35
50
60
42
60
SS18 SS110
80
56
80
100
70
100
UNITS
VOLTS
VOLTS
VOLTS
I(AV)
1.0
Amp
IFSM
40.0
Amps
VF
IR
CJ
RqJA
TJ,
TSTG
0.45
0.55
0.85
0.70
0.5
6.0
110
-65 to +125
5.0
90
88.0
-65 to +150
-65 to +150
Volts
mA
pF
C/W
C
C
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
www.msksemi.com
SS12-MS/SS110-MS
Semiconductor
Fig.1 Forward Current Derating Curve
Fig.2 Typical Reverse Characteristics
10 4
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
1.5
Average Forward Current (A)
Compiance
T J=100°C
10 3
T J=75°C
10 2
10
SS12/SS14
SS16-SS120
1
T J=25°C
100
Case Temperature (°C)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
T J=25°C
1.0
0.1
Junction Capacitance (pF)
10
SS12/SS14
SS16/SS18
SS110/SS112
SS115/SS120
0.4
0.6
0.8 1.0 1.2
1.4
1.6
1.8
SS12/SS14
SS16-SS120
0.1
1
10
100
Fig.6- Typical Transient Thermal Impedance
24
18
12
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
50
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
30
00
100
Reverse Voltage (V)
36
06
200
Instaneous Forward Voltage (V)
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
500
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.msksemi.com
SS12-MS/SS110-MS
Semiconductor
PACKAGE MECHANICAL DATA
A
Dimensions
B
Ref.
Min.
Max.
A
4.25
B
Inches
Min.
Max.
4.65
0.167
0.183
2.50
2.90
0.098
0.114
C
1.35
1.65
0.053
0.065
D
0.76
1.52
0.030
0.060
E
E
4.93
5.28
0.194
0.208
F
0.051
0.203
0.002
0.008
J
K
G
0.15
0.31
0.006
0.012
H
1.98
2.41
0.078
0.095
J
6.50
H
F
G
L
D
Millimeters
2.30
K
DO-214AC (SMA)
L
0.256
1.70
0.090
0.067
REEL SPECIFICATION
P/N
SS12-MS/SS110-MS
PKG
QTY
SMA
2000
Compiance
SS12-MS/SS110-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“SS14-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.09053
- 50+0.04521
- 2000+0.03432
- 国内价格
- 20+0.16786
- 200+0.13636
- 600+0.11891
- 2000+0.09665
- 10000+0.08752
- 20000+0.08260
