www.msksemi.com
AZC199-04S-MS
Semiconductor
Compiance
MAIN APPLICATIONS
USB 2.0&3.0 power and data line protection
Digital video interface (DVI)
Notebook computers
Video graphics cards
Monitors and flat panel displays
10/100/1000 ethernet
SIM ports
ATM interfaces
PIN Configuration
PROTECTION SOLUTION TO MEET
IEC61000-4-2 (ESD) ±20kV (air), ±20kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC61000-4-5 (Lightning) 5A (8/20µs)
100 watts peak pulse power per line (tP=8/20µs)
Protects four I/O lines
Low clamping voltage
Low operating voltage
Low capacitance
Circuit Diagram
ABSOLUTE MAXIMUM RATINGS (TA=25℃, RH=45%-75%, unless otherwise noted)
Parameter
Peak pulse power dissipation on 8/20µs
waveform
ESD per IEC 61000-4-2 (Air)
ESD per IEC 61000-4-2 (Contact)
Symbol
Value
Unit
PPP
100
W
VESD
+/- 20
+/-20
kV
Lead soldering temperature
TL
260 (10 sec.)
Operating junction temperature range
TJ
-55 to +125
TSTG
-55 to +150
Storage temperature range
ELECTRICAL CHARACTERISTICS (TA=25℃)
Parameter
Reverse working voltage
Reverse breakdown voltage
Symbol
Conditions
Typ
VRWM
VBR
IT=1mA
Reverse leakage current
IR
VRWM=5V
Forward voltage
VF
IT=10mA
Clamping voltage
(I/O pin to Ground)
VC
Junction capacitance
Min
Max
Unit
5.0
V
6.0
V
1
µA
0.8
1.0
V
IPP=1A, tP=8/20µs
9.5
11
VC
IPP=5A, tP=8/20µs
12.5
15
CJ
VRWM=0V, f=1MHz
Any I/O pin to Ground
VRWM=0V, f=1MHz
Between I/O pins
0.65
0.8
0.3
0.5
V
pF
www.msksemi.com
AZC199-04S-MS
Semiconductor
Compiance
Electrical Parameter
Symbol
Parameter
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
VRWM
IR
Working Peak Reverse Voltage
Maximum Reverse Leakage Current @
VRWM
IT
Test Current
VBR
Breakdown Voltage @ IT
FIG1: Pulse Waveform
FIG2:Power Derating
www.msksemi.com
AZC199-04S-MS
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b
c
D
E1
E
e
e1
L
θ
Dimensions In Millimeters
Min.
Max.
1.050
1.250
0.000
0.100
1.050
1.150
0.300
0.500
0.100
0.200
2.820
3.020
1.500
1.700
2.650
2.950
0.950(BSC)
1.800
2.000
0.300
0.600
0°
8°
Dimensions In Inches
Min.
Max.
0.041
0.049
0.000
0.004
0.041
0.045
0.012
0.020
0.004
0.008
0.111
0.119
0.059
0.067
0.104
0.116
0.037(BSC)
0.071
0.079
0.012
0.024
0°
8°
REEL SPECIFICATION
P/N
AZC199-04S-MS
PKG
SOT-23-6
QTY
3000
www.msksemi.com
AZC199-04S-MS
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative
nearest
you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities
concerned
in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable,
but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or
other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“AZC199-04S-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.60830
- 200+0.39160
- 1500+0.34100
- 3000+0.30250
- 国内价格
- 10+0.27413
- 100+0.22045
- 600+0.19359
- 1200+0.19069
- 3000+0.14622
- 国内价格
- 10+0.26990
- 100+0.21702
- 300+0.19058
- 3000+0.14395
- 6000+0.12806
- 9000+0.12018
