SRV05-4
SRV05-4
    MSKSEMI(美森科)
    SOT23-6
    SOT23-6 VC:15V 60W
SRV05-4 数据手册
www.msksemi.com SRV05-4 Semiconductor Compiance FEATURES  Transient protection for high-speed data lines IEC 61000-4-2(ESD) PACKAGE OUTLINE ±20KV(Contact) ±25KV(Air) IEC 61000-4-4(EFT) 40A(5/50ns)  Package optimized for high-speed lines  Small package(2.9mm*2.8mm*1.1mm)  Protects four data lines and one Vcc line  Low capacitance: 0.20pF (I/O to I/O)  Low leakage current  Low clamping voltage  Each I/O pin can withstand over 1000 ESD strikes for ±8KV contact discharge MACHANICAL DATA SOT-23-6  Flammability Rating: UL 94V-0  Terminal: Matte tin plated.  High temperature soldering guaranteed:  260℃/10s  Packaging: Tape and Reel PIN CONFIGURATION  Reel size: 7 inch APPLICATIONS  Serial ATA  MDDI Ports  USB 2.0/3.0 Power and Data Line Protection  Display Ports  High Definition Multi-Media Interface (HDMI)  Digital Visual Interface (DVI) www.msksemi.com SRV05-4 Semiconductor Compiance ABSOLUTE MAXIMUM RATING Symbol Parameter Value Units PPP Peak Pulse Power (8/20μs) 60 W VESD ESD per IEC 61000-4-2 (Contact) ESD per IEC 61000-4-2 (Air) ±20 ±25 kV TOPT Operating Temperature -55/+125 C TSTG Storage Temperature -55/+150 C ELECTRICAL CHARACTERISTICS (Tamb=25C) Symbol Parameter Test Condition VRWM Reverse Working Voltage Any I/O pin to GND VBR Reverse Breakdown Voltage IR Reverse Leakage Current IT = 1mA Any I/O pin to GND VRWM = 5V Any I/O pin to GND IPP = 1A, tp = 8/20μs Any I/O pin to GND IPP = 4A, tp = 8/20μs Any I/O pin to GND IPP = 8A, tp = 8/20μs Vcc pin to GND VR = 0V, f = 1MHz Between I/O and I/O VR = 0V, f = 1MHz Between I/O and GND VR = 0V, f = 1MHz Between Vcc and GND VC CESD Clamping Voltage Parasitic Capacitance Min Typ Max Units 5.0 V 9.0 V 1.0 μA 10 V 15 V 15 V 0.20 0.30 pF 0.45 0.50 pF 6.0 0.80 pF Note: I/O Pins are pin 1,3,4,6. Pin 5 is Vcc. Pin 2 is GND. www.msksemi.com SRV05-4 Semiconductor Compiance ELECTRICAL CHARACTERISTICS CURVE www.msksemi.com SRV05-4 Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E1 E e e1 L θ Dimensions In Millimeters Min. Max. 1.050 1.250 0.000 0.100 1.050 1.150 0.300 0.500 0.100 0.200 2.820 3.020 1.500 1.700 2.650 2.950 0.950(BSC) 1.800 2.000 0.300 0.600 0° 8° Dimensions In Inches Min. Max. 0.041 0.049 0.000 0.004 0.041 0.045 0.012 0.020 0.004 0.008 0.111 0.119 0.059 0.067 0.104 0.116 0.037(BSC) 0.071 0.079 0.012 0.024 0° 8° REEL SPECIFICATION P/N SRV05-4 PKG SOT-23-6 QTY 3000 www.msksemi.com SRV05-4 Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
SRV05-4 价格&库存
很抱歉,暂时无法提供与“SRV05-4”相匹配的价格&库存,您可以联系我们找货
SRV05-4
    • 20+0.12356
    库存:2537
    SRV05-4
      • 1+0.45210
      • 200+0.15070
      • 1500+0.09427
      • 3000+0.07480
      库存:5117
