www.msksemi.com
BAT54/A/C/S
Semiconductor
FEATURES
Compiance
3
Extremely Fast Switching Speed
1
2
SOT-23
BAT54 MARKING: KL1
BAT54A MARKING: KL2
BAT54C MARKING: KL3
BAT54S MARKING: KL4
Maximum Ratings @TA=25℃
Parameter
Peak Repetitive Peak reverse voltage
Working Peak Reverse Voltage
Symbol
Limits
Unit
30
V
VRRM
VRWM
VR
Forward Continuous Current
IFM
200
mA
Power Dissipation
PD
200
mW
TSTG
-55-150
Storage temperature
Electrical Characteristics @TA=25℃
Parameter
Reverse Breakdown Voltage
Symbol
Min.
V (BR)R
30
Typ.
Max.
Unit
Conditions
V
IR=100μA
VF1
0.24
V
IF=0.1mA
VF2
0.32
V
IF=1mA
VF3
0.40
V
IF=10mA
VF4
0.50
V
IF=30mA
VF5
1
V
IF=100mA
Reverse current
IR
2
μA
VR=25V
Diode Capacitance
CD
10
pF
VR=1V,f=1MHz
Reverse Recovery Time
trr
5
nS
Forward voltage
IF=IR=10mA
Irr=0.1XIR,RL=100Ω
www.msksemi.com
BAT54/A/C/S
Semiconductor
Compiance
Typical Characteristics
Forward
Characteristics
(uA)
100
REVERSE CURRENT IR
FORWARD CURRENT
10
1
0.1
0.01
400
600
FORWARD VOLTAGE
(mW)
D
P
POWER DISSIPATION
12
8
4
10
15
REVERSE VOLTAGE
VR
T =25 oC
a
0.1
25
(V)
10
15
30
VR
25
30
125
150
(V)
Power Derating Curve
300
f=1MHz
5
1
REVERSE VOLTAGE
Ta=25℃
a
(mV)
16
Characteristics
T =100 oC
10
0.01
1000
Capacitance Characteristics
CAPACITANCE BETWEEN TERMINALS
C T (pF)
800
VF
Reverse
100
IF
(mA)
1000
250
200
150
100
50
50
75
100
AMBIENT TEMPERATURE
Ta
www.msksemi.com
BAT54/A/C/S
Semiconductor
Compiance
PACKAGE MECHANICAL DATA
Symbol
A
A1
A2
b
c
D
E1
E
e
e1
L
Dimensions In Millimeters
Min.
Max.
1.050
1.250
0.000
0.100
1.050
1.150
0.300
0.500
0.100
0.200
2.820
3.020
1.500
1.700
2.650
2.950
0.950(BSC)
1.800
2.000
0.300
0.600
0°
8°
Dimensions In Inches
Min.
Max.
0.041
0.049
0.000
0.004
0.041
0.045
0.012
0.020
0.004
0.008
0.111
0.119
0.059
0.067
0.104
0.116
0.037(BSC)
0.071
0.079
0.012
0.024
0°
8°
REEL SPECIFICATION
P/N
BAT54/A/C/S
PKG
SOT-23
QTY
3000
www.msksemi.com
BAT54/A/C/S
Semiconductor
Compiance
Attention
■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications
that can handle applications that require extremely high levels of reliability, such as life-support systems,
aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious
physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you
before using any MSKSEMI Semiconductor products described or contained herein in such applications.
■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products
at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or
other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described
orcontained herein.
■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the
performance, characteristics, and functions of the described products in the independent state, and are not
guarantees of the performance, characteristics, and functions of the described products as mounted in the
customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent
device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment.
■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all
semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to
accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause
damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents
or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention
circuitsfor safedesign, redundant design, and structural design.
■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described
or contained herein are controlled under any of applicable local export control laws and regulations, such
products must not be exported without obtaining the export license from theauthorities concerned in
accordance with the above law.
■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or
mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise,
without the prior written permission of MSKSEMI Semiconductor.
■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not
guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and
reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property
rights or other rightsof third parties.
■ Any and all information described or contained herein are subject to change without notice due to
product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the
MSKSEMI Semiconductor productthat you intend to use.
www.msksemi.com
很抱歉,暂时无法提供与“BAT54C-MS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18700
- 200+0.06204
- 1500+0.03883
- 3000+0.03069
- 国内价格
- 50+0.06250
- 500+0.04820
- 1500+0.04110
- 5000+0.03650
- 30000+0.03350
- 50000+0.03050
- 国内价格
- 50+0.06772
- 500+0.05314
- 3000+0.04180
- 6000+0.03694
- 24000+0.03273
- 51000+0.03046
