BAT54
BAT54
    MSKSEMI(美森科)
    SOT-23
    IR=2uA@25V VRRM=30V Single VF=1V@100mA IFM=200mA SOT-23 肖特基势垒二极管(SBD)ROHS
BAT54 数据手册
www.msksemi.com BAT54/A/C/S Semiconductor FEATURES Compiance 3 Extremely Fast Switching Speed 1 2 SOT-23 BAT54 MARKING: KL1 BAT54A MARKING: KL2 BAT54C MARKING: KL3 BAT54S MARKING: KL4 Maximum Ratings @TA=25℃ Parameter Peak Repetitive Peak reverse voltage Working Peak Reverse Voltage Symbol Limits Unit 30 V VRRM VRWM VR Forward Continuous Current IFM 200 mA Power Dissipation PD 200 mW TSTG -55-150 ℃ Storage temperature Electrical Characteristics @TA=25℃ Parameter Reverse Breakdown Voltage Symbol Min. V (BR)R 30 Typ. Max. Unit Conditions V IR=100μA VF1 0.24 V IF=0.1mA VF2 0.32 V IF=1mA VF3 0.40 V IF=10mA VF4 0.50 V IF=30mA VF5 1 V IF=100mA Reverse current IR 2 μA VR=25V Diode Capacitance CD 10 pF VR=1V,f=1MHz Reverse Recovery Time trr 5 nS Forward voltage IF=IR=10mA Irr=0.1XIR,RL=100Ω www.msksemi.com BAT54/A/C/S Semiconductor Compiance Typical Characteristics Forward Characteristics (uA) 100 REVERSE CURRENT IR FORWARD CURRENT 10 1 0.1 0.01 0 200 400 600 FORWARD VOLTAGE (mW) D P POWER DISSIPATION 12 8 4 10 15 REVERSE VOLTAGE 20 VR T =25 oC a 0.1 0 5 25 (V) 10 15 30 20 VR 25 30 125 150 (V) Power Derating Curve 300 f=1MHz 5 1 REVERSE VOLTAGE Ta=25℃ 0 a (mV) 16 0 Characteristics T =100 oC 10 0.01 1000 Capacitance Characteristics 20 CAPACITANCE BETWEEN TERMINALS C T (pF) 800 VF Reverse 100 IF (mA) 1000 250 200 150 100 50 0 0 25 50 75 100 AMBIENT TEMPERATURE Ta (℃) www.msksemi.com BAT54/A/C/S Semiconductor Compiance PACKAGE MECHANICAL DATA Symbol A A1 A2 b c D E1 E e e1 L 0 Dimensions In Millimeters Min. Max. 1.050 1.250 0.000 0.100 1.050 1.150 0.300 0.500 0.100 0.200 2.820 3.020 1.500 1.700 2.650 2.950 0.950(BSC) 1.800 2.000 0.300 0.600 0° 8° Dimensions In Inches Min. Max. 0.041 0.049 0.000 0.004 0.041 0.045 0.012 0.020 0.004 0.008 0.111 0.119 0.059 0.067 0.104 0.116 0.037(BSC) 0.071 0.079 0.012 0.024 0° 8° REEL SPECIFICATION P/N BAT54/A/C/S PKG SOT-23 QTY 3000 www.msksemi.com BAT54/A/C/S Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
BAT54 价格&库存
很抱歉,暂时无法提供与“BAT54”相匹配的价格&库存,您可以联系我们找货
BAT54
  • 50+0.02860
  • 500+0.02700
库存:2343
BAT54
    • 50+0.06956
    • 500+0.05498
    • 3000+0.04331
    • 6000+0.03845
    • 24000+0.03424
    • 51000+0.03197
    库存:2491
    BAT54
    • 50+0.05596
    • 500+0.05253
    • 2000+0.04566
    • 5000+0.04223
    • 15000+0.03880
    • 30000+0.03708
    库存:2083
