MMSZ5221B-MMSZ5262B
Surface mount zener diode
FEATURES
z
z
z
Planar die construction.
500mW power dissipation.
General purpose, medium current.
z
Ideally suited for automated assembly processes.
APPLICATIONS
z
Zener diode.
z
Ultra-small surface mount package.
SOD-123
ORDERING INFORMATION
Type No.
MMSZ5221B-MMSZ5262B
Marking
Package Code
See table 2
SOD-123
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
Characteristic
Symbol
Value
Unit
VF
0.9
V
Power Dissipation
Pd
500
mW
Thermal resistance,junction to ambient air
RθjA
350
℃/W
Junction temperature
Tj
150
Storage temperature range
Tstg
-65 to +150
Forward Voltage
@ IF=10mA
Notes: 1. Device mounted on ceramic PCB; 7.6 mm x 9.4 mm x 0.87 mm with pad areas 25 mm2.
2. Tested with pulses, Tp ≤1.0ms.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
MMSZ5221B-MMSZ5262B
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
Type
Type
Number
Code
Zener Voltage Range
Test
Current
Vz@IZT
IZT
Maximum Zener
Impedance
ZZT@IZT
ZZK@IZK=0.25mA
Ω
Maximum Reverse
Leakage Current
IR
@VR
μA
V
Nom(V)
Min(V)
Max(V)
mA
MMSZ5221B
2.4
2.28
2.52
1200
100
1.0
MMSZ5223B
2.7
2.57
2.84
1300
75
1.0
MMSZ5225B
3.0
2.85
3.15
1600
50
1.0
MMSZ5226B
3.3
3.14
3.47
1600
25
1.0
MMSZ5227B
3.6
3.42
3.78
1700
15
1.0
MMSZ5228B
3.9
3.71
4.10
1900
10
1.0
MMSZ5229B
4.3
4.09
4.52
2000
5.0
1.0
MMSZ5230B
4.7
4.47
4.94
1900
5.0
2.0
MMSZ5231B
5.1
4.85
5.36
1600
5.0
2.0
MMSZ5232B
5.6
5.32
5.88
1600
5.0
3.0
MMSZ5233B
6.0
5.70
6.30
1600
5.0
3.5
MMSZ5234B
6.2
5.89
6.51
1000
5.0
4.0
MMSZ5235B
6.8
6.46
7.14
750
3.0
5.0
MMSZ5236B
7.5
7.13
7.88
500
3.0
6.0
MMSZ5237B
8.2
7.79
8.61
500
3.0
6.5
MMSZ5238B
8.7
8.27
9.14
600
3.0
6.5
MMSZ5239B
9.1
8.65
9.56
600
3.0
7.0
MMSZ5240B
10
9.50
10.50
600
3.0
8.0
MMSZ5241B
11
10.45
11.55
600
2.0
8.4
MMSZ5242B
12
11.40
12.60
600
1.0
9.1
MMSZ5243B
13
12.35
13.65
9.5
13
600
0.5
9.9
MMSZ5245B
15
14.25
15.75
8.5
16
600
0.1
11
MMSZ5246B
16
15.20
16.80
7.8
17
600
0.1
12
MMSZ5248B
18
17.10
18.90
7.0
21
600
0.1
14
MMSZ5250B
21.00
6.2
25
600
0.1
15
MMSZ5251B
22
20.90
23.10
5.6
29
600
0.1
17
MMSZ5252B
24
22.80
25.20
5.2
33
600
0.1
18
MMSZ5254B
27
25.65
28.35
5.0
41
600
0.1
21
MMSZ5255B
28
26.60
29.40
4.5
44
600
0.1
21
MMSZ5256B
30
28.50
31.5
4.2
49
600
0.1
23
MMSZ5257B
33
31.35
34.65
3.8
58
700
0.1
25
MMSZ5258B
36
34.20
37.80
3.4
70
700
0.1
27
MMSZ5259B
39
37.05
40.95
3.2
80
800
0.1
30
MMSZ5260B
43
40.85
45.15
3.0
93
900
0.1
33
MMSZ5261B
47
44.65
49.35
2.7
105
1000
0.1
36
ht t p : //
www.lgesemi .c o m
MMSZ5221B-MMSZ5262B
Type
Zener Voltage Range
Number
MMSZ5262B
Vz@IZT
Test
Maximum Zener
Maximum Reverse
Current
Impedance
Leakage Current
IZT
Nom(V)
Min(V)
Max(V)
mA
51
48.45
53.55
2.5
ZZT@IZT
ZZK@IZK=0.25mA
Ω
125
1100
IR
@VR
μA
V
0.1
39
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
ht t p : //
www.lgesemi .c o m
MMSZ5221B-MMSZ5262B
PACKAGE OUTLINE
Plastic surface mounted package
SOD-123
K
SOD-123
B
C
A
D
H
E
Dim
Min
Max
A
1.4
1.8
B
2.55
2.85
C
1.15 Typical
D
0.55 Typical
E
0.3
0.4
H
0.02
0.10
0.1 Typical
J
J
K
3.55
3.85
All Dimensions in mm
SOLDERING FOOTPRINT
Unit:mm
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SOD-123
3000/REEL
90000
40X20X22
5.00
4.00
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“MMSZ5228B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.11325
- 300+0.08821
- 1200+0.07431
- 3000+0.06593
- 国内价格
- 20+0.12355
- 200+0.09623
- 600+0.08107
- 3000+0.07193
- 9000+0.06406
- 21000+0.05988
