UF5400-UF5408
Glass Passivated Rectifiers
DO - 27
Features
Glass passivated junction
Low leakage
Low forward voltage drop
High current capability
v
Easily cleaned with alcohol,Isopropanol
and similar solvents
The plastic material carries U/L recognition
94V-0
Mechanical Data
Case:JEDEC DO-27,molded plastic
Terminals: Axial lead ,solderable per
Dimensions in millimeters
MIL- STD-202,Method 208
Polarity: Color band denotes cathode
Weight: 0.041 ounces,1.15 grams
Mounting position: Any
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25
ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
UF
5400
UF
5401
UF
5402
UF
5403
UF
5404
UF
5405
UF
5406
UF
5407
UF
5408
UNITS
Maximum recurrent peak reverse voltage
VRRM
50
100
200
300
400
500
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
210
280
350
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
300
400
500
600
800
1000
V
Maximum average forw ard rectified current
9.5mm lead length,
@TA =75
IF(AV)
3.0
A
IFSM
150.0
A
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
@TJ =125
Maximum instantaneous forw ard voltage
v at 3.0 A
Maximum reverse current
at rated DC blocking voltage
VF
@TA =25
1.0
10.0
IR
@TA =100
1.7
(Note1)
trr
Typical junction capacitance
(Note2)
CJ
45
Typical thermal resistance
(Note3)
RθJA
TJ
- 55 ---- + 175
TSTG
- 55 ---- + 175
Operating junction temperature range
Storage temperature range
A
100.0
Maximum reverse recovery time
50
V
75
ns
pF
/W
NOTE: 1. Measured with I F=0.5A, I R=1A, I rr=0.25A.
2. Measured at 1.0MHZ and applied rev erse v oltage of 4.0V DC.
3. Thermal resistance junction to ambient.
Revision:20170301-P1
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
UF5400-UF5408
Ratings AND Charactieristic Curves
FIG.1 -- TEST CIRCUIT DIAGRAM AND REVERSE RECOVERY TIME CHARACTERISTIC
trr
50
N 1.
10
N 1.
+0.5A
D.U.T.
50VDC
(approx)
OSCILLOSCOPE
(NOTE 1)
1
NONINDUCTIVE
PULSE
GENERATOR
(NOTE2)
-0.25A
-1.0A
1cm
SET TIME BASE FOR 10/20 ns/cm
NOTES:1.RISE TIME = 7ns MAX.INPUT IMPEDANCE = 1M .22pF.
JJJJJ2.RISE TIME =10ns MAX.SOURCE IMPEDANCE=50 .
FIG.3 -- FORWARD DERATING CURVE
1
0 .1
U F 5 4 0 5 G --U F 5 4 0 8 G
TJ=25
P u ls e w id th = 3 0 0
0 .0 1
0 .4 0 .6 0 .8 1 .0
s
1 .2 1 .4 1 .6 1 .8
2.5
2.0
AMPERES
10
AVERAGE FORWARD CURRENT
U F 5 4 0 0 G --U F 5 4 0 4 G
TJ=25
f=1MHz
60
50
40
30
1
4
10
100
REVERSE VOLTAGE,VOLTS
ht t p : //
1000
40
60
80
100
120 140 160 180
FIG.5 -- PEAK FORWARD SURGE CURRENT
150
125
8.3ms Single Half
Sine-Wave
100
AMPERES
80
Single Phase
Half Wave 60HZ
Resistive or
Inductive Load
AMBIENT TEMPERATURE,
JUNCTION CAPACITANCE,pF
1.0
0.5
FIG.4 -- TYPICAL JUNCTION CAPACITANCE
1.5
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
0.1
z
3.0
100
AMPERES
INSTANTANEOUS FORWARD CURRENT
FIG.2 -- TYPICAL FORWARD CHARACTERISTIC
75
50
25
www.lgesem i .c o m
2
5
10
NUMBER OF CYCLES AT 60Hz
很抱歉,暂时无法提供与“UF5404”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.49480
- 50+0.39690
- 150+0.34790
- 国内价格
- 5+0.56981
- 50+0.45663
- 150+0.40004
- 1250+0.35759
- 2500+0.32357
- 5000+0.30662
