HS1A - HS1M
1.0 AMPS. High Efficient Surface Mount Rectifiers
SMA/DO-214AC
Features
0. 181( 4. 60)
0. 161( 4. 10)
Glass passivated junction chip.
For surface mounted application
Low forward voltage drop
Low profile package
Built-in stain relief, ideal for automatic
placement
Fast switching for high efficiency
High temperature soldering:
260oC/10 seconds at terminals
Plastic material used carries Underwriters
Laboratory Classification 94V0
0. 209( 5. 30)
0. 193( 4. 90)
0. 012(0.30)
0. 006(0.15)
0.096(2.45)
0.078(2.00)
0. 059( 1. 50)
0. 035( 0. 90)
Mechanical Data
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
Cases: Molded plastic
Terminals: Pure tin plated, lead free
Polarity: Indicated by cathode band
Packing: 12mm tape
Weight: 0.064 gram
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
Maximum Ratings and Electrical Characteristics
Rating at 25 oC ambient temperature unless otherwise specified.
Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%
Symbol HS
Type Number
Maximum Recurrent Peak Reverse Voltage
Maximum RMS Voltage
Maximum DC Blocking Voltage
Maximum Average Forward Rectified Current
See Fig.1
Peak Forward Surge Current, 8.3 ms Single
Half Sine-wave Superimposed on Rated
Load (JEDEC method )
Maximum Instantaneous Forward Voltage
@ 1.0A
V RRM
V RMS
V DC
1A
HS
1B
HS
1D
HS
1F
HS
1G
HS
1J
HS
1K
50
35
50
100
70
100
200
140
200
300
210
300
400
280
400
600
420
600
800 1000
560 700
800 1000
A
IFSM
30
A
VF
1.0
1.3
1.7
V
75
15
uA
uA
nS
pF
5.0
150
IR
Maximum Reverse Recovery Time ( Note 1)
Trr
Typical Junction Capacitance ( Note 2 )
Cj
Maximum Thermal Resistance (Note 3)
R θJA
70
TJ
-55 to +150
-55 to +150
50
Storage Temperature Range
TSTG
1. Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A
Notes:
2. Measured at 1 MHz and Applied V R=4.0 Volts.
3. Mounted on P.C.Board with 0.2” x 0.2” (5mm x 5mm) Copper Pad Area.
ht t p : //
V
V
V
1.0
o
Revision:20170701-P1
Units
I(AV)
Maximum DC Reverse Current @ TA =25 C
o
at Rated DC Blocking Voltage @ TA=125 C
Operating Temperature Range
HS
1M
www.lgesemi .c o m
o
C/W
o
o
C
C
mail:lge@lgesemi.com
HS1A - HS1M
RATINGS AND CHARACTERISTIC CURVES (HS1A THRU HS1M)
FIG.2- TYPICAL REVERSE CHARACTERISTICS
FIG.1- MAXIMUM AVERAGE FORWARD CURRENT
DERATING
1000
1.0
INSTANTANEOUS REVERSE CURRENT. ( A)
AVERAGE FORWARD CURRENT. (A)
1.2
0.8
0.6
0.4
0.2
90
100
110
120
130
140
150
O
LEAD TEMPERATURE. ( C)
FIG.3- MAXIMUM NON-REPETITIVE FORWARD SURGE
CURRENT
Tj=100 0C
100
10
Tj=25 0C
1
PEAK FORWARD SURGE CURRENT. (A)
40
0.1
35
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE. (%)
30
8.3ms Single Half Sine Wave
JEDEC Method
25
FIG.5- TYPICAL INSTANTANEOUS
FORWARD CHARACTERISTICS
15
100
10
5
100
JUNCTION CAPACITANCE.(pF)
60
50
40
HS
30
HS
1J-
1A
-HS
HS
1G
1M
D
S1
-H
1A
HS
HS
70
Tj=25 0C
10
M
FIG.4- TYPICAL JUNCTION CAPACITANCE
1G
50
S1
-H
10
1J
5
NUMBER OF CYCLES AT 60Hz
HS
2
INSTANTANEOUS FORWARD CURRENT. (A)
1
0.1
10
0.5
1
2
5
10
100 200
500
0.01
.2
REVERSE VOLTAGE. (V)
.4
.6
.8
1.0
1.2
1.4
1.6
FORWARD VOLTAGE. (V)
FIG.6- REVERSE RECOVERY TIME CHARACTERISTIC AND TEST CIRCUIT DIAGRAM
50W
NONINDUCTIVE
10W
NONINDUCTIVE
trr
+0.5A
DUT
50Vdc
(approx)
PULSE
GENERATOR
(NOTE 2)
1W
NON
INDUCTIVE
OSCILLOSCOPE
(NOTE 1)
-0.25A
NOTES: 1. Rise Time=7ns max. Input Impedance=
1 megohm 22pf
2. Rise Time=10ns max. Sourse Impedance=
50 ohms
-1.0A
1cm
SET TIME BASE FOR
5/ 10ns/ cm
Version: B07
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
SMA
5000/REEL
80000
ht t p : //
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
36X30.6X31
12.00
11.00
www.lgesemi .c o m
很抱歉,暂时无法提供与“HS1M”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.25326
- 200+0.20078
- 600+0.17162
- 5000+0.12863
- 10000+0.11351
- 20000+0.10530
- 国内价格
- 1+0.54340
- 500+0.18150
- 2500+0.12100
- 5000+0.09889
- 国内价格
- 5+0.15301
- 20+0.13951
- 100+0.12601
- 500+0.11251
- 1000+0.10621
- 2000+0.10171
