S9012
S9012
    LGE(鲁光)
    SOT-23
    PNP硅外延平面晶体管 VCBO=40V VCEO=25V VEBO=5V SOT23
S9012 数据手册
S9012 SOT-23 Transistor(PNP) SOT-23 1. BASE 2. EMITTER 3. COLLECTOR Features — Complementary to S9013 Excellent hFE linearity — MARKING: J6 Dimensions in inches and (millimeters) MAXIMUM RATINGS (TA=25℃ unless otherwise noted) Symbol Value Units Collector-Base Voltage -40 V VCEO Collector-Emitter Voltage -25 V VEBO Emitter-Base Voltage -5 V IC Collector Current -Continuous -500 mA PC Collector Power Dissipation 300 mW VCBO Parameter Tj Junction Temperature 150 ℃ Tstg Storage Temperature -55-150 ℃ ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified) Parameter Symbol Test Collector-base breakdown voltage V(BR)CBO IC= -100μA, IE=0 -40 V Collector-emitter breakdown voltage V(BR)CEO IC= -1mA, IB=0 -25 V Emitter-base breakdown voltage V(BR)EBO IE=-100μA, IC=0 -5 V Collector cut-off current ICBO VCB=-40V, IE=0 -0.1 μA Collector cut-off current ICEO VCE=-20V, IB=0 -0.1 μA Emitter cut-off current IEBO VEB= -5V, IC=0 -0.1 μA DC current gain hFE VCE=-1V, IC= -50mA Collector-emitter saturation voltage VCE(sat) IC=-500mA, IB= -50mA -0.6 V Base-emitter saturation voltage VBE(sat) IC=-500mA, IB= -50mA -1.2 V Transition frequency fT Collector output capacitance Cob VCE=-6V, conditions IC= -20mA f=30MHz MIN TYP MAX 120 UNIT 400 150 MHz VCB=-10V,IE=0,f=1MHz 5 pF CLASSIFICATION OF hFE Rank L H J Range 120-200 200-350 300-400 ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com S9012 SOT-23 Transistor(PNP) Typical Characteristics ht t p : // Revision:20170701-P1 www.lgesemi .c o m mail:lge@lgesemi.com
S9012 价格&库存
很抱歉,暂时无法提供与“S9012”相匹配的价格&库存,您可以联系我们找货
S9012
  • 50+0.10520
  • 500+0.08306
  • 3000+0.06567
  • 6000+0.05832
  • 24000+0.05195
  • 51000+0.04850
库存:3001
S9012
  • 50+0.09643
  • 600+0.07613
  • 1200+0.07499
库存:1185
