S10M
S10M
    LGE(鲁光)
    SMC(DO-214AB)
    IAV=10A Single IR=5uA@1kV VF=1.1V@10A VRRM=1kV SMC(DO-214AB) 二极管-通用ROHS
S10M 数据手册
S10AC THRU S10MC Reverse Voltage :50 to 1000 Volts Forward Current :10.0 Ampere Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Low reverse leakage  Built-in strain relief,ideal for automated placement  High forward surge current capability  High temperature soldering guaranteed: 250 °C/10 seconds at terminals Mechanical Data Case : JEDEC DO-214AB/SMC molded plastic body Terminals : Solderable per MIL-STD-750,Method 2026 Polarity : Color band denotes cathode end Mounting Position : Any Weight : 0.0007 ounce, 0.25 grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) S10AC VRMM 50 35 50 VRMS VDC Maximum average forward rectified current at TL=75℃ Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 10.0A Maximum DC reverse current at rated DC blocking voltage SYMBOLS S10BC S10DC 100 70 100 200 140 200 400 280 400 S10JC S10KC 600 420 600 800 560 800 S10MC 1000 700 1000 UNITS V V V I(AV) 10.0 A IFSM 200 A VF 1.1 V IR 5 100.0 μA 100.0 pF 10.0 ℃/W -55 to +150 ℃ CJ RJA Operating junction and storage temperature range TJ,TSTG Note:1.Measured at 1 MHz and applied reverse voltage of 4 V D.C 2.P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 3.The typical data above is for reference only. http:// S10GC www.lgesemi.com S10AC THRU S10MC Ratings AND Charactieristic Curves Fig.1 Forward Current Derating Curve Fig.2 Typical Reverse Characteristics Instaneous Reverse Current(μA) Average Forward Current (A) 14 12 10 8.0 6.0 4.0 2.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 TJ=125° C 10 1.0 TJ=25° C 0.1 Case Temperature (°C) 00 20 40 60 80 100 120 Fig.3 Typical Forward Characteristic Fig.4 Typical Junction Capacitance Junction Capacitance (pF) Instaneous Forward Current (A) 10 1.0 TJ=25° C 100 10 TJ=25°C 0.1 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1 1.8 0.1 1.0 10 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 140 percent of Rated Peak Reverse Voltage (%) 240 200 160 120 80 40 00 8.3 ms Single Half Sine Wave (JEDE C Method) 1 10 100 Number of Cycles PACKAGE SPQ/PCS CARTON SPQ/PCS CARTON SIZE/CM CARTON GW/KG CARTON NW/KG SMC 3000/REEL 42000 36X36X36.5 18.50 15.50 http:// www.lgesemi.com 100
S10M
物料型号:S10AC至S10MC系列二极管。
器件简介:这些二极管符合RoHS标准,具有塑料封装,适用于表面贴装应用,具有低反向漏电流、内置的应变缓解,适合自动化放置,高正向浪涌电流能力,以及在终端上保证的高温焊接性。
引脚分配:文档中提到了极性,颜色带表示阴极端。
参数特性:包括最大重复峰值反向电压、最大RMS电压、最大直流阻断电压、在75°C时的最大平均正向整流电流、在10.0A时的最大瞬时正向电压、在额定直流阻断电压下的最大直流反向电流、典型结电容和典型热阻。
功能详解:文档提供了正向电流降额曲线、典型反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流的图表。
应用信息:适用于单相半波60Hz的电阻性或感性负载,对于电容性负载,电流需要降额20%。
封装信息:JEDEC DO-214AB/SMC塑封塑料体,可按照MIL-STD-750标准进行焊接。
很抱歉,暂时无法提供与“S10M”相匹配的价格&库存,您可以联系我们找货
