KBP301 THRU KBP307
SINGLE PHASE 3.0AMP GLASS PASSIVATED BRIDGE RECTIFIER
KBP
Features
14.5± 0.5
11.2± 0.5
3.2 45°
Mechanical Data
· Case: KBP, molded plastic
· Terminals: plated leads solderable per
AC
1.0 TYP.
15.2 MIN
MIL-STD-202, Method 208
· Polarity: as marked on case
· Mounting position: Any
· Marking: type number
4.8± 0.2
1.5 TYP.
Glass passivated die construction
Low forward voltage drop
High current capability
High surge current capability
Plastic material-UL flammability 94V-0
12.7 MIN
1.8 TYP.
1.8 TYP.
φ 0.8± 0.1
3.7± 0.25
3.7± 0.25
· Lead Free: For RoHS / Lead Free Version
Dimensions in millimeters
Maximum Ratings and Electrical Characteristics
Rating at 25℃ ambient temperature unless otherwise specified.
Single Phase, half wave, 60Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
TYPE NUMBER
SYMBOL
KBP
301
KBP
302
KBP
303
KBP
304
KBP
305
KBP
306
KBP
307
UNITS
50
100
200
400
600
800
1000
V
35
70
140
280
420
560
700
V
VRRM
Peak Repetitive Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRWM
RMS Reverse Voltage
VRMS
Average Rectified Output Current (Note 1)
@TC=10
00℃
IF(AV)
3.0
A
Non-Repetitive Peak Forward Surge Current 8.3ms
Single half sine-wave superimposed on rated load
(JEDEC Method)
IFSM
60
A
VDC
I2t Rating for Fusing (t < 8.3ms)
Forward Voltage per element
@IF=3.0A
Peak Reverse Current
At Rated DC Blocking Voltage
@TA=25℃
@TA=125℃
Typical Thermal Resistance per leg (Note 2)
Operating and Storage Temperature Range
I2t
14.94
VFM
1.1
V
IR
5.0
500
uA
RθJA
30
RθJL
11
TJ,TSTG
-55to+150
A2s
℃/W
Note:1. Mounted on glass epoxy PC board with 1.3mm2 solder pad.
2. Measured at 1.0 MHz and applied reverse voltage of 4.0V D.C..
Revision:20170701-P1
ht t p : //
www.lgesemi .c o m
mail:lge@lgesemi.com
KBP301 THRU KBP307
Fig. 2 Typical Fwd Characteristics
IF, INSTANTANEOUS FWD CURRENT (A)
IO, AVERAGE RECTIFIED CURRENT (A)
Fig. 1 Forward Current Derating Curve
3.0
2.0
1.0
10
TA= 25°C
0.1
Pulse Width
= 300 µs
100
T,TEMPERATURE (°C)
0.6
0.8
1.0
1.2
1.4
Fig. 4 Typical Junction Capacitance
100
100
Single Half Sine-Wave
Pulse Width =8.3ms
(JEDEC Method)
f = 1MHz
Cj, JUNCTION CAPACITANCE (pF)
IFSM, PEAK FWD SURGE CURRENT (A)
0.4
VF, INSTANTANEOUS FWD VOLTAGE (V)
Fig. 3 Max Non-Repetitive Peak Fwd Surge Current
50
40
30
10
10
100
VR, REVERSE VOLTAGE (V)
NUMBER OF CYCLES AT 60 Hz
IR, INSTANTANEOUS REVERSE CURRENT (A)
Fig. 5 T ypical Reverse Characteristics (per element)
100
TJ = 125C
10
1.0
TJ = 25C
0.1
0.01
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“KBP307”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.71040
- 50+0.56928
- 100+0.56074
- 200+0.49872
- 500+0.44580
- 2500+0.40347
