WS2812D-F5
WS2812D-F5
    WORLDSEMI
    LED_D5.8X8.6MM_TM
    LED 三色 RGB D=5mm 直插(注意防潮,请查阅规格书中对应具体内容)
WS2812D-F5 数据手册
WS2812D-F5-1261 Intelligent control LED integrated light source Features and Benefits     The control circuit and the LED share the only power source. Control circuit and RGB chip are integrated in a package of F5 plug-in components, to form a complete addressable pixel. Built-in signal reshaping circuit, after wave reshaping to the next driver, ensure wave-form distortion not accumulate. Built-in electric reset circuit and power lost reset circuit. Each pixel of the three primary color can achieve 256 brightness display, completed 16777216 color full color display, and scan frequency is of 2KHz. Cascading port transmission signal by single line. When the refresh rate is 30fps, cascade number are not less than 1024 pixels. Send data at speeds of 800Kbps. The color of the light is highly consistent, cost-effective.  Reverse-connection protection.      Applications  Full-color module, LED full-color soft/hard light bar, LED guardrail tube.  LED decorative lighting, LED Screen, Indoor/outdoor LED video irregular screen, various electronic products, electrical equipment marquee. General description WS2812D-F5-1261 is an intelligent external control LED light source that integrates control circuit and light-emitting circuit. Its appearance is the same as an F5 LED lamp bead, and each element is a pixel.It internal include intelligent digital port data latch and signal reshaping amplification drive circuit.Also include a precision internal oscillator and a voltage programmable constant current control part, effectively ensuring the pixel point light color height consistent. The data transfer protocol use single NZR communication mode. After the pixel power-on reset, the DIN port receive data from controller, the first pixel collect initial 24bit data then sent to the internal data latch, the other data which reshaping by the internal signal reshaping amplification circuit sent to the next cascade pixel through the DO port. After transmission for each pixel, the signal to reduce 24bit. pixel adopt auto reshaping transmit technology, making the pixel cascade number is not limited the signal transmission, only depend on the speed of signal transmission. LED with low driving voltage, environmental protection and energy saving, high brightness, scattering angle is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, convenient installation. 1 http://www.world-semi.com WS2812D-F5-1261 Intelligent control LED integrated light source Mechanical Dimensions(Unit:mm) PIN Function NO. Symbol PIN Function description 1 Dout DATA OUT Control data signal output 2 VCC POWER SUPPLY 3 GND GROUND Ground,data & power grounding 4 Din DATA IN Control data signal input Power supply Absolute Maximum Ratings(TA=25℃, VCC=5V, VSS=0V, unless otherwise specified) Parameter Symbol Ratings Unit Power supply voltage Vcc +3.7~+5.3 V Logical Input Voltage VI -0.3V~VCC+0.7V V Operation junction temperature Topt -25~+85 ℃ Storage temperature range Tstg -40~+105 ℃ 2 http://www.world-semi.com WS2812D-F5-1261 Intelligent control LED integrated light source Electrical Characteristics(TA=-20~+70℃,VCC=5V,VSS=0V,unless otherwise specified) Parameter Symbol Min Tpy Max Unit Conditions RGB Current Iout 32 36 40 mA R+G+B Input current II —— —— ±1 µA VI=VCC/VSS High Voltage Input VIH 2.7V —— VCC+0.7V V DIN Low Voltage Input VIL -0.3V —— 0.7V V DIN Switching Characteristics(TA=-20~+70℃,VCC=5V,VSS=0V,unless otherwise specified) Parameter Symbol Min Tpy Max Unit Condition Oscillation frequency Fosc —— 800 —— KHz —— Transmission delay time tPLZ —— —— 300 ns CL=15pF, DIN→DOUT, RL=10KΩ Fall time tTHZ —— —— 120 µs CL=300pF, OUTR/OUTG/OUTB Input capacity CI —— —— 15 pF —— LED light chip parameters Quiescent Current: 0.6mA Parameter Brightness Wavelength Symbol IV λd Color Mini Typ Max Red 250 -- 350 Green 500 -- 700 Blue 80 -- 150 Red 620 -- 625 Green 520 -- 530 Blue 465 -- 475 Unit mcd nm Sequence waveform Sequence Chart Cascade Method D1 DIN DO PIX1 3 http://www.world-semi.com D2 DIN DO PIX2 D3 DIN DO PIX3 D4 WS2812D-F5-1261 Intelligent control LED integrated light source Data Transfer Time: 0 code, high voltage time 220ns~380ns T1H 1 code, high voltage time 580ns~1µs T0L 0 code, low voltage time 580ns~1µs T1L 1 code, low voltage time 580ns~1µs RES Frame unit, low voltage time >280µs Title T0H Data Transmission Method Note: The data of D1 is send by MCU, and D2, D3, D4 through pixel internal reshaping amplification to transmit. R6 R5 R4 R3 R2 R1 R0 G7 G6 G4 G3 WS2812D R7 Din GND VDD Dout Composition of 24bit Data G5 G2 G1 G0 B7 B6 B5 Note: Data transmit in order of RGB, high bit data at first. WS2812D Ln Din GND VDD Dout 4 3 2 1 75R L2 4 3 2 1 WS2812D Din GND VDD Dout http://www.world-semi.com 4/5 5V 104 Cn 5V 104 75R C2 104 C1 5V DIN 75R 4 3 2 1 L1 Typical Application Circuit: Dout B4 B3 B2 B1 B0 WS2812D-F5-1261 Intelligent control LED integrated light source Modify Record Version № Status Bar Modify Content Summary Date Reviser Approved V1.0 N New 20181201 Shen JinGuo Yin HuaPing V1.1 M Outline drawing. Luminous chip 20190507 Shen JinGuo Yin HuaPing parameters, maximum rating, data transmission time. Remarks: Initial version: V1.0;Version number plus "0.1" after each revision; Status bar: N--New, A--Add, M--Modify, D--Delete. http://www.world-semi.com 5/5
WS2812D-F5 价格&库存
很抱歉,暂时无法提供与“WS2812D-F5”相匹配的价格&库存,您可以联系我们找货
WS2812D-F5
  • 1+4.65705
  • 5+3.38019
  • 25+2.66870
  • 100+1.77873
  • 500+1.45533
  • 1000+1.33435
库存:9135
WS2812D-F5
  • 1+0.85360
  • 50+0.65670
  • 500+0.60500
库存:3
WS2812D-F5
  • 1+5.008601+0.65088
  • 5+3.634725+0.47234
  • 25+2.8695125+0.37290
  • 100+1.91301100+0.24860
  • 500+1.56519500+0.20340
  • 1000+1.434761000+0.18645
库存:9140
WS2812D-F5
  • 5+1.23012
  • 50+0.93906
  • 150+0.81422
  • 500+0.64854
  • 2500+0.57921
库存:3938
