SZA33A
SZA33A
    MSV(萌盛微)
    SMAF
    硅平面稳压二极管
SZA33A 数据手册
MSV SZA33A Silicon Planar Zener Diodes PINNING PIN FEATURES • Total power dissipation: Max. 1 W. • Wide zener reverse voltag e 33 V . • Small plastic package suitable for surface mounted design. MECHANICAL DATA • Case:SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 27mg 0.00095oz DESCRIPTION 1 Cathode 2 Anode 1 2 Simplified outline SMAF and symbol Absolute Maximum Ratings And Characteristics (Ta = 25 °C) Symbol Value Unit Power Dissipation at T c =75°C PD 1 W Forward Voltage at I F = 200 mA VF 1.2 V Junction Temperature Range TJ - 55 to + 150 °C Storage Temperature Range TS - 55 to + 150 °C Parameter Fig.1 Maximum Continuous Power Derating 1.2 Power Dissipation ( W ) 1.0 0.8 0.6 0.4 0.2 0.0 25 50 75 100 125 150 175 T c ,Case Temperature (°C) Characteristics at Ta = 25°C Dynamic Impedance Zener Voltage Range (1) Type SZA33A Marking Z33 V ZT(at I ZT) Reverse Current I ZT Z ZT(at I ZT) IR at V R Admissible Zener Current Min(V) Nom(V) Max(V) (mA) Max (Ω) Max(μA) (V) I ZM (mA) 31.3 33 34.9 7.5 45 5 25 28 www.mswdz.com Page 1 of 2 MSV SZA33A PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 ∠ 7° The recommended mounting pad size 1.6 (63) 2.2 (86) 1.6 (63) 1.8 (71) mil Bottom View A UNIT mm g pad e E A pad D E A V M mm Unit : (mil) www.mswdz.com Page 2 of 2
SZA33A
- 物料型号:SZA33A - 器件简介:文档提到了该器件的总功率耗散最大为1瓦,具有宽齐纳反向电压范围,并且小巧的塑料封装适合于表面安装设计。 - 引脚分配:文档中指出了两个引脚,1号引脚是阳极(Anode),2号引脚是阴极(Cathode)。 - 参数特性:包括齐纳电压范围、动态阻抗、反向电流等,具体数值如下: - 齐纳电压(VZT):33V - 正向电压(FVF):在200mA电流时为1.2V - 动态阻抗(ZZT):7.5Ω - 反向电流(IR):最大45μA - 功能详解:文档提供了最大连续功率耗散的图表,展示了在不同结温下功率耗散的降低情况。 - 应用信息:文档中没有明确提供应用信息,但根据器件的特性,可以推断它可能用于电压调节和保护电路。 - 封装信息:器件采用塑料表面安装封装(SMAF),引脚为可焊性,符合MIL-STD-750标准。
SZA33A 价格&库存
很抱歉,暂时无法提供与“SZA33A”相匹配的价格&库存,您可以联系我们找货
