SY8047QDC
SY8047QDC
    SILERGY(矽力杰)
    QFN16_3X3MM_EP
    超低静态电流 1.25MHz,4A同步降压稳压器 QFN16_3X3MM_EP
SY8047QDC 数据手册
SY8047 Ultra Low Quiescent Current 1.25MHz, 4A Synchronous Step Down Regulator General Description Features SY8047 is a high efficiency ultra low quiescent current, 1.25MHz synchronous step-down DC-DC regulator IC capable of delivering up to 4A output current. SY8047 operates over a wide input voltage range from 2.5V to 5.5V and integrates main switch and synchronous switch with very low RDS (ON) to minimize the conduction loss.           Ordering Information Input voltage range: 2.5V to 5.5V 1.25MHz switching frequency Max output current: 4.0A Peak current mode control for the fast transient speed 100% drop out function Typical 18uA quiescent current Low RDS(ON) for internal switches (PFET/NFET): 75mΩ/55mΩ Hic-cup mode protection for hard short condition RoHS Compliant and Halogen Free Compact package: QFN3x3-16 SY8047 □(□□)□ Temperature Code Package Code Optional Spec Code Ordering Number Package Type SY8047QDC QFN3x3-16 Applications     Note 4A Set Top Box Net PC Mini-Notebook PC Access Point Router Typical Applications Efficiency vs. Load Current 96 94 L1: 1.0uH VIN:2.5V to 5.5V RH 100k SVIN 1uF SY8047 FB 100k ON/ OFF SS RL 49.9k CSS:1nF EN PGND AGND Cff 22pF COUT: 22uF/6.3Vx2 Efficiency (%) 10Ω PG 92 LX PVIN CIN: 22uF/6.3V VOUT:1.8V 90 88 86 VIN=3.3V,VOUT=1..8V VIN=4.2V,VOUT=1.8V VIN=5.0V,VOUT=1.8V 84 82 80 1 10 100 1000 10000 Load Current (mA) Figure 1. Schematic Diagram SY8047 Rev.0.9 © 2018 Silergy Corp. Figure 2. Efficiency Figure Silergy Corp. Confidential-Prepared for Customer Use Only 1 All Rights Reserved. SY8047 NC 3 PG 4 EN PGND PGND 13 Exposed Thermal Pad 12 PVIN 11 PVIN 10 SVIN 9 5 6 7 SS 8 NC 2 14 NC LX 15 AGND 1 16 FB LX NC Pinout (top view) ① Part Number Package type Top Mark SY8047QDC QFN3x3-16 VJxyz Note① : x=year code, y=week code, z= lot number code. Pin Name LX NC Pin Number 1, 2 3, 7, 8, 16 PG 4 FB 5 AGND 6 SS 9 SVIN 10 PVIN 11, 12 EN PGND 13 14, 15 Pin Description Inductor pin. Connect this pin to the switching node of inductor No connection Power good indicator(Open drain output). Low if the output < 90% of regulation voltage; High otherwise. Connect a pull-up resistor to the input. Output feedback pin. Connect this pin to the center point of the output resistor divider (as shown in Figure 1) to program the output voltage: VOUT=0.6V*(1+RH/RL). Analog ground pin. Soft-start programming pin. Do not float this pin. Connect a capacitor from this pin to ground to program the soft-start time. tSS=Max(60µs, CSS×0.6V/1.6µA). Supply voltage for control circuit. Decouple this pin to ground with at least 1uF ceramic cap. Supply voltage for power circuit. Decouple this pin to ground with at least 22uF ceramic cap. Enable input pin. Integrated 4MΩ pull down resistor. Power ground pin. Absolute Maximum Ratings (Note 1) All pins --------------------------------------------------------------------------------------------------------------------------- 6V Power Dissipation, PD @ TA = 25°C, QFN3x3---------------------------------------------------------------------------- 2.6W Package Thermal Resistance (Note 2) θ JA --------------------------------------------------------------------------------------------------------------- 38°C/W θ JC ---------------------------------------------------------------------------------------------------------------- 8°C/W Junction Temperature Range ---------------------------------------------------------------------------------------------- 150°C Lead Temperature (Soldering, 10 sec.) ---------------------------------------------------------------------------------- 260°C Storage Temperature Range ------------------------------------------------------------------------------------ -65°C to 150°C Recommended Operating Conditions (Note 3) Supply Input Voltage ----------------------------------------------------------------------------------------------- 2.5V to 5.5V Junction Temperature Range ----------------------------------------------------------------------------------- -40°C to 125°C Ambient Temperature Range ------------------------------------------------------------------------------------ -40°C to 85°C SY8047 Rev.0.9 © 2018 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 2 All Rights Reserved. SY8047 Electrical Characteristics (VIN = 5V, VOUT = 2.5V, L = 1.0uH, COUT = 22uFx2, TA = 25°C, unless otherwise specified) Parameter Input Voltage Range Quiescent Current Shutdown Current Feedback Reference Voltage PFET RON NFET RON Peak Current Limit EN rising threshold EN falling threshold Input UVLO threshold UVLO hysteresis Oscillator Frequency PGOOD Under-voltage Threshold Short Circuit Protection Threshold Min ON Time Symbol VIN IQ ISHDN VREF RDS(ON),P RDS(ON),N ILIM VENH VENL VUVLO VHYS FOSC VFB,LV VSCP Test Conditions 0.15 1.25 0.55 0.26 80 Unit V µA µA V mΩ mΩ A V V V V MHz V V ns Soft Start Current ISS TSS  1.6 µA Soft Start time Output Discharge Switch On Resistance Thermal Shutdown Temperature Thermal Shutdown Hysteresis TSS CSS=1nF 400 µs RDSC 50 Ω TSD THYS 150 15 °C °C IOUT=0, VFB=VREF  105% EN=0 Min 2.5 0.591 Typ 18 0.1 0.6 75 55 Max 5.5 1 0.609 5 1.5 0.4 2.5 IOUT=500mA 0.6V  CSS I SS Note 1: Stresses beyond the “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only. Functional operation of the device at these or any other conditions beyond those indicated in the operational sections of the specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. Note 2: θ JA is measured in the natural convection at T A = 25°C on a low effective single layer thermal conductivity test board of JEDEC 51-3 thermal measurement standard. Note 3: The device is not guaranteed to function outside its operating conditions. SY8047 Rev.0.9 © 2018 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 3 All Rights Reserved. SY8047 Block Diagram SVIN Internal Power PVIN Input UVLO 2.5V Current limiting Sensor EN 1.5V LX Control Logic + FB SS PG SY8047 Rev.0.9 © 2018 Silergy Corp. - 0.6V Internal SST GND Thermal Sensor Silergy Corp. Confidential-Prepared for Customer Use Only 4 All Rights Reserved. SY8047 QFN3x3-16 Package outline & PCB Layout Top View PC B layout (Recommended) Side View Detail A Pin1 identifier: two options Bottom View Notes: All dimension in millimeter and exclude mold flash & metal burr. SY8047 Rev.0.9 © 2018 Silergy Corp. Silergy Corp. Confidential-Prepared for Customer Use Only 5 All Rights Reserved. SY8047 Taping & Reel Specification 1. QFN3x3-16 taping orientation 3.9/4.1 11.7/12.3 1.45/1.55 Feeding direction 2. Carrier Tape & Reel specification for packages Reel Size Package types QFN3x3 Tape width (mm) Pocket pitch(mm) Reel size (Inch) Trailer length(mm) Leader length (mm) Qty per reel 12 8 13" 400 400 5000 3. Others: NA SY8047 Rev.0.9 © 2018 Silergy Corp. Powered by TCPDF (www.tcpdf.org) Silergy Corp. Confidential-Prepared for Customer Use Only 6 All Rights Reserved.
SY8047QDC
物料型号:SY8047
器件简介: - SY8047是一款高效率、超低静态电流的1.25MHz同步降压DC-DC调节器IC,能够提供高达4A的输出电流。 - 工作电压范围宽,从2.5V到5.5V。 - 集成了主开关和同步开关,具有非常低的导通电阻(RDS(ON)),以最小化导通损耗。
引脚分配: - 引脚1和2(LX):电感引脚,连接到电感的开关节点。 - 引脚3、7、8、16(NC):无连接。 - 引脚4(PG):电源良好指示(开漏输出)。如果输出低于调节电压的90%,则为低;否则为高。需要连接上拉电阻到输入。 - 引脚5(FB):输出反馈引脚。连接到输出电阻分压器的中点(如图1所示)以编程输出电压。 - 引脚6(AGND):模拟地引脚。 - 引脚9(SS):软启动编程引脚。不要悬空此引脚。从这个引脚到地连接一个电容器以编程软启动时间。 - 引脚10(SVIN):控制电路的供电电压。至少与1uF陶瓷电容解耦到地。 - 引脚11和12(PVIN):电源电路的供电电压。至少与22uF陶瓷电容解耦到地。 - 引脚13(EN):使能输入引脚。集成了4M的下拉电阻。 - 引脚14和15(PGND):电源地引脚。
参数特性: - 输入电压范围:2.5V至5.5V - 静态电流:典型值18uA - 关断电流:0.1uA至1uA - 反馈参考电压:0.591V至0.609V - PFET导通电阻(RDS(ON),P):75mΩ - NFET导通电阻(RDS(ON).N):55mΩ - 峰值电流限制:5A - 使能上升阈值(VENH):1.5V - 使能下降阈值(VENL):0.4V - 输入欠压锁定阈值(VUVLO):2.5V - 欠压锁定滞后(VHYS):0.15V - 振荡频率(Fosc):1.25MHz - PGOOD欠压阈值(VFB.LV):0.55V - 短路保护阈值(VSCP):0.26V - 最小开启时间:80ns - 软启动电流(Iss):1.6uA - 软启动时间(Tss):400us(当Css=1nF时) - 输出放电开关导通电阻(Rpsc):50mΩ - 热关断温度(TsD):150℃ - 热关断滞后(THYS):15℃
功能详解: - 具有100%的掉电功能。 - 硬短路条件下的hic-cup模式保护。 - 符合RoHS和无卤素要求。 - 紧凑的封装:QFN3x3-16。
应用信息: - 适用于机顶盒、网络PC、迷你笔记本电脑、接入点、路由器等。
封装信息: - 封装类型:QFN3x3-16 - 封装标记:VJxyz(x=年份代码,y=周代码,z=批次号代码)
SY8047QDC 价格&库存
很抱歉,暂时无法提供与“SY8047QDC”相匹配的价格&库存,您可以联系我们找货
