YG602020
YG602020
    INNPTION(英诺迅)
    SOT89-4
    50MHz到4000MHz增益块MMIC放大器
YG602020 数据手册
INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier Features GND 4 ■ Operating Frequency 50MHz to 4GHz ■ 18dB Gain at 2.0GHz ■ 22dBm P1dB at 2.0GHz ■ 32dBm OIP3 at 2.0GHz ■ Single Power Supply ■ Integrated Active Bias Circuit ■ Industry Standard SOT-89 Package 1 2 3 IN GND OUT N O Functional Block Diagram ■ ESD protection all ports above 1000V HBM I T O Applications ■ WLAN / WiMAX / WiBro ■ GSM / CDMA / PCS ■ CMMB ■ RFID ■ WCDMA / LTE N N I ■ GPS / COMPASS Product Description ■ CATV ■ ISM The YG602020 is a high performance InGaP HBT MMIC gain block amplifier utilizing a Darlington pair configuration with an active bias network. The active bias network provides stable current over temperature and process variations. The YG602020 is internally matched to 50Ω, its typical bias condition is a single 5V, and does not require a dropping resistor as compared to typical Darlington amplifiers. The YG602020 is assembled in an industry standard SOT-89 package. It is internally integrated with ESD protection unit. Pin Description Pin No. Symbol Description 1 IN RF input 3 OUT RF output and bias 2, 4 GND Ground connected Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 1 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier Absolute Maximum Ratings Parameter Rating Unit Input RF Power +25 dBm Supply Voltage -0.5 to +6.0 V Device Current 200 mA Operating Ambient Temperature -40 to +85 °C Storage Temperature -40 to +150 °C Caution! Exceeding any one or a combination of the Absolute Maximum Rating conditions may cause permanent damage to the device. Extended application of Absolute Maximum Rating conditions to the device may reduce device reliability. Electrical Specifications Parameter Small Signal Gain Specification Min. Typ. 15.4 Max. Condition dB 2450MHz dB 2000MHz dB 900MHz dB 433MHz dBm 2450MHz dBm 2000MHz dBm 900MHz dBm 433MHz dB 2450MHz dB 2000MHz dB 900MHz dB 433MHz dB 2450MHz dB 2000MHz 19.6 dB 900MHz 10.6 dB 433MHz 25.7 dB 2450MHz 27.9 dB 2000MHz 30.6 dB 900MHz 30.9 dB 433MHz 32.5 dBm 2450MHz 32.3 dBm 2000MHz 31.2 dBm 900MHz 30.5 dBm 433MHz Noise Figure 4.0 dB 2400MHz Supply Voltage 5.0 V Device Current 72 mA I T O 18.0 23.4 26.9 P1dB Output Power 21.0 22.2 20.2 N N I 18.0 Input Return Loss 27.0 20.1 12.6 12.3 Output Return Loss 9.1 7.4 Reverse Isolation OIP31) N O Unit 1) OIP3 measured with two tones at an output power of 0dBm/ tone separated by 1MHz. Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 2 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier Typical Performance WLAN (2400~2500MHz) Application: VCC=5V 2.2uF 1nF 30pF 30nH RF IN 30pF 30pF I T O 30 30 20 25 10 N N I S11 S21 0 -10 -20 -30 -40 2.40 2.41 2.42 2.43 2.44 2.45 2.46 2.47 2.48 20 P1dB (dBm) S11, S21 (dB) N O RF OUT YG602020 15 10 5 2.49 0 2.40 2.50 2.41 2.42 2.43 36 34 2.45 2.46 2.47 2.48 2.49 2.50 5.0 4.5 2.45GHz 32 2.44 Frequency (GHz) Frequency (GHz) 4.0 2.442GHz 30 EVM(%) OIP3 (dBm) 3.5 28 26 3.0 2.5 2.0 1.5 24 1.0 22 0.5 0.0 20 0 1 2 3 4 5 6 7 8 9 10 5 6 7 8 Output Power (dBm) Innotion All rights reserved. http://www.innotion.com.cn 9 10 11 12 13 14 15 16 Output Power (dBm) 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 3 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier WCDMA (1900~2200MHz) Application: VCC=5V 2.2uF 1nF 30pF 30nH RF IN RF OUT YG602020 30pF 30pF I T O S11 S21 10 0 -10 -20 -30 1900 20 N N I 1950 2000 2050 2100 2150 25 P1dB(dBm) S11, S21(dB) 20 15 36 5 0 1900 2200 1950 2000 32 2050 2100 2150 2200 Frequency(MHz) -40 -42 1.95GHz 34 P1dB 10 Frequency(MHz) -44 1.95GHz -46 30 ACPR(dBc) OIP3(dBm) N O 30 30 28 26 -48 -50 -52 -54 24 -56 22 -58 20 -60 0 1 2 3 4 5 6 7 8 9 10 5 6 7 8 Output Power(dBm) Innotion All rights reserved. http://www.innotion.com.cn 9 10 11 12 13 14 15 16 Output Power(dBm) 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 4 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier GPS/COMPASS Application: VCC=5V 2.2uF 1nF 100pF 43nH RF IN RF OUT YG602020 100pF 100pF 30 S11 S21 30 20 0 -10 -20 -30 1500 N N I 1520 1540 1560 1580 1600 1620 1640 1660 Frequency(MHz) 36 34 15 10 5 1680 1700 0 1500 1520 1540 1560 1580 1600 1620 1640 1660 1680 1700 Frequency(MHz) 1610MHz 32 OIP3(dBm) 25 P1dB(dBm) S11, S21(dB) 20 10 N O I T O 40 30 28 26 24 22 20 0 1 2 3 4 5 6 7 8 9 10 Output Power(dBm) Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 5 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier GSM (890~960MHz) Application: VCC=5V 2.2uF 1nF 100pF 68nH RF IN RF OUT YG602020 100pF 100pF 30 25 0 -10 -20 -30 -40 800 N N I 820 840 860 880 900 920 940 960 S11 S21 20 P1dB(dBm) S11, S21(dB) 20 10 15 10 5 980 1000 0 890 900 910 Frequency(MHz) 36 N O I T O 30 40 920 930 940 950 960 Frequency(MHz) 900MHz 34 OIP3(dBm) 32 30 28 26 24 22 20 0 1 2 3 4 5 6 7 8 9 10 Output Power(dBm) Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 6 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier ISM (433MHz) Application Circuit: VCC=5V 2.2uF 1nF 220pF 82nH RF IN RF OUT YG602020 220pF 220pF 30 30 25 S11 S21 10 0 -10 -20 -30 400 N N I 410 420 430 440 450 460 470 480 Frequency(MHz) 36 15 10 5 490 500 0 400 405 410 415 420 425 430 435 440 445 450 Frequency(MHz) 433MHz 34 32 OIP3(dBm) 20 P1dB(dBm) S11, S21(dB) 20 N O I T O 40 30 28 26 24 22 20 0 1 2 3 4 5 6 7 8 9 10 Output Power(dBm) Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 7 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier 100~200 MHz Application Circuit: VCC=5V 2.2uF 1nF 470pF 180nH 24Ω RF IN RF OUT YG602020 470pF 470pF 24 S11 S21 30 20 20 0 -10 -20 -30 100 N N I 110 120 130 140 150 160 170 180 Frequency(MHz) 34 32 P1dB(dBm) S11,S21(dB) 16 10 N O I T O 40 12 8 4 190 200 0 100 110 120 130 140 150 160 170 180 190 200 Frequency(MHz) 140MHz OIP3(dBm) 30 28 26 24 22 20 0 1 2 3 4 5 6 7 8 9 10 Pout (dBm) Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 8 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier Packaging Diagram Units: inches(millimeters) N O I T O N N I Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 9 of 10 INNOTION YG602020 50MHz to 4000MHz Gain Block MMIC Amplifier Suggested PCB Land Pattern Units: inches(millimeters) N O I T O N N I Notes: The suggested PCB land pattern is for 0.8mm thickness FR4 PCB. Innotion All rights reserved. http://www.innotion.com.cn 2012-02-28 For sales, orders, and technical support, please contact us, Phone: (86-512-62997198) Version 2.0 Page 10 of 10
YG602020 价格&库存
很抱歉,暂时无法提供与“YG602020”相匹配的价格&库存,您可以联系我们找货
