PDCSD12C
PDCSD12C
    PDW(江苏芯格诺)
    SOD-323
    截止电压(Vrwm):12V (最大值) 峰值脉冲电流(8/20us):15A 极性:双向 最大钳位电压:25V 击穿电压(最小值):13.3V
PDCSD12C 数据手册
ESD Protection Diode PDCSD12C Description Features The PDCSD12C is a 12V bi-directional TVS diode, utilizing leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this device an ideal solution for protecting voltage sensitive data and power line. The PDCSD12C-T complies with the IEC 61000-4-2 (ESD) standard with ±30 kV air and ±30 kV contact discharge. It is assembled into an ultra-small lead-free SOD-323 package.The small size and high ESD surge protection make PDCSD12C-T an ideal choice to protect cell phone, digital cameras, audio players and many other portable applications.  375W peak pulse power(8 /20μs)  Protects one data or power line  Ultra low leakage:nA level  Operating voltage:12V  Low clamping voltage  2-pin leadless package  Complies with following standards: – IEC 61000-4-2 (ESD) immunity test Air discharge: ±30kV Contact discharge: ±30kV – IEC61000-4-5 (Lightning) 15A (8/20µs)  RoHS Compliant Mechanical Characteristics Applications  Package: SOD-323  Case Material: “Green” Molding Compound.  Moisture Sensitivity: Level 3 per J-STD-020  Terminal Connections: See Diagram Below  Marking Information: See Below        Dimensions and Pin Configuration Marking Information Cellular Handsets and Accessories Personal Digital Assistants Notebooks and Handhelds Portable Instrumentation Digital Cameras Peripherals Audio Players 12 12 = Device Marking Code Circuit and Pin Schematic Ordering Information Part Number Marking Packaging Reel Size PDCSD12C 12 10000/Tape & Reel 7 inch www.pdwsemi.com 1 -4 © 2022 PDW, Inc. Specifications are subject to change without notice. Revised: 2022/04/08 ESD Protection Diode PDCSD12C Absolute Maximum Ratings (TA=25°C unless otherwise specified) Parameter Symbol Value Unit Peak Pulse Power (8/20µs) Ppk 375 W Peak Pulse Current (8/20µs) Ipp 15 A ESD per IEC 61000−4−2 (Air) ±30 VESD ESD per IEC 61000−4−2 (Contact) Operating Temperature Range Storage Temperature Range kV ±30 TJ −55 to +125 °C Tstg −55 to +150 °C Electrical Characteristics (TA=25°C unless otherwise specified) Parameter Reverse Working Voltage Breakdown Voltage Symbol Min Typ VRWM VBR Max Unit 12 V 13.3 Test Condition V IT = 1mA Reverse Leakage Current IR 0.5 μA VRWM = 12V Clamping Voltage VC 16 V IPP = 1A (8 x 20µs pulse) Clamping Voltage VC 25 V IPP = 15A (8 x 20µs pulse) Junction Capacitance CJ pF VR = 0V, f = 1MHz www.pdwsemi.com 35 2 -4 © 2022 PDW, Inc. Specifications are subject to change without notice. Revised: 2022/04/08 ESD Protection Diode PDCSD12C Typical Performance Characteristics (TA=25℃ unless otherwise Specified) Junction Capacitance vs. Reverse Voltage Peak Pulse Power vs. Pulse Time Clamping Voltage vs. Peak Pulse Current Power Derating Curve ESD Clamping Voltage 8 X 20μs Pulse Waveform www.pdwsemi.com 8 kV Contact per IEC61000−4−2 3 -4 © 2022 PDW, Inc. Specifications are subject to change without notice. Revised: 2022/04/08 ESD Protection Diode PDCSD12C SOD-323 Package Outline Drawing A DIMENSIO MILLIMETERS INCHES MIN MAX MIN MAX 1.50 1.80 0.060 0.071 SYM B 1.20 1.40 0.045 0.054 C 2.30 2.70 0.090 0.107 D - 1.10 - 0.043 E 0.30 0.40 0.012 0.016 F 0.10 0.25 0.004 0.010 H - 0.10 - 0.004 Suggested Land Pattern SYM www.pdwsemi.com 4 -4 DIMENSIONS MILLIMETERS INCHES A 3.15 0.120 B 0.80 0.031 C 0.80 0.031 © 2022 PDW, Inc. Specifications are subject to change without notice. Revised: 2022/04/08
PDCSD12C 价格&库存
很抱歉,暂时无法提供与“PDCSD12C”相匹配的价格&库存,您可以联系我们找货
