FT8215Q
FT8215Q
    FORTIORTECH(峰岹科技)
    QFN-24-EP(4x4)
    FT8215Q 是一款三相内置 MOSFET 无传感器磁场定向控制直流无刷马达驱动 IC。芯片高度集成,外围元器件少,电机噪声低,转矩脉动小。GUI 可配置客户电机参数、启动和调速方式,并储存在内置的...
FT8215Q 数据手册
FT8215Q Fortior Tech FT8215Q Datasheet www.fortiortech.com FT8215Q 目 1 2 录 系统介绍 ................................................................................................................................... 3 1.1 概述 ......................................................................................................................................... 3 1.2 应用场景 ................................................................................................................................. 3 1.3 特性 ......................................................................................................................................... 3 1.4 应用电路 ................................................................................................................................. 4 1.5 功能框图 ................................................................................................................................. 5 1.6 封装 ......................................................................................................................................... 6 1.7 引脚定义 ................................................................................................................................. 7 封装信息 ................................................................................................................................... 8 2.1 QFN24 .................................................................................................................................... 8 3 定购信息 ................................................................................................................................... 9 4 修改记录(DOCUMENT CHANGE LIST)........................................................................ 10 REV_V1.0 2 www.fortiortech.com FT8215Q FT8215Q 三相内置 MOSFET 无传感器磁场定向控制器 1 系统介绍 1.1 概述 1.3 特性 FT8215Q 是 一 款 三 相 、 无 传 感 器 ⚫ FOC 控制直流无刷马达驱动 IC,内置驱 无传感器磁场定向控制(FOC),减 小电机噪声和振动 动 MOS。芯片高度集成电机控制所需部件, ⚫ 恒转速、恒电流或开环控制模式 所需外围元器件少,噪声低,电机转矩脉 ⚫ 模拟/PWM/I2C/CLOCK 调速 动小。内置 EEPROM,可配置客户电机参数、 ⚫ I2C 接口用于电机控制和状态回读 启动和调速方式。调速接口可选择 PWM、 ⚫ 静止状态支持初始位置检测启动 ⚫ 支持顺逆风启动 ⚫ Soft-On Soft-Off (SOSO) ⚫ 驱动电流:2A ⚫ 内置 EEPROM,可配置电机参数、启动 模拟输入、I2C 调节电机转速,集成转速 指示功能,可通过 FG 引脚或 I2C 接口实 时读取电机转速。速度控制方式可选择恒 转速、恒电流和开环控制,具有电机转速 和调速方式 指示功能,集成过流、欠压、过温、堵转 ⚫ 可配置多段速度曲线 等多种保护模式,睡眠电流 40uA。 ⚫ 堵转保护 ⚫ 过流保护 ⚫ 缺相保护 ⚫ 正、反转自由切换 ⚫ 可配置电机转速指示或堵转 1.2 应用场景 落地扇、散热风扇等 QFN24(4mm*4mm*0.75mm) REV_V1.0 3 www.fortiortech.com FT8215Q 1.4 应用电路 VCC 5~18V U U VCC VCP CP2 CP1 VSL VDD5 VSL GND V FT8215Q 1uF VREF W VCC FG W VSL VCC SMP ASPD VSL Interface to Configuration Motor V DIR SPD 1uF VCC 1uF 0.1uF 图 1-1 FT8215Q 应用电路(单电阻) VCC 5~18V U U VCC CP1 VSL VDD5 VSL GND V FT8215Q 1uF VREF W VCC W VSL VCC SMP FG VSL SPD Motor V DIR ASPD Interface to Configuration VCP CP2 1uF VCC 1uF 0.1uF 图 1-2 FT8215Q 应用电路(双电阻/三电阻) REV_V1.0 4 www.fortiortech.com FT8215Q Charge Pump VCC SMP U V W VCC VREF VDD5 CP2 VCP CP1 1.5 功能框图 VCC VCP 5V LDO VREF PreDriver VScaler U ADC VSL ASPEED VSL SPEED VCC VCP I2C FG Logic Control PreDriver V GND VDD5 VSL VCC DIR EEPROM Over Current VCP OSC PreDriver Thermal W VSL 图 1-3 FT8215Q 功能框图 REV_V1.0 5 www.fortiortech.com FT8215Q 19 U 20 U 21 VCC 22 VCC 23 VCP 24 CP2 1.6 封装 CP1 1 18 VSL VDD5 2 17 VSL GND 3 VREF 4 DIR 5 SMP 6 FT8215Q Top View With downbond GND 16 V 15 V 14 VSL W 12 9 FG/SDA W 11 8 SPEED/SCL VCC 10 7 ASPEED 13 VSL 图 1-4 FT8215 QFN24 顶视图,封装尺寸:(4mm*4mm*0.75mm, e=0.5mm) REV_V1.0 6 www.fortiortech.com FT8215Q 1.7 引脚定义 表 1-1 FT8215 QFN24 引脚定义 CP1 VDD5 GND VREF FT8215 QFN24 1 2 3 4 IO 类 型 AO P P AI DIR 5 DI SMP ASPEED SPEED FG VCC W W VSL VSL V V VSL VSL U U VCC VCC VCP CP2 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 AI AI DI DO P DO DO DO DO DO DO DO DO DO DO P P P AO PAD 名称 功能描述 电荷泵引脚,在 CP2 与 CP1 之间接 0.1uF 电容 5V LDO 输出,接 1~4.7uF 电容到地 地 ADC 参考电压,外接 1uF 电容到地 电机转动方向控制,内置上拉电阻 1:正转。输出相序为 U-->V-->W 0:反转。输出相序为 U-->W-->V 母线电流采样输入 模拟调速输入 电机调速输入,PWM/CLOCK 调速 转速输出信号或者堵转指示,集电极开路输出 输入电源 W 相输出 W 相输出 下桥地端输出 下桥地端输出 V 相输出 V 相输出 下桥地端输出 下桥地端输出 U 相输出 U 相输出 输入电源,5~18V DC,接≥1uF 电容到地 输入电源 电荷泵输出,对 VCC 接 1~4.7uF 电容 电荷泵引脚,在 CP2 与 CP1 之间接 0.1uF 电容 备注: 1. IO 类型说明: DI = 数字输入, DO = 数字输出, AI = 模拟输入, AO = 模拟输出, P = 电源 REV_V1.0 7 www.fortiortech.com FT8215Q 2 封装信息 2.1 QFN24 Symbol A A1 b c D D2 e Ne Nd E E2 L h N REV_V1.0 Millimeter Min 0.70 – 0.18 0.18 3.90 2.40 Nom 0.75 0.02 0.25 0.20 4.00 2.50 0.50BSC 2.50BSC 2.50BSC 3.90 4.00 2.35 2.50 0.35 0.40 0.30 0.35 Pin Number = 24 图 2-1 QFN24 封装尺寸图(4.0mm*4.0mm*0.75mm, e=0.5mm) 8 Max 0.80 0.05 0.30 0.25 4.10 2.60 4.10 2.65 0.45 0.40 www.fortiortech.com FT8215Q 3 定购信息 控制功能 型号 FT8215Q REV_V1.0 封装 QFN24 (4x4 mm) 电源 电压 (V) 5~18 Rdson (上桥+ 下桥) (Ω) 驱 动 电 流 (A) 0.25 2 保护 调速方式 驱动类型 无感正弦 I2C PWM/ CLOCK 模拟 √ √ √ 9 正 反 转 初 始 位 置 侦 测 过 流 保 护 过 温 保 护 欠 压 保 护 堵 转 保 护 缺 相 保 护 √ √ √ √ √ √ √ 工作温度 Tj(℃) 无 铅 -40~150 √ www.fortiortech.com FT8215Q 4 修改记录(Document Change List) Date Revision 2021/01/11 1.0 REV_1.0 Changes 初始版本 10 www.fortiortech.com FT8215Q Copyright Notice Copyright by Fortior Technology (Shenzhen) Co., Ltd. All Rights Reserved. Right to make changes —Fortior Technology (Shenzhen) Co., Ltd RSVs the right to make changes in the products - including circuits, standard cells, and/or software - described or contained herein in order to improve design and/or performance. The information contained in this manual is provided for the general use by our customers. Our customers should be aware that the personal computer field is the subject of many patents. Our customers should ensure that they take appropriate action so that their use of our products does not infringe upon any patents. It is the policy of Fortior Technology (Shenzhen) Co., Ltd. to respect the valid patent rights of third parties and not to infringe upon or assist others to infringe upon such rights. This manual is copyrighted by Fortior Technology (Shenzhen) Co., Ltd. You may not reproduce, transmit, transcribe, store in a retrieval system, or translate into any language, in any form or by any means, electronic, mechanical, magnetic, optical, chemical, manual, or otherwise, any part of this publication without the expressly written permission from Fortior Technology (Shenzhen) Co., Ltd. Fortior Technology (Shenzhen) Co., Ltd. Room203, 2/F, Building No.11, Keji Central Road2, SoftwarePark, High-Tech Industrial Park, Shenzhen, P.R. China 518057 Tel: 0755-26867710 Fax: 0755-26867715 URL: http://www.fortiortech.com Contained herein Copyright by Fortior Technology (Shenzhen) Co., Ltd all rights Reserved. REV_1.0 11 www.fortiortech.com
FT8215Q 价格&库存
很抱歉,暂时无法提供与“FT8215Q”相匹配的价格&库存,您可以联系我们找货
FT8215Q
  • 1+7.45720
  • 10+6.02310
  • 30+5.13450
  • 100+4.53920
  • 490+4.17610
  • 980+3.91500
库存:758
