厚膜贴片电阻承认书-CR 系列
Approval Specification for Thick Film Chip Resistors - Type CR
承认书
APPROVAL SHEET
厂商:丽智电子(昆山)有限公司
客户:
: 丽智电子(南通)有限公司
Supplier:
customer:
核准
Approved by
审核
Checked by
制作
Prepared by
地址:江苏省昆山市汉浦路 989 号
Address: No. 989, Hanpu Road Kunshan City Jiangsu Province
Tel:0086-0512-57780531
Fax:0086-0512-57789581
地址: 江苏省南通市通州区康富路 789 号
Address: No. 789, Kang Fu Road Tongzhou District Nantong city Jiangsu province
Tel: 0086-0513-68856666
Fax: 0086-0513-68383688
1
文件編號:613-00-001 版本:V30.0
厚膜贴片电阻承认书-CR 系列
1. 范围(scope):
1.1 适用于本公司所生产的无铅、无卤之厚膜贴片电阻 CR 系列
This specification applies to thick film chip resistors which meet requirements of Pb free and halogen free.
1.2 本公司的无铅产品指的贴片电阻端电极无铅,而存在于电阻层的玻璃中的符合 RoHS 豁免条款。
There no lead exists in terminal of resistor, and lead which exist in glass of resistor layer meets RoHS
exemption.
2. 产品料号(part number):
0603 1/10W 5% 100Ω
CR0603JA0101G
CR
类型(Type)
0603
尺寸(Size)
J
A
0101
G
公差
额定功率
阻值
包装代码
Rated Power
Resistance value
Packing Code
CR: 厚膜贴片
1005
Tolerance
电阻(thick film
0201
B=±0.1%
1= 1W
±1% , ±0.5% :
G= reel (卷装)
chip resistors)
0402
D=±0.5%
2= 3/4W
49R9=49.9Ω
V= bulk (散料)
0603
F=±1%
3= 1/2W
1002=10KΩ
S= Double Standard
0805
G=±2%
4= 1/4W
±2% , ±5% :
Quantity (两倍卷
1206
J=±5%
8= 1/8W
06R8=6.8Ω
盘标准包装量)
1210
K=±10%
A= 1/10W
0564=560KΩ
1812
B= 2W
2010
F= 1/16W
2512
H=1/20W
L=1/32W
备注:1005:为尺寸 01005 规格
2
厚膜贴片电阻承认书-CR 系列
3. 电阻本体字码标示(Marking on the Resistor's Body):
※ 01005、0201 及 0402 因本体太小,本体上无字码
标示
For 01005、0201 and 0402 size, no marking on the
body due to the small size of the resistor
公差±5%的产品,以三字码标示,前两位表示阻值
的有效数字,最后一位表示 10 的乘幂
±5% tolerance product: the marking is 3 digits, the first
2 digits are significant figures of resistance value and
the 3rd one denotes the power number of 10, (10X)
※ ±0.5%, ±1%的产品,以四字码标示,前三位表示阻
值的有效数字,最后一位表示 10 的乘幂
±0.5%, ±1% lerance product: the marking is 4 digits,
the first 3 digits are significant figures of resistance
value and the 4th one denotes the power number of 10,
X
(10 )
472=47×102=4.7KΩ
10Ω以下标示:5R6=5.6Ω
Below 10Ω: 5R6=5.6Ω
4992=499×102=49.9KΩ
※ 0603 ±1% E96 系列的标准阻值,因电阻本体太小,
采用三位代码标示。
Standard E96 series values of 0603 ±1%: due to the
small size of the resistor’s body, use 3digits code to
indicate the resistance value.
100Ω以下标示:6R81=6.81Ω
Below 100Ω: 6R81=6.81Ω
※ 0 欧姆产品,采用 000 三位代码标示。
0Ω Products,use 000 3digits code to indicate the
resistance value.
000=0Ω
3
厚膜贴片电阻承认书-CR 系列
0603 ±1% E96 系列的标准阻值代码(Standard E96 Series Resistance Value Code for 0603 ±1% Marking)
代码
Code
01
02
03
04
05
06
07
08
09
10
11
12
13
14
15
16
阻值
Value
100
102
105
107
110
113
115
118
121
124
127
130
133
137
140
143
代码
Code
17
18
19
22
23
24
25
26
27
28
29
30
31
32
阻值
Value
147
150
154
158
162
165
169
174
178
182
187
191
196
200
205
210
代码
Code
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
阻值
Value
215
221
226
232
237
243
249
255
261
267
274
280
287
294
301
309
代码
Code
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
阻值
Value
316
324
332
340
348
357
365
374
383
392
402
412
422
432
442
453
代码
Code
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
阻值
Value
464
475
487
499
511
523
536
549
562
576
590
604
619
634
649
665
代码
Code
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
阻值
Value
681
698
715
732
750
768
787
806
825
845
866
887
909
931
953
976
0603 ±1% E96 系列的指数代码(Multiplier Code for 0603 ±1% Marking)
代码 Code
Y
X
-2
指数 Multiplier
10
10
-1
A
B
10
C
1
10
D
2
10
E
3
10
F
4
105
阻值标示如下(So the resistance value are marked as the following examples)
3
38Y=243×10-2=2.43Ω
10D=124×10 =124KΩ
0603 ±1%的产品,在标准 E24 系列中,但不属于 E96 系列,标示与 5%的字码相同,但是在字码下加一条线
Standard E24 and not belong to E96 series values of 0603 ±1%, the marking is the same as 5% tolerance but
marking as underline
331=33×101=330Ω
560=56×100=56Ω
4
厚膜贴片电阻承认书-CR 系列
4. 尺寸(dimension):
E
尺寸
dimension
型别(Type)
CR1005
CR0201
CR0402
CR0603
CR0805
CR1206
CR1210
CR1812
CR2010
CR2512
e
L
0.40±0.02
0.60±0.03
1.00±0.05
1.60±0.10
2.00±0.15
3.10±0.15
3.10±0.15
4.50±0.20
5.00±0.20
6.25±0.20
W
0.20±0.02
0.30±0.03
0.50±0.05
0.80±0.10
1.25±0.15
1.60±0.15
2.50±0.15
3.10±0.20
2.50±0.20
3.10±0.20
T
0.13±0.02
0.23±0.03
0.30±0.05
0.45±0.10
0.50±0.10
0.55±0.10
0.55±0.15
0.55±0.15
0.55±0.15
0.55±0.15
单位(unit): mm
E
0.10±0.03
0.10±0.05
0.15±0.10
0.25±0.20
0.35±0.20
0.45±0.25
0.35±0.25
0.55±0.20
0.65±0.25
0.85±0.25
e
0.10±0.03
0.15±0.05
0.20±0.10
0.30±0.20
0.40±0.20
0.40±0.25
0.60±0.25
0.70±0.20
0.50±0.25
0.95±0.25
5. 功率衰减曲线( Derating Curve):
(其他)
(1005&0201)
工作温度范围(Operating Temperature Range): -55℃~+155℃;
储存条件(storage condition ): 5~30℃, 30~75%RH.
5
厚膜贴片电阻承认书-CR 系列
6.电阻结构(Construction ):
Marking
Outer Protective layer
Inner protective layer
Resistive layer
Conductive layer
Side conductive layer
Ni plating layer
Sn plating layer
Ceramic Substrate
No.
1
2
3
4
5
6
7
8
9
主要材料
Major material
结构
construction
陶瓷基板
Ceramic substrate
银电极
Conductive layer
侧电极
阻体层
Resistive layer
内保护层
外保护层
文字
Marking
镍电极
Ni plating layer
锡电极
Sn plating layer
三氧化二铝
Al2O3
银
Ag
镍铬合金
NiCr
氧化钌+玻璃
RuO2 + glass
玻璃
Glass
环氧树脂
Epoxy
环氧树脂
Epoxy
镍
Ni
雾锡
Matte Tin
6
厚膜贴片电阻承认书-CR 系列
7. 阻值范围(resistance range):
阻值范围
Resistance Range
型别 Type
0.5%
1%
2%
5%
CR1005
1Ω~10MΩ
1Ω~10MΩ
1Ω~10MΩ
CR0201
1Ω~10MΩ
1Ω~10MΩ
1Ω~10MΩ
CR0402
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~22MΩ
CR0603
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
CR0805
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
CR1206
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
CR1210
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
CR1812
10Ω~1MΩ
1Ω~10MΩ
1Ω~10MΩ
1Ω~10MΩ
CR2010
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
CR2512
10Ω~1MΩ
1Ω~22MΩ
1Ω~22MΩ
1Ω~100MΩ
8. 电气特性(electrical characteristics):
1/32W
最大工作
电压
Max Working
Voltage
15V
最大过负
荷电压
Max Overload
Voltage
30V
绝缘耐压
Dielectric
Withstanding
Voltage
30V
零欧姆阻值
Resistance
Value of
Jumper
很抱歉,暂时无法提供与“CR0603FA1333G”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.01840
- 100+0.01050
- 1000+0.00650
- 2500+0.00420
- 5000+0.00310
- 国内价格
- 100+0.00515
- 1000+0.00504
- 5000+0.00497
- 国内价格
- 100+0.00480
- 500+0.00448
- 2000+0.00416
- 5000+0.00384
- 10000+0.00352
- 30000+0.00329
