CR0402JF0203G
CR0402JF0203G
    LIZ(丽智电子)
    贴片电阻 0402 20KΩ ±5% 62.5mW ±200ppm/℃
CR0402JF0203G 数据手册
厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 承认书 APPROVAL SHEET 厂商:丽智电子(昆山)有限公司 客户: : 丽智电子(南通)有限公司 Supplier: customer: 核准 Approved by 审核 Checked by 制作 Prepared by 地址:江苏省昆山市汉浦路 989 号 Address: No. 989, Hanpu Road Kunshan City Jiangsu Province Tel:0086-0512-57780531 Fax:0086-0512-57789581 地址: 江苏省南通市通州区康富路 789 号 Address: No. 789, Kang Fu Road Tongzhou District Nantong city Jiangsu province Tel: 0086-0513-68856666 Fax: 0086-0513-68383688 1 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 1. 范围(scope): 1.1 适用于本公司所生产的无铅、无卤之厚膜贴片电阻 CR 系列 This specification applies to thick film chip resistors which meet requirements of Pb free and halogen free. 1.2 本公司的无铅产品指的贴片电阻端电极无铅,而存在于电阻层的玻璃中的符合 RoHS 豁免条款。 There no lead exists in terminal of resistor, and lead which exist in glass of resistor layer meets RoHS exemption. 2. 产品料号(part number): 0603 1/10W 5% 100Ω CR0603JA0101G CR 类型(Type) 0603 尺寸(Size) J A 0101 G 公差 额定功率 阻值 包装代码 Rated Power Resistance value Packing Code CR: 厚膜贴片 1005 Tolerance 电阻(thick film 0201 B=±0.1% 1= 1W ±1% , ±0.5% : G= reel (卷装) chip resistors) 0402 D=±0.5% 2= 3/4W 49R9=49.9Ω V= bulk (散料) 0603 F=±1% 3= 1/2W 1002=10KΩ S= Double Standard 0805 G=±2% 4= 1/4W ±2% , ±5% : Quantity (两倍卷 1206 J=±5% 8= 1/8W 06R8=6.8Ω 盘标准包装量) 1210 K=±10% A= 1/10W 0564=560KΩ 1812 B= 2W 2010 F= 1/16W 2512 H=1/20W L=1/32W 备注:1005:为尺寸 01005 规格 2 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 3. 电阻本体字码标示(Marking on the Resistor's Body): ※ 01005、0201 及 0402 因本体太小,本体上无字码 标示 For 01005、0201 and 0402 size, no marking on the body due to the small size of the resistor ※ 公差±5%的产品,以三字码标示,前两位表示阻值 的有效数字,最后一位表示 10 的乘幂 ±5% tolerance product: the marking is 3 digits, the first 2 digits are significant figures of resistance value and the 3rd one denotes the power number of 10, (10X) ※ ±0.5%, ±1%的产品,以四字码标示,前三位表示阻 值的有效数字,最后一位表示 10 的乘幂 ±0.5%, ±1% lerance product: the marking is 4 digits, the first 3 digits are significant figures of resistance value and the 4th one denotes the power number of 10, X (10 ) 472=47×102=4.7KΩ 10Ω以下标示:5R6=5.6Ω Below 10Ω: 5R6=5.6Ω 4992=499×102=49.9KΩ ※ 0603 ±1% E96 系列的标准阻值,因电阻本体太小, 采用三位代码标示。 Standard E96 series values of 0603 ±1%: due to the small size of the resistor’s body, use 3digits code to indicate the resistance value. 100Ω以下标示:6R81=6.81Ω Below 100Ω: 6R81=6.81Ω ※ 0 欧姆产品,采用 000 三位代码标示。 0Ω Products,use 000 3digits code to indicate the resistance value. 000=0Ω 3 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 0603 ±1% E96 系列的标准阻值代码(Standard E96 Series Resistance Value Code for 0603 ±1% Marking) 代码 Code 01 02 03 04 05 06 07 08 09 10 11 12 13 14 15 16 阻值 Value 100 102 105 107 110 113 115 118 121 124 127 130 133 137 140 143 代码 Code 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 阻值 Value 147 150 154 158 162 165 169 174 178 182 187 191 196 200 205 210 代码 Code 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 阻值 Value 215 221 226 232 237 243 249 255 261 267 274 280 287 294 301 309 代码 Code 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 阻值 Value 316 324 332 340 348 357 365 374 383 392 402 412 422 432 442 453 代码 Code 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 阻值 Value 464 475 487 499 511 523 536 549 562 576 590 604 619 634 649 665 代码 Code 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 阻值 Value 681 698 715 732 750 768 787 806 825 845 866 887 909 931 953 976 0603 ±1% E96 系列的指数代码(Multiplier Code for 0603 ±1% Marking) 代码 Code Y X -2 指数 Multiplier 10 10 -1 A B 0 10 10 C 1 10 D 2 10 E 3 10 F 4 105 阻值标示如下(So the resistance value are marked as the following examples) 3 38Y=243×10-2=2.43Ω 10D=124×10 =124KΩ 0603 ±1%的产品,在标准 E24 系列中,但不属于 E96 系列,标示与 5%的字码相同,但是在字码下加一条线 Standard E24 and not belong to E96 series values of 0603 ±1%, the marking is the same as 5% tolerance but marking as underline 331=33×101=330Ω 560=56×100=56Ω 4 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 4. 尺寸(dimension): E 尺寸 dimension 型别(Type) CR1005 CR0201 CR0402 CR0603 CR0805 CR1206 CR1210 CR1812 CR2010 CR2512 e L 0.40±0.02 0.60±0.03 1.00±0.05 1.60±0.10 2.00±0.15 3.10±0.15 3.10±0.15 4.50±0.20 5.00±0.20 6.25±0.20 W 0.20±0.02 0.30±0.03 0.50±0.05 0.80±0.10 1.25±0.15 1.60±0.15 2.50±0.15 3.10±0.20 2.50±0.20 3.10±0.20 T 0.13±0.02 0.23±0.03 0.30±0.05 0.45±0.10 0.50±0.10 0.55±0.10 0.55±0.15 0.55±0.15 0.55±0.15 0.55±0.15 单位(unit): mm E 0.10±0.03 0.10±0.05 0.15±0.10 0.25±0.20 0.35±0.20 0.45±0.25 0.35±0.25 0.55±0.20 0.65±0.25 0.85±0.25 e 0.10±0.03 0.15±0.05 0.20±0.10 0.30±0.20 0.40±0.20 0.40±0.25 0.60±0.25 0.70±0.20 0.50±0.25 0.95±0.25 5. 功率衰减曲线( Derating Curve): (其他) (1005&0201) 工作温度范围(Operating Temperature Range): -55℃~+155℃; 储存条件(storage condition ): 5~30℃, 30~75%RH. 5 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 6.电阻结构(Construction ): Marking Outer Protective layer Inner protective layer Resistive layer Conductive layer Side conductive layer Ni plating layer Sn plating layer Ceramic Substrate No. 1 2 3 4 5 6 7 8 9 主要材料 Major material 结构 construction 陶瓷基板 Ceramic substrate 银电极 Conductive layer 侧电极 Side conductive layer 阻体层 Resistive layer 内保护层 Inner protective layer 外保护层 Outer Protective layer 文字 Marking 镍电极 Ni plating layer 锡电极 Sn plating layer 三氧化二铝 Al2O3 银 Ag 镍铬合金 NiCr 氧化钌+玻璃 RuO2 + glass 玻璃 Glass 环氧树脂 Epoxy 环氧树脂 Epoxy 镍 Ni 雾锡 Matte Tin 6 文件編號:613-00-001 版本:V30.0 厚膜贴片电阻承认书-CR 系列 Approval Specification for Thick Film Chip Resistors - Type CR 7. 阻值范围(resistance range): 阻值范围 Resistance Range 型别 Type 0.5% 1% 2% 5% CR1005 - 1Ω~10MΩ 1Ω~10MΩ 1Ω~10MΩ CR0201 - 1Ω~10MΩ 1Ω~10MΩ 1Ω~10MΩ CR0402 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~22MΩ CR0603 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ CR0805 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ CR1206 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ CR1210 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ CR1812 10Ω~1MΩ 1Ω~10MΩ 1Ω~10MΩ 1Ω~10MΩ CR2010 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ CR2512 10Ω~1MΩ 1Ω~22MΩ 1Ω~22MΩ 1Ω~100MΩ 8. 电气特性(electrical characteristics): 1/32W 最大工作 电压 Max Working Voltage 15V 最大过负 荷电压 Max Overload Voltage 30V 绝缘耐压 Dielectric Withstanding Voltage 30V 零欧姆阻值 Resistance Value of Jumper
CR0402JF0203G
1. 物料型号:文档中列出了多种型号的厚膜贴片电阻,例如CR1005、CR0201、CR0402、CR0603等,每种型号都有其特定的尺寸和额定功率。
2. 器件简介:文档描述了这些电阻是符合无铅(Pb free)和无卤(halogen free)要求的厚膜贴片电阻。
3. 引脚分配:文档中提到了电阻的端电极无铅,并且如果存在于电阻层的玻璃中的铅符合RoHS豁免条款。
4. 参数特性: - 电阻值:文档中提供了多种阻值范围,例如10Ω至10MΩ。 - 公差:包括±1%、±0.5%、±5%等。 - 额定功率:不同型号的电阻有不同的额定功率,如1/32W、1/16W、1/10W等。
5. 功能详解:文档详细描述了电阻的结构,包括陶瓷基板、银电极、侧电极、阻体层、内保护层、外保护层、镍电极和锡电极。
6. 应用信息:文档中提到了电阻的工作温度范围(-55℃~+155℃)和储存条件(5~30℃, 30~75%RH)。
7. 封装信息:提供了不同型号电阻的具体尺寸信息,如长度、宽度、厚度等。
8. 性能信赖性测试:文档列出了多种测试方法和条件,如温度系数、焊锡性、绝缘电阻、绝缘耐压、短时间过负荷等。
9. 包装规格:提供了卷盘尺寸和标准数量每卷的信息。
10. 焊接建议:文档提供了建议的回流焊曲线、波峰焊曲线和手工焊温度。
CR0402JF0203G 价格&库存
很抱歉,暂时无法提供与“CR0402JF0203G”相匹配的价格&库存,您可以联系我们找货
CR0402JF0203G
    • 1+0.04430
    • 100+0.02860
    • 1000+0.01960
    • 5000+0.01330
    • 10000+0.00950
    库存:98303
    CR0402JF0203G
      • 100+0.00324
      • 1000+0.00260
      • 3000+0.00216
      • 10000+0.00206
      • 50000+0.00162
