XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
1/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
Product Specification
Title:TACT SWITCHES 轻触开关
1. SCOPE(适用范围)
This specification covers the performance, tests and quality requirements for the single key switches
which have no key top(TACT SWITCHES:MECHANICAL
CONTACT)本规范涵盖了盖单推柄和无推柄的轻触开关的性能、测试和质量要求。 XKB
Connectivity)
2. PRODUCT DESCRIPTION( 产品描述)
XKB-DESCRIPTION(描述)
Part Number(料号)
轻触开关7.0x3.5x5.0侧立直插160gf
TS-1188A-B-C
3. APPLICABLE DOCUMENT (适用文件)
The following documents form a part of this specification to the extent specified herein. In the event of
conflict between the requirements of this specification and the product drawing, the product drawing
shall take precedence. In the event of conflict between the requirements of this specification and the
referenced documents, this specification shall take
precedence.(下列文件构成本规范的一部分,在此规定的范围内。本规范要求与产品图纸有冲突
时,以产品图纸为准。如果本规范的要求与参考文件发生冲突,应以本规范为准。)
MIL-STD-105
EIA-364
QQ-N-290
ISO/IEC- 7816
4. REQUIREMENTS (要求)
4.1. Design and Structure (设计和结构)
Product shall be of the design, structure and physical dimensions specified on the applicable product drawing.( XKB
Connectivity产品的设计、结构和物理尺寸参考所适用的产品图纸)
参考附件图档
4.2. Materials/ Finish (材料/表面处理)
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
2/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
Materials used in the structure of product shall be as specified on the applicable product drawing.
(产品结构中使用的材料参考所适用的产品图纸)
4.3. Ratings (额定功率)
Item(项目)
Standard(标准)
Rated Voltage (Maximum)额定电压
12V
Rated Current (Maximum)额定电流
50mA
Operating temperature range工作温度范围
Storage Temperature Range储存温度范围
DC
-20℃~+85℃
From -20 to +85℃ degree centigrade
-30℃~+80℃
From -30 to +80 degree centigrade
5.0 TEST STANDARD (测试条件)
Unless otherwise specified, the standard range of atmospheric conditions for making
measurements and tests are as follows (除另有说明外,用以进行测量和测试的标准环境
条件范围如下)
5.1 Ambient temperature(环境温度): 5℃ to 35℃
5.2 Normal humidity (正常湿度): 45% to 85%
5.3 Air pressure (气压): 86Kpa to 106Kpa
5.4 Temperature (温度):40±2℃
5.5 Relative humidity (相对湿度):65±5%
6.0 TYPE OF ACTUATION 动作类型
Tactile feedback (轻触返回)
7.0 CONTACT ARRANGEMENT 1POLES 1THROWS (接触形式1 接点 1 回路)
Details of contact arrangement are given in the assembly drawings.
(详细接点形式见装配图)
8.0 PERFORMANCE AND TEST DESCRIPTION ( XKB Connectivity性能和测试类型)
8.1 APPEARANCE (外观)
ITEM
DESCRIPTION(类型)
TEST CONDITION(测试条件)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
3/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
1
Appearance
(外观)
Visual.(目视)
Should not have any flaw
Scratch discoloration and
crushed(无任何裂痕、刮伤
、污染和变形)
8.2 ELECTRICAL (电气)
ITEM DESCRIPTION(类型)
2
3
4
5
TEST CONDITION (测试条件)
Applying static load twice the
actuating force to the center of the
stem.measurements shall be made
with a 1 kHz small-current contact
Low level contact
resistance. (接触电阻) resistance
meter.(用两倍的动作力作静负载施加于
按钮的中心,并用
1千赫小电流接触电阻仪测量)
REQUIREMENT(要求)
100 mΩ Max.
Insulation
Resistance.
(绝缘电阻)
Measurements shall be made following
application of DC100V potential between
terminals and between individual
terminals and frame for one minute.
(在端子与端子之间,端子与外壳之间施加
DC100V,一分钟,测量相邻两端的绝缘电阻)
100 mΩ min.
Dielectric strength.
(耐电压)
AC 250 V (50Hz or60Hz) shall be
applied between terminals and between
individual terminals and frame for one
minute.(在端子与端子之间,端子与外壳之
间施加 AC250V(50HZ-60HZ))
There shall be no
breakdown.
(无击穿、闪烁现象)
Lightly striking the center of the stem
at a rate encountered in normal use ( 3
to 4 operations per sec). Bounce shall
be
tested
when
“ON”
and
“OFF”.(在正常使用中(以每秒
3-4
次周
期)轻
轻地
在手
柄中
心加
力,在
通与
断瞬
间测
试抖
动)
10mS Max.
Bounce
(抖动)
8.3 MECHANICAL (机械)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
4/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
6
7
8
9
10
Actuating
(动作力)
Place the switch such that the direction
of switch operation is vertical and then
gradually increase the load applied to
the center of the stem, the maximum
Force load required for the stem to come to a
160 ± 30
stop shall be measured.
(开关的动作方向为垂直放置开关向推柄中心
逐渐地增加负荷直到推柄停止时所测量的最大
负荷)
Travel(行程)
Return Force
(返回力)
Static Strength
(静止强度)
Stem
Strength(推柄强度
gf
apply a static load twice the actuating
force to the center of the stem, the
travel distance for the stem to come to a 0.25
(开关的动作方向为垂直放置开关,并以双倍
动作力的静负荷作用推柄中心,测量推柄从开
始到停止的行程距离)
The sample switch is installed such
that the direction of switch operation
is vertical and, upon depression of the
stem in its center the whole travel
distance, the force of the stem to
10gf
return to its free position shall be
measured.
(开关的动作方向为垂直放置开关,在已有
行程的推柄中心向上减小压力,推柄回到自
由位置时所测量到的力)
min.
Placing the switch such that the
There shall be no sign
direction of switch operation is vertical, of damage
a static load of 3 kg shall be applied in
mechanically and
the direction of stem operation for a
electrically.
period of 60 seconds.
(无机械的和电气的损伤迹象
(开关的动作方向为垂直放置开关,在推柄动
作方向施加 3Kg 的静负荷,60 秒时间)
vertical,the maxitrnm force to withstarxt
a pull applied opposite to the direction
1Kgf
of stem operation shall be
measured.(固定开关,使开关与操作方向垂
直,以推柄动作方向反方向施加拉力所测量到
的最大承受力)
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
5/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
11
Operating
Life(动作寿命)
following the test set forth below:
按下列条件进行寿命试验
(1) DC 5V 5mA resistive load. DC 5V
5mA 阻性负载
(2) Rate of operation: 2 to 3 operations
per second动作频率: 2-3 次/每秒
(3) Depression: 160
gf 减压力
(4) Cycles of operation动作次数:
10×104cycles
Contact
resistance接触电阻: 100
mΩ Max. Insulation
resistance绝缘电阻 :
100mΩ Min. Actuating
force: 动作力
+ 30 %or- 30%of initial
force. ±30%初始动作力
Item 8.2.2
Item 8. 3.7
按下列条件进行抗振动试验
(1)Range of oscillation:10 to 55Hz
频率范围
Vibration
Resistance
(振动)
12
(2)Amplitude,pk-to-pk:1.5mm
振幅:峰-峰 1.5mm
Item 8.2.5
Item 8.3.6、8.3.7
(3)Cycle of sweep: 10-55-10Hz in one
minute, approx.扫描周期: 10-55-10Hz
约一分钟内
(4)Mode of sweep: Logarithmically
sweep or uniform sweep. 扫描方式:
对数扫描式恒定扫描
(5)Direction of oscillation振动方向:
Three
mutually
perpendicular
directions, including the direction of
stem
travel.
3
个相互垂直方向,包括推柄行程方向
(6)2 hours each, for a total of
6hours. 每方向 2 小时.共 6 小时
13
Impact
Shock
Resistance(抗冲
击)
Measurements
shall
be
made
按下列条件进行冲击试验
(1)Acceleration: 80g 加速度
(2)Cycles of test : 3 cycles each in
6directions, for a total of 18cycles
试验次数: 每个方向 3 次,6 个方向共 18
次
Item 8.2.2
Item 8.3.6、8.3.7
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
6/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
8.4 ENVIRONMENTAL (环境 XKB Connectivity)
ITEM
14
15
DESCRIPTION(类型)
Solder ability
(可焊性 )
Moisture Resistance
(耐潮湿)
Test temperature:245±5℃ Test
time :5sec During test,the stick
detect temperature in the
oven.Then switch terminal soak in
the oven.It put 2min under normal
temperature after testing.
试验温度:245±5℃
试验时间:5s;试验时以测温棒侦测锡炉
温度;开关端子浸入与焊锡接触,在时间
内f
取出;测试后再常温下测试后再常温下静
止 2 分钟
Following the test set forth below the
sample shall be left in normal
temperature and humidity conditions
for one hour before measurements
are
made:
样品按下列条件进行耐潮湿试验,试验后
在正常温度和湿度条件下放置
1
小时后测定
(1)Temperature温度: 60±2℃
(2)Relative humidity相对湿度: 90 to
95%
(3)Time时间:
96hours
Water drops shall be removed.擦除水珠
16
TLow Temperature
Resistance 耐低温
are made:
样品按下列条件进行耐低温试验,试验后在
正常温度和湿度条件下放置 1 小时后测定
(1)Temperature温度:-40±2℃
(2)Time时间:
96 hours
REQUIREMENT(要求)
The area must be reach
90% on the surface of
switch terminal
开关端子上锡面积应达
到 90%以上
Contact resistance: 100
mΩ Max.
接触电阻Insulation
resistance : 100 MΩ Min.
绝缘电阻
Item 8.2.4、8.2.5
Item8.3.6~8.3.8
mΩ Max.
接触电阻Insulation
绝缘电阻
Item 8.2.4、8.2.5
Item 8.3.6~8.3.8
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
7/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
17
Heat Resistance 耐热
are made:
样品按下列条件进行耐热试验,试验后在正
常温度和湿度条件下放置 1 小时后测定
(1)Temperature温度: 85±2℃
(2) Time时间:
96 hours
18
Change of
Temperature 温度循环
Following ten cycles of high
temperature test .The Sample shall
be Placed in Normal temperature and
humidity Conditions for one hour
before measurements are made.
During this test, water drops shall be
removed.样品按下列条件进行高低温循环
试验,试验后在正常温度和温度条件下放置
1 小时后测定
A:+85±2
B:40±2℃
C:2 小时
D:1 小时
E:2 小时
F:1 小时
Cycling:5
cycles
19
Salt Spray Test
盐雾试验
Hand Soldering
手工焊接
The salt spray test shall be
conducted at the following
conditions :
样品按下列条件进行盐雾试验
(1) Density(浓度): 溶液(5±1)% Nacl
(质量百分比)
(2)Temperature温度: 35±2℃
Time时间:
24 hours
Please practice according to bellow
conditions: (请按以下条件进行焊接)
(1) Soldering temperature焊锡温度 :
≤350℃
(2) Continuous soldering
time连续焊接时间: ≤3 S
(3) Capacity of soldering
iron电铬铁的功率: ≤60 W
mΩ Max.
接触电阻Insulation
绝缘电阻
Item 8.2.4、8.2.5
Item 8.3.6~8.3.8
mΩ Max.
接触电阻Insulation
绝缘电阻
Item 8.2.4、8.2.5
Item 8.3.6~8.3.8
E
Appearance shall no2rust,
oxidation, corrosion and
other undesirable
小
phenomena.(外观须无生锈
时
E
、氧化、腐蚀等不良现象)
2
小
时
scratch and crack.
(无任何裂痕、刮伤和破裂)
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
8/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
For the product of SMT , type solder
according to the following conditions
对于 SMT 产品,请按以下条件进行焊接
21
Automatic Flow
Soldering
(自动焊接)
Caution: the condition mentioned
above is a temperature on the PWB
surface on which parts are mounted.
There are cases where PWB
temperature greatly differs from
switch's surface temperature
depending on PWB material, size,
thickness, etc. The switch's surface
temperature shall not allowed to
exceed 260℃
注意:以上提及的条件是零部件上 PWB
表面的温度,由于 PWB
的材料、尺寸、厚度等不同,PWB
从开关表面获得的温度也会有很大产不同
,因此,千万小心不要让开关表面温度超
scratch and crack
(无任何裂痕、刮伤和破裂)
No visual damage to
insulator.
(绝缘体不得有严重变形)
过 260℃
9.0 XKB CONNECTIVITY OTHER PRECAUTIONS 其他注意事项:
9.1. Following the soldering process, do not try to clean the switch with a solvent or the
like.
进行焊接过程中,不可以用溶剂或类似品清洗开关
9.2. Safeguard the switch assembly against flux penetration from its topside.
防止助焊剂从开关的顶端渗入
XKB Connectivity
Doc. No.
TS-A0188-03
Page No.
9/10
Date Issued
2015-04-06
Prepared by
Josephine
Date revised
2018-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
9.3. Please have the products keep in close status and the storage time is 90 days
guaranty after delivering the goods at most. 交货后保证开关处于封密状态并库存时间
90 天以下
10. REEL PACKAGING 盘装
10.1. Scope 范围: This specification covers the requirements of the reel packaging for
SMT standard type of tact switches. 该规范包含 SMT
标准型拨动开关的绕带封装的要求
10.2. Packaging Material 包装材料
ITEM 项目
DESCRIPTION 说明
Package 包装
Cartons 卡通箱
Reel 转轴
Delete Cartons 可降解箱
Carrier Tape 载带
Polypropylene 聚丙烯
10.3. XKB Connectivity Packaging Quantity 封装数量
Please refer to the packing drawing. 请参考产品包装图纸
Rev.
Description
Date revised
Created/
Revised by
01
New Release
2021/09/05
Josephine Lin
很抱歉,暂时无法提供与“TS-1188A-B-C”相匹配的价格&库存,您可以联系我们找货
