Doc. No.
X-A0162-38
Page No.
1/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
XKB Connectivity
Product Specification
Title:4.20mm Pitch X9357 Series Connector
1. SCOPE(适用范围)
This specification covers the performance, tests and quality requirements for the4.20mm series
wire
to
board
connector.
(XKB
Connectivity
本规范涵盖了盖4.20mm系列线对板连接器性能、测试和质量要求)
2. PRODUCT DESCRIPTION( 产品描述)
DESCRIPTION(描述)
Part Number(料号)
Terminal 端子
X9357TX-XXX
Housing 胶壳
X9357XX-XXX-N2
X9357WR-XX-XXXX
X9357WV-XX-XXXX
Wafer 针座
X9357WR-XXXX-XXXX
X9357WV-XXXX-XXXX
3. APPLICABLE DOCUMENT (适用文件)
The following documents form a part of this specification to the extent specified herein. In the event of
conflict between the requirements of this specification and the product drawing, the product drawing
shall take precedence. In the event of conflict between the requirements of this specification and the
referenced documents, this specification shall take precedence.(XKB Connectivity
下列文件构成本规范的一部分,在此规定的范围内。本规范要求与产品图纸有冲突时,以产品图
纸为准。如果本规范的要求与参考文件发生冲突,应以本规范为准。)
4. REQUIREMENTS (要求)
4.1. Design and Structure (设计和结构)
Product shall be of the design, structure and physical dimensions specified on the applicable product drawing.(XKB
Connectivity 产品的设计、结构和物理尺寸参考所适用的产品图纸)
4.2. Materials/ Finish (材料/表面处理)
Specification
规格内容
Materials
材质
Terminal 端子
Brass 黄铜
Disposal of Surface
表面处理
Tin Plated: Over 70μ. Nickel: Over 30μ〞
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
2/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
Housing胶壳
UL94V
UL 94V-2/UL94V-0
UL 94V-2/UL94V-0
Wafe
Base
UL94V
针座
PIN
Brass 黄铜
Over Tin 70μ〞Plated ; Over 30μ〞Nickel
Please Refer to the Project drawing for the above Specification. (上述参数请以工程图为准)
4.3. Ratings (额定功率)
XKB Connectivity Item(项目)
Standard(标准)
Rated Voltage (Maximum) 额定电压
600V
Rated Current (Maximum) 额定电流
9A
Ambient temperature Range 使用温度范围
Applicable wire insulation O.D 适用线径
AC/DC
-25℃~+85℃
From -25 to +85 degree centigrade
AWG 18#~22# Insulation O.D.
3.00mm(Max.)
NOTE备注 : Including terminal temperature rise 升温时含端子
5. TEST STANDARD (测试条件)
5.1 Unless otherwise specified, the standard range of atmospheric conditions for making
measurements and tests are as follows (除另有说明外,用以进行测量和测试的标准
环境条件范围如下)
Ambient temperature(环境温度): 5℃ to 35℃
Normal humidity (正常湿度): 45% to 85%
Air pressure (气压): 86Kpa to 106Kpa
5.2 However if doubt arises on the decision based on the measured Values under the
above-mentioned Conditions.The following conditions shall be employed:
(但是在对判定产生疑问时,按下述状态实施)
Temperature (温度):20±2℃
Relative humidity (相对湿度):65±5%
8. PERFORMANCE AND TEST DESCRIPTION (性能和测试类型)
8.1 APPEARANCE (外观)
ITEM
DESCRIPTION(类型)
TEST CONDITION(测试条件)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
3/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
1
Appearance
(外观)
Visual.(目视)
Should not have any flaw
Scratch discoloration and
crushed(无任何裂痕、刮伤
、污染和变形)
8.2 ELECTRICAL (电气)
ITEM DESCRIPTION(类型)
TEST CONDITION (测试条件)
REQUIREMENT(要求)
Based upon EIA-364-06A.
1
2
contact resistance
(接触阻抗)
Insulation
Resistance (绝缘阻抗)
3
Dielectric strength
(耐电压)
4
Contact resistance on
crimped
portion(铆线后端子接
触阻抗)
Mate connectors, measure by dry
circuit, 20mV MAX,
10mA.(公母配合,开放电压 20mV
以下,电流 10mA 检测连接器 A~B 区)
Based upon EIA-364-21B/MIL-STD-202
Method 302 Cond. B
Mate connectors, apply 500V DC
between adjacent terminal or ground.
Initial(初始): 10
milliohms Max.
After Test(测试后): 20
milliohms Max.
1000 M min.
(公母配合, 在相邻端子,
端子与地片之间, 使用500V
的直流电,检测连接器)
Based upon EIA-364-20A/MIL-STD-202
Method 301
Mate connectors, apply 1000V AC for 1
minute between adjacent terminal or
ground.(公母配合, 在相邻端子,
端子与地片之间, 使用1000V 的交流电 1
分锺,检测连接器)
Crimp the applicable wire on to the
terminal measure by dry circuit 20mV
MAX, 10mA.(铆线后之端子,开放电压 20mV
以下,电流 10mA检测连接器)
There shall be no
breakdown.
(无击穿、闪烁现象)
10 milliohms
8.3 MECHANICAL (机械)
REQUIREMENT(要求)
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
4/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
1
Insert and withdraw Connectors at the
speed rate of
25.4±3mm/minute.(以每分锺 25.4±3mm
Insertion & Retention 的速率插入和拔出)
Force (插拔力)
2
Terminal/ Housing
Retention Force
(端子保持力)
3
Terminal Insertion
Force (端子插入力)
Refer to paragraph 6
参照第 10 项
Apply axial pull out force at the speed
rate of 25.4±3mm/minute on the
terminal assembled in the housing.
(以每分 25.4±3mm 的速率, 将端子从
Housing 内轴向拔出的力量.)
24.5N {2.5kgf}Min.
Insert the crimped terminal into the
housing.
(铆线后之端子插入Housing
所需最大力量)
14.7N {1.5kgf} Max.
Apply axial push force at the speed
rate of 25.4±3mm/minute.
(以每分 25.4±3mm 的速率,将 PIN
4
PIN Retention Force
(PIN针保持力)
针从Wafer 内轴向拔出的力量 )
Fix the crimped terminal, apply axial
pull out force on the wire. (Do not
5
Tensile strength
(Crimped
connections)(端子压
着强度)
crimp insulation part).
13.7N {1.4kgf} min.
AWG
Spec.
kgf. Min.
#20
#22
#24
6.0
4.0
2.0
(固定铆线后的端子,使电线与端子分离时
所需的最小力量)
Note> As for unspecified
wire sizes in this
specification define
values with clients
6
Repeated Insertion/
Withdrawal
(重复插拔)
When mated up to 30 cycles
repeatedly by the rate of 10 cycles
per minute. (以每分锺不超过 10
次的速率,将公母插拔30 次.)
Contact
Resistance(接触阻抗):2
0 milliohms Max.
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
5/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
Based upon EIA-364-28B/MIL-STD202 Method 213B Cond.A
Amplitude (振幅): 1.5mm P-P
7
Vibration (耐振动性) Sweep time(频率): 10~55~10 HZ in
1 minute
Duration(持续时间): 2 hours in each
X.Y.Z axials.(每轴向 2 小时)
Based upon EIA-364-27B/MIL-STD202
8
Shock (耐冲击性)
Method 213B Cond.A
Pulse width(冲击时间): 11 msec.,
Waveform(波形) : half sine,
490m/s2{50G}, 3 strokes in each X.Y.Z.
axes.
(加速度最大50G,沿3个互相垂直达的方向)
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
Discontinuity瞬断:1
micro- second Max.
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
Discontinuity瞬断:1
micro- second Max.
8.4 ENVIRONMENTAL (环境)
ITEM
DESCRIPTION(类型)
1
Temperature
Rise(温升测试)
2
Heat Resistance
(耐热性)
Carrying rated current load. (UL
1977)(公母对插后,在通过额定电流下,
所测定的温度)
Based upon MIL-STD-202
Method 108A Cond.A
85±2℃,96 hours.
3
Cold Resistance
(耐寒性)
Based upon EIA-364-105
-25±5℃,96 hours.
REQUIREMENT(要求)
30℃ Max.
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
6/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
4
Humidity (
耐湿性)
Based upon EIA-364-31A/MIL-STD202
Method 103B Cond.B
Temperature(温度): 40±2℃
Relative Humidity(湿度): 90~95%
Duration(持续时间): 96 hours
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
Insulation
Resistance
绝缘阻抗:1000 M min.
Based upon EIA-364-32B
5 cycles of:
5
Temperature Cycling
(温度变化)
a) -55℃ 30 minutes.
b) +85℃ 30 minutes.
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
(从-55℃持续 30 分锺升至+85℃持续 30
分锺,循环 5 次)
6
Salt Spray
(盐水喷雾)
7
Solder-ability
(焊锡附着性)
8
Solder- Resistance
(焊锡耐热性)
Based upon EIA-364-26A/MIL-STD202
Method 101D Cond.B
24±1 hours exposure to a salt spray
from the 5±1% solution at 35±2℃.
(在温度 35±2℃,盐水浓度
5±1%下,盐水喷雾24±1 小时)
注:此项测试只针对先冲后镀端
Appearance外观:
No Damage无异状
Contact
Resistance接触阻抗:20
milliohms Max.
Based upon EIA-364-52
Soldering Time焊接时间: 3±0.5second.
Solder Temperature焊接温度: 245±5℃.
Immersed area must show
no
voids,
pin
holes.
浸渍面积需95%以上
Based upon EIA-364-56A
Appearance外观:
No Damage无异状
Soldering time焊接时间:3~5 sec
Solder Temperature焊接温度:250±5℃.
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
7/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
9. PACKAGING 包装
Please refer to the packing drawing. 请参考产品包装图纸
参考附件
10. INSERTION/WITHDRAWAL FORCE 综合插入力及拔出力:
参考附件
11. SOLDERING 焊接:
11.1. Wave soldering(波峰焊): DIP Suggestions solder temperature at 260℃(500°F)
max.5 seconds . DIP型推荐焊接焊锡温度为260℃(500°F) 最多5秒
11.2. Hand soldering(手焊): Use a soldering iron of 30 watts controlled at 350℃
approximately 5 seconds. while applying solder.
使用30W烙铁控制温度在350℃,焊接时长约5秒
XKB Connectivity
Doc. No.
X-A0162-38
Page No.
8/9
Date Issued
2020-04-06
Prepared by
Josephine
Date revised
2020-11-23
checked by
Jay
Rev. No.
01
Approved by
Mei Chen
11.3. Reflow soldering profile(回炉焊):When the maximum temperature of the reflow
furnace is 260 °C and the temperature is 260 °c. 10 seconds MAX. (reference)
SMT型回焊炉最高温度为260℃,温度为260℃时,最长时间不超过10秒(如图)
Rev.
Description
Date revised
Created/
Revised by
01
New Release
2021/05/20
Josephine Lin
很抱歉,暂时无法提供与“X9357HF-06G-N2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.23126
- 100+0.21634
- 500+0.20142
- 2000+0.18650
- 5000+0.17606
- 10000+0.17158
- 国内价格
- 5+0.49320
- 50+0.38968
- 150+0.33786
- 1000+0.29908
- 2000+0.26800
- 5000+0.25251
