GBU10005 THRU GBU1010
Reverse Voltage - 50 to 1000 Volts Forward Current - 10.0 Amperes
GLASS PASSIVATED BRIDGE RECTIFIERS
Features
GBU
Surge overload rating - 220 amperes peak
.437(11.1)
.430(10.9)
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
Plastic material has U/L lammability classification 94V-0
.154(3.9)
.146(3.7)
.752(19.1)
.720(18.3)
.232(5.9)
.224(5.7)
.401(10.2)
.392(9.80)
.073(1.85)
.057(1.45)
Mechanical Data
.100(2.54)
.085(2.16)
.720(18.29)
.680(17.27)
.047(1.2)
.035(0.9)
Case : JEDEC GBU Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
.080(2.03)
.065(1.65)
.210 .210
.190 .190
(5.3) (5.3)
(4.8) (4.8)
Maximum Ratings And Electrical Characteristics
.139(3.53)
.133(3.37)
.126(3.2)*45°
CHAMFER
.874(22.2)
.860(21.8)
.106(2.7)
.091(2.3)
.022(.56)
.018(.46)
.210
.190
(5.3)
(4.8)
Dimensions in inches and (millimeters)
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward(with heatsink NOTE 2)
Rectified current @T c =100°C(without heatsink)
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
Rating for Fusing(t
很抱歉,暂时无法提供与“GBU1010”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.20472
- 50+1.79291
- 150+1.61633
- 500+1.21932
- 2500+1.12126
- 5000+1.06240
- 国内价格
- 5+2.20320
- 50+1.78600
- 150+1.60620
- 500+1.20830
- 2500+1.11080
- 5000+1.05220
- 国内价格
- 5+2.00145
- 50+1.62749
- 100+1.60308
- 200+1.46726
- 500+1.10691
