KBU15005 THRU KBU1510
Reverse Voltage - 50 to 1000 Volts Forward Current - 15.0 Amperes
SILICON BRIDGE RECTIFIERS
Features
KBU
Ideal for printed circuit board
Reliable low cost construction utilizing molded plastic technique
.157(4.0)*45°
0.935(23.7)
0.895(22.7)
Plastic material has U/L lammability classification 94V-0
0.15 x0.23L
(3.8 x5.7L)
HOLE THRU
0.300
(7.5)
High temperature soldering guaranteed:
0.700(17.8)
0.600(16.8)
260°C/10 seconds,0.375”(9.5mm) lead length,
0.780(19.8)
0.740(18.8)
AC
5 lbs. (2.3kg) tension
0.669
MIN.
(17.0)
0.866
MIN.
(22.0)
0.052(1.3)
DIA.
0.048(1.2)
Mechanical Data
0.220(5.6)
0.180(4.6)
0.087(2.2)
0.071(1.8)
Case : JEDEC KBU Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.27ounce,7.59grams
0.280(7.1)
0.236(6.0)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25°C ambient temperature unless otherwisespecified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward output rectified current
at TC=50 C(Note 1)
Peak forward surge current
8.3ms single half sine-wave superimposed
on rated load (JEDEC Method)
Maximum instantaneous forward voltage
drop per birdge element at 6.0A
Maximum DC reverse current
TA=25°C
TA=125°C
at rated DC blocking voltage
Operating junction temperature range
storage temperature range
SYMBOLS
VRRM
VRMS
VDC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
KBU15005 KBU1501 KBU1502 KBU1504 KBU1506 KBU1508 KBU1510
UNITS
V
V
V
I(AV)
15
A
IFSM
300
A
VF
1.0
V
IR
10
0.5
μA
mA
TJ
-55 to +150
°C
TSTG
-55 to +150
°C
NOTES:
1.Device mounted on 100mm*100mm*1.6mm Cu plate heatsink
http://www.microdiode.com
Rev:2024A2
Page :1
Ratings And Characteristic Curves
FIG.1-MAXIMUM FORWARD SURGE CURRENT
FIG. 2 – DERATING CURVE OUTPUT RECTIFIED CURRENT
AVERAGE FORWARD OUTPUT CURRENT
AMPERES
PEAK FORWARD SURGE CURRENT
AMPERES
400
350
300
250
200
TJ=25°C
150
100
50
1
10
5
50
100
150
CASE TEMPERATURE (℃)
NUMBER OF CYCLETS AT 60Hz
FIG.3– TYPICAL FORWARD CHARACTERISTICS
FIG.4– TYPICAL REVERSE CHARACTERISTICS
10
INSTANTANEOUS REVERSE CURRENT
MICROAMPERES
INSTANTANEOUS FORWARD CURRENT
(AMPERES)
100
10
1.0
0.1
1.0
TJ = 25°C
0.1
0.01
0.01
0.4
0.6
0.8
1.0
1.2
1.4
1.6
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
60
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE
The curve above is for reference only.
Rev:2024A2
Page :2
很抱歉,暂时无法提供与“KBU1510”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2.72725
- 10+2.14147
- 80+1.58450
- 160+1.56073
- 400+1.44045
- 国内价格
- 1+2.97519
- 10+2.33615
- 30+2.06378
- 100+1.72854
- 400+1.57140
- 800+1.47712
