山东晶导微电子股份有限公司
TB34S THRU TB320S
Jingdao Microelectronics co.LTD
3A SURFACE MOUNT SCHOTTKY BRIDGE
FEATURES:
PINNING
• Reverse Voltage - 40 to 200 V
PIN
DESCRIPTION
• Forward Current - 3 A
1
Input Pin(~)
• High Surge Current Capability
2
Input Pin(~)
• Designed for Surface Mount Application
3
Output Anode(+)
4
Output Cathode(-)
MECHANICAL DATA
• Case: ABS/LBF
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 88mg 0.0031oz
3
4
2
1
ABS/LBF Package
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
Parameter
TB34S
TB36S
TB38S
TB310S
TB320S
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
60
80
100
200
V
Maximum RMS voltage
V RMS
28
42
56
70
140
V
Maximum DC Blocking Voltage
V DC
40
60
80
100
200
V
Average Rectified Output Current
at T c = 100 °C
I F(AV)
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
Max Instantaneous Forward Voltage at 3 A
Maximum DC Reverse Current
T a = 25°C
at Rated DC Reverse Voltage
T a =100°C
Typical Junction Capacitance 1)
Typical Thermal Resistance
2)
Operating Junction Temperature Range
Storage Temperature Range
A
3.0
80
70
A
VF
0.55
IR
0.5
10
0.3
5
mA
Cj
250
160
pF
0.70
0.85
0.95
V
RθJA
60
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C.
2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad.
2016.01
ABS-S-TB34S~TB320S-3A200V
Page 1 of 3
山东晶导微电子股份有限公司
TB34S THRU TB320S
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
T J =75°C
10 2
TB34S
TB36S-TB320S
10 1
T J =25°C
10 0
Case Temperature (°C)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
500
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =100°C
10 3
10
1.0
TB34S
TB36S/TB38S
TB310S
TB320S
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
T J =25°C
200
100
50
TB32S/TB34S
TB36S-TB320S
10
1.8
0.1
1
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
100
8.3 ms Single Half Sine Wave
(JEDEC Method)
80
60
TB34S/TB36S
TB38S~TB320S
40
1
10
100
Number of Cycles at 60Hz
2016.01
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
TB34S THRU TB320S
PACKAGE OUTLINE
Plastic surface mounted package; 4 leads
ABS/LBF
∠ALL ROUND
∠ALL ROUND
C
A
a
L1
d
L
HE
e
D
e
E
ABS/LBF mechanical data
A
C
D
E
HE
d
e
max
1.5
0.22
5.2
4.5
6.4
4.2
0.7
min
1.3
0.15
4.9
4.2
6.0
3.8
0.5
max
59
8.7
205
177
252
165
28
min
51
5.9
193
166
236
150
UNIT
mm
L
L1
a
0.95
0.6
0.2
7°
37
mil
The recommended mounting pad size
24
4
Marking
Type number
6.2
244
4.0
157
1.0
39
2.0
79
2016.01
mm
Unit :
(mil)
XTH512285B0
Marking code
TB34S
TB34S
TB36S
TB36S
TB38S
TB38S
TB310S
TB310S
TB320S
TB320S
TBxxS
Page 3 of 3
很抱歉,暂时无法提供与“TB310S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.38316
- 50+1.09350
- 150+0.96941
- 500+0.81454
- 国内价格
- 5+0.94875
- 20+0.86250
- 100+0.77625
- 500+0.69000
- 1000+0.64975
- 2000+0.62100
