TP10331620
TP10331620
    ROCPU(台普)
    SMD,5.2x5.2mm
    轻触开关 5.2*5.2*2mm 立贴
TP10331620 数据手册
A B D C E F G Circuit Diagram 1 1 5.20 [0.205] T3 0.50 [0.020] T3 T1 T1 T6 T5 T4 T2 Main Specifications: 主要技术指标: Climate grade: -30℃~﹢80℃ 气候等级:-30℃~﹢80 Rated values:Max50 Ma12V,DC Min10 uA1V DC 额定值:Max50 Ma12V,DC Min10 uA1V DC Contact resistance:≤100m Ω 接触电阻:≤100m Ω 2 3.70 [0.146] T4 T2 4.80 [0.189] 2.00[0.079] 3 2.60 [0.102] 6.00 [0.236] 0.03 [0.001]±0.10 3.50 [0.138] 5 4.40 [0.173] 0.50 [0.020] 5.60 [0.220] 4 1.00 [0.039] 0.60 [0.024] 6.50 [0.256] 6 4 3 2 1 Upper cover 上盖 Push Button 按钮 Terminal 端子 Yellow Membrane 黄膜 Shrapnel 弹片 Plastic base 塑胶底座 Name NO UNIT A4 COMMON DRAWN BY FUYUAN 台普 A2 A1 REV MM ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C 1 SUS 不锈钢 1 LCP 1 Phosphor bronze 磷青铜 1 PI 1 SUS 不锈钢 1 LCP PCS Materials PROJCTED DATE 2019 CHECKED BY APPROVAL B Black 黑色 Silver plating 镀银 Yellow 黄色 Silver plating 镀银 Black 黑色 Notes COCO ALEN MODEL NO: TP10331620 Https: www.rocpu.tw ROCPU TECHNOLONGY CO.,LTD Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission D E 2 3 4 PRODUCT NAME: TOLERANCE A3 5 Dielectric strength:250V AC 1Min 耐压:250V AC 1Min Insulation resistance:≥100MΩ 绝缘电阻:≥100MΩ Travel:0.20±0.10mm 行程:0.20±0.10mm Operating force:160±50gf 操作力:160±50gf Life:200000 寿命:200000 F G 5
TP10331620 价格&库存
很抱歉,暂时无法提供与“TP10331620”相匹配的价格&库存,您可以联系我们找货
TP10331620
    • 5+0.66917
    • 50+0.53223
    • 150+0.46386
    • 500+0.41256
    库存:2618
