TP160112075
TP160112075
    ROCPU(台普)
    插件,12x12mm
    轻触开关 12*12*7.5mm 直插
TP160112075 数据手册
A D C E F G CIRCUIT 5.00 [0.197] 12.18 [0.479]±0.30 1 B 1.00[0.039] 1.00[0.039] 1 T4 T3 T2 T1 9.00[0.354] 11.90[0.469]±0.20 12.50[0.492]±0.50 13.80[0.543]±0.50 0 . 0 [Ø0.071 2 . 1 ] Ø 4 6.25[0.246] COMMON MM DRAWN BY FUYUAN 台普 A1 ROCPU DATE REVISION DESCRIPTION A ISSUE B X.XX ± 0.10 X.X ± 0.15 X ± 0.25 ANGULAR C 5 SWITCH BUTTON 开关按钮 Nylon 尼龙 COVER PLATE 盖板 SHRAPNEL 弹片 SUS 不锈钢 SUS 不锈钢 2 TERMINAL 端子 DATE 2019 1 1 Brass 黄铜 4 Silver 镀银 1 SILICONE 硅胶垫圈 Silica gel 硅胶 1 ITEM Name Materials NUM CHECKED BY APPROVAL B PRODUCT NAME: COCO ALEN MODEL NO: TP160112075 Https: www.rocpu.tw Copies are issued in strict confidence and shall not be reproduced or copied,or used as the basic of manufacture or sale of apparatus without permission E 4 COLOR ROCPU TECHNOLONGY CO.,LTD D 3 Brown 棕色 1 PROJCTED 2 1 Silver 镀银 TOLERANCE A3 A2 Nylon 尼龙 3 PCB LAYOUT UNIT 6 SWITCH HOUSING 开关外壳 4 12.50[0.492] A4 REV Ø [ 0 9.00 [0.354] 2-Ø1.80 1.80 [0.071] 0.30[0.012] ] 7 4 5.00 [0.197] 3.80[0.150] 3.45 [0.136] 1.80 [0.071] 4 3.70 [0.146]±0.30 3 4.50 [0.177] 7.50 [0.295]±0.20 2 5 SPECIFICATIONS 规格 CONTACT RATING:DC5~24V,1~50mA 触点额定值:DC5~24V,1~50mA OPERATION LIFE:3,000,000 cycles 运行寿命:300万次循环 CONTACT RESISITANCE:100mΩ max 接触电阻:最大100mΩ INSULATION RESISTANCE:100MΩ min,500VDC 绝缘电阻:最小100MΩ,500VDC OPERATING TEMPERATURE:-25℃to+70℃ 工作温度:-25℃至+70℃ Height:7.5mm 高度:7.5毫米 Operating force:200±30gf 操作力:200±30gf Waterproof grade:IP65 防水等级:IP65 F G 5
TP160112075 价格&库存
很抱歉,暂时无法提供与“TP160112075”相匹配的价格&库存,您可以联系我们找货
TP160112075
    • 1+4.16880
    • 10+3.35880
    • 40+2.94840
    库存:34
